Staro 21.02.2008., 16:23   #1
nenadv99
Lokacija: zadar
Postovi: 129
konfiguracija do 8k kuna
za igranje ne bas zahtjevnih igara, s vjerojatnom nadogradnjom za godinu dvije
Intel Core 2 Duo E4600 BOX, 2×2.4GHz, 800MHz, 775-pin, 2MB
Thermaltake CL-P0268, Mini Typhoon Cooler, Cu, scK AM2/775/939/754, 2200 rpm, 18 dBA
MB Gigabyte P35-DS3P, s775, iP35, DDR II, SATA II, RAID, FW, GLAN
DDR2 1GB PC6400 (800MHz), Kingmax
DDR2 512MB PC6400 (800MHz), Kingmax
HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200
DVD+RW/-RW/RAM LG GSA-H12L Dual Layer, LightScribe, 18x, bulk, black
Gigabyte Radeon HD3850, 256MB DDR3, TVout, Dual DVI
Thermaltake VD6000BNS mid tower Soprano VX, bez PS, crno, USB, Fire wire, 1×120mm fan
Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors
Logitech UltraX Flat Keyboard Premium HR + Logitech RX1000 Laserski miš USB
monitor Monitor Samsung SM 2232BW, 22" LCD, 2 ms, DVI, crni
Zadnje izmijenjeno od: McG. 22.02.2008. u 00:11.
nenadv99 je offline   Reply With Quote
Staro 21.02.2008., 16:31   #2
Bravo
Bravo's Avatar
Postovi: 1,450
proc uzmi E4400 il E4500 il E2180
a memoriju il 2x1Gb (dovoljno za sve igre) il 4x1Gb (nepotrebno što se tiče igara)...
i onda ti ostane za HD3850 512Mb il HD3870 512Mb..
Staro 21.02.2008., 16:57   #3
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Moj prijedlog prema uputama Brava :-)
mbo - Gigabyte P35-DS3, s775, intel P35+ICH9, FSB 1333/1066/800MHz
cpu - Procesor Intel Core 2 Duo E6750 , 2.66GHz, ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 x2
vga - VGA Ati Radeon HD 3870, 512Mb GDDR4, Dual DVI, PCI Express 16x
hdd - HDD Seagate 250GB, SATA II , Barracuda 7200.10, 16Mb,ST3250410AS
dvd - DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI,
psu - Napajanje CORSAIR 450W, VX Series CMPSU-450VXEU, 12cm vent.,ATX2
cas - Coolermaster Centurion 534 lite , black , bez napajanja
mon - PHILIPS 220WS8FB, 22" LCD, widescreen, 1000:1, 5ms, VGA, DVI-D
coo - SCYTHE Mine SCMN-1100, socket 478/775/754/940/939/AM2
tip - Tipkovnica Logitech UltraX Premium Keyboard, USB, HR, srebrno/cr
mis - Miš Logitech RX 1000, laserski, crn, USB
7.610,30Kn sve iz www.adm.hr
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 22.02.2008., 00:13   #4
Postovi: 7,568
8.000 kn i spominju se diskovi od 250 i 320GB.
Staro 22.02.2008., 00:19   #5
mislav_os
freak
Postovi: 2,688
Autor McG Pregled postova
Dobro si rekao
A inace je ova elvisova konfa sto je slozio dobra
Staro 22.02.2008., 09:23   #6
elvis again
In the ghetto
Postovi: 1,943
Stavio sam tog jer je brz i tih i netreba nis sa aam-om namjestavat, a ako covek hoce nek si pikne samsunga 500gb cca 300kn vise i gotovo - mjesta jos ima do 8k.
Staro 22.02.2008., 13:18   #7
Postovi: 7,568
Za tišinu još nekak, ali svu tu brzinu ne bude osjetil u onome kaj je spomenul. Osim ako cijele dane vrti HD Tune i HD Tach. Na stranu sad da se taj disk otkad su Osječani stavili recenziju, preporučuje pošto-poto za sve moguće konfiguracije. Ali Osječani pored brzih Seagatea imaju još pokoji TB sa strane. Uzalud mu i brzina i tišina, kad se 250GB danas u doba flata i HDa, napuni za jedan dan.
