Staro 16.02.2008., 16:22   #1
Alfredo nr.3
Alfredo nr.3's Avatar
Lokacija: Požega
Postovi: 1,244
Lg L226wtq Lcd
danas sam vidio ovaj monitor u eurotradeu, kosta 2158kn i odusevio me. citam review po netu, uglavnom su dobri, osim sto u jednom spominju rtc artefakte. no citao sam o tome i pise da je to jako tesko primjetiti ako se ne ide za tim. u ponedeljak cu ga jos jednom isprobati pa ako sve bude stimalo ga uzimam. nisam pitao da li dvi kabel dolazi uz monitor, nadam se da da. zanimaju me dojmovi onih koji ga posjeduju ili su radili na njemu.
Alfredo nr.3 je offline   Reply With Quote
Staro 17.02.2008., 00:30   #2
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
daj link na neki review..
Staro 17.02.2008., 01:21   #3
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
http://www.reviewspring.com/lg-l226wtq-lcd-a21.php http://www.xbitlabs.com/articles/oth...nch.html#sect0 - u ovom review spominju rtc artefakte, ali sam procitao da novije revizije nemaju taj problem. aperently all monitors manufactured in march 2007 have ghosting problems have that same monitor, mine was produced August 2007 and it's great with it's 2ms response time. same here but mine is 5000:1 contrast ratio and its made in korea The RTC mechanism is set up better in later revisions of the monitor's firmware (version 1.14 and later) To see the firmware version, turn off the screen, press the menu button and while pressing it turn on the screen. Now press menu again and you will see the service menu where you can see the firmware version. Ghosting is usually due to an incorrect panel type setting, also adjustable there. (I don't remember exactly which panel type is the right one, so be careful!) do you see any serial number?? like 703 , 704, 705 or something should stand on the pakage, or i think in the meny, if its an 704 or later its firmware 1.14 or later=good
Staro 17.02.2008., 03:20   #4
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
što reći, odličan monitor prihvatljive cijene, da mi treba monitor bio bi u užem izboru ako ne i prvi.
još 1 review: http://reviews.cnet.co.uk/monitors/0...9294285,00.htm
Staro 17.02.2008., 10:45   #5
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
taj Lg je "oprao" sve sasmunge i philipse u klasi (22" TN)...posebno me raduje kak je bolji u ghostingu i input lagu, odn. ima najbržu matricu i najmanje izražen lag....tko gleda 22" TN - to je najbolji izbor..
gnomisa je offline   Reply With Quote
Staro 17.02.2008., 14:22   #6
SmallDaddyMata
SmallDaddyMata's Avatar
Lokacija: Bj
Postovi: 7
Ja ga imam doma.... I sta da kazem monitor razvaljuje u igricama slika je kristalna da bolje neide... P.S. dvi kabl je s mojim došo tak da znaš LG-u za ovaj monitor. preporucujem da ga kupis
SmallDaddyMata je offline   Reply With Quote
Staro 17.02.2008., 15:49   #7
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
super. hvala na komentarima. sutra idem u eurotrade i uzimam monitor.
Staro 19.02.2008., 11:56   #8
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
javi kakve su impresije...
p.s. zna li netko podržava li ovaj monitor HDCP?
edit: podržava HDCP !!!
Staro 19.02.2008., 14:35   #9
refugee
Malac
refugee's Avatar
Datum registracije: Jun 2003
Lokacija: Zabreg
Postovi: 290
Jel i 20" model jednako dobar?
Komp 2...
Barton 2500+
Abit NF7 2.0
1GB DDR 400 KingMax
Seagate 200 GB
PNY 6800 GT
NEC 4551 DVD-R/RW DL + Toshiba DVD-ROM
refugee je offline   Reply With Quote
Staro 19.02.2008., 15:44   #10
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
uzeo sam monitor i nakon dan i pol rada, mogu samo reci da ne zalim ni lipe za ulozenim. monitor je zakon. stavio sam ga pored starog crtea i lijepo se vidi razlika u slici. slika je cisca i ostrija. nemam iskustva sa lcdima ali prikaz boje po meni je bolji nego na starom crt samsungu. kut gledanja je odlican. igrao sam pes gledao filmove,citao radove i nigdje nisam naisao na problem. koliko sam primjetio oci mi se manje umaraju nakon par sati gledanja u novi monitor. ps. monitor podrzava hdcp, kontrast pri movie modeu je deklarirano 5000:1 dfc, 2ms
Staro 20.02.2008., 14:04   #11
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
alfredo, baš gledam na stranicama eurotrade.a i tamo piše da ovaj monitor ima kontrast 3000:1, kakva je situacija na tvom? Koju si boju uzeo, ja bi crnu, znaš li da li imaju?