Staro 24.02.2008., 01:33   #8
mislav_os
freak
Postovi: 2,688
E ovo si super napisao...Potpisujem
Pogledaj samo u "moj komp" koji HDD imam
Imao sam prije njega Maxtora 250GB,i sad prije cca 2 tjedna uzeo ovaj,mislio sam da ce biti dovoljno,ali vraga.....Napuni se odmah,sa torrentima etc...
Tako da nenadv99,uzmi neki 320+ GB HDD
Staro 24.02.2008., 02:45   #9
jurbAs
jurbAs's Avatar
Postovi: 2,583
Heheheheh cca 5dana zestokog skidanja sa 8mbita.a ili cca 2 dana sa 16mbit.a hehehe meni je mjesecna fluktacija po disku oko 600gb mjesecno
McG e da mi je neki od 500 koji je tako brz ko taj Seagate ako znate neki javite da znam sto da kupujem... jedva cekam DFI UT P35 da mi zamjene.... da ubodem jos dva od 500
Zadnje izmijenjeno od: jurbAs. 24.02.2008. u 02:56.
Staro 24.02.2008., 02:56   #10
Postovi: 7,568
Autor jurbAs Pregled postova
McG nisam skonto kakve veze imaju Osjecani imaju veze sa Tb makar imam i ja doma 1.6Tb
To se odnosi na to da nemaju isključivo taj jedan jako popularan disk u konfiguracijama. Niti ga preporučuju uzduž i poprijeko. Disk je dobar, nema dileme, ali 250GB je jednostavno premali kapacitet - pogotovo u konfiguraciji za novce koji se tu spominju.
Staro 24.02.2008., 03:00   #11
jurbAs
jurbAs's Avatar
Postovi: 2,583
skonto zato sam editirao post ali si bio brzi.... ovaj ma u takvu kofu ako je samo kutija u pitanju drmnio bi 500gb bez pardona ili cak 2komada ako decko ima namjere imat flat to doslovno pojede disk u tren oka.... uzas... evo lega ima 320gb otkako ima flat stalno jadan muci muku sa mjestom....
jel znas kakav brzi disk od 500 imam doma nesretnog seagate 3AAK koji je uzasno spor i WD 500AAKS koji je odlican
Staro 24.02.2008., 03:08   #12
Postovi: 7,568
Iskreno nemam pojma, jer mi je brzina diskova bitna koliko i nijansa žute na njenoj haljini.
Ono kaj bi te moglo zanimati su Samsung 334GB platter i WesternDigital 320GB platter modeli.
Staro 24.02.2008., 03:24   #13
jurbAs
jurbAs's Avatar
Postovi: 2,583
mali su mi to diskovi nazalost... nista ispod 500 ne dolazi u obzir negine mi raid 0 koliko vidim.... tamo mi je bio prosjek oko 80 do 100mb/s posto imam dva identicna maxtora od 250 ko bog.. mozda njih zamjenim za ove od 320... to ne bi bilo lose.... brzi su a jos i raid ajme....
Staro 24.02.2008., 03:28   #14
Postovi: 7,568
Diskovi s tim platterima dolaze i s većim kapacitetom. Zato sam i napisal modeli, pa izabereš onog koji ti više odgovara.
Staro 24.02.2008., 03:31   #15
jurbAs
jurbAs's Avatar
Postovi: 2,583
da imas tu pravo ali treba ulovit dva ista tj identicna disk WD mi se svida po review covjece to moj raid sa maxtorom uffff nemos vjerovat... morat cu ozbiljno pocet razmisljat o ovome....bar za sistemski i programe
Staro 24.02.2008., 07:46   #16
Postovi: 33,978
Svesrdno preporučujem WD 5000AAKS - tih i hladan.