I jesi provjerio koji je FW kao što piše u #3 postu?
Pogledaj pa javi molim te..
Staro 20.02.2008., 14:23   #12
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
nisu imali monitor crne boje, ali ova sivo-crna, meni je taman. na monitoru je naljepnica na kojoj pise digital fine contrast 5000:1. izgleda da ima modela sa 3000:1 kontrastom, ali ovaj moj je 5000:1. podrzava hdcp i ima odaziv od 2ms. probao sam igre i odlicno rade, nisam primjetio ghostanje ili neki drugi problem. citao sam da je contrast 5000:1 samo kada se stavi movie mode, a normalno je valda 3000:1. firmware je 710, a pise da od 704 nadalje sve radi odlicno, sto potvrdujem. monitor je proizveden u decembru 2007. pogledas, pise na straznjoj strani monitora. uz monitor dolazi i dvi i vga kabel, te dva cdea jedan za driver i jedan sa programom forte manager pomocu kojeg se kalibrira monitor, te nudi opciju da se mjenjuju predefinirane postvka unutra windowsa, bez manualne akcije usmjerene prema monitoru, sto je za mene pohvalno. isto nudi opciju za ugasiti led lapicu, sto je isto pohvalno, jer moze smetati pri radu. ako te jos nesto zanima pitaj.
Staro 20.02.2008., 14:32   #13
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Mogel bi i par slikica postat :-)
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 20.02.2008., 15:01   #14
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
da moja malenkost posjeduje fotoaparat ne bi bilo problema. ako nabavim neki cu poslikati pa postati.
Staro 20.02.2008., 16:04   #15
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
sad bas gledam na stranicama lg.a model L227WT, cini se najnovije nesto ali nisam skuzio koja je razlika spram ovog, ako ima tko kakvih informacija...
Staro 21.02.2008., 01:00   #16
jurbAs
jurbAs's Avatar
Postovi: 2,583
alfredo koji ti je stvarni kontrast monitora?! a ne DC tj dinamic contrast on ti je vise marketing nego istina... nemoj se na to obazirat kakva je situacija sa kutom gledanja? jel sve 5 u tom polju?
Staro 21.02.2008., 10:26   #17
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
Autor jurbAs Pregled postova
imaš na stranici lg.a sve o ovom monitoru pa pogledaj, negdje piše da je kontrast 3000, negdje da je 5000:1
u biti koliko sam ja skužio delaultni kontrast je 3000:1 al imaš tipku na monitoru (movie mod) kojom se kontrast diže na 5000:1 ali naravno to te ne spriječava da odmah po paljenju monitora ne stisneš tipku i prebaciš na viši kontrast, vjerovatno to funcionira i u igrama ili svakodnevnom radu.
Inače i mene zanima kakvi su kutovi gledanja na monitoru i prikaz boja (alfredo, rekao si da nema iskustva s LCD.ima ali reci za kutove gledanja...)
Staro 22.02.2008., 02:13   #18
jurbAs
jurbAs's Avatar
Postovi: 2,583
heheh da nesto razjasnim 3000:1 5000:1 to ti je sve DC mene zanima pravi kontrast ja nisam susreo veci od 1500:1 na monitorima... tako da nevjerujem da i jedan ima veci... mozda cak i ima neki IPS ili tako nekaj... ali sumnjam da ima tn.ovac..... morat cu ja malo po netu potrazit podatke....
Staro 22.02.2008., 14:49   #19
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
lol, još nema lcd-a na tržištu koji ima preko 1000 contrast... a kamoli 5000..
to je sve dynamic, odnosno, prodavanje magle po velebitu..
Staro 22.02.2008., 14:57   #20
jurbAs
jurbAs's Avatar
Postovi: 2,583
heheheh imas jedan preko 1000 tj 2 971p 1500:1 i 245T 1500:1 tj radi se o istoj matrici samo je razlika u velicini....
evo gledam bas prade.de i oni kazu da i taj monitor prikazuje 1030:1 sad mozda moze 1500:1 ne kuzim u cemu je caka...
Staro 22.02.2008., 16:29   #21
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
kut gledanja je zaista odlican. prikaz crne i bijele boje je bolji nego na starom crteu, crna je crna, to mogu potvrditi. sto se tice predefiniranih postavka, po meni nisu dobro napravljene, npr. kada se stavi tekst onda monitor pojaca osvjetljenje, sto mi pocne smetati jer previse isijava. za razliku, samsung 226bw na tekst modu smanji osvjetljenje. podesio sam si sliku, stavio na normal i to i to. ovako je slika za mene odlicna. na ovom monitoru nije gust gledati divx i kopirane dvd-e jer se jako vide kockice, tako da sam se prebacio na nabavljanje hd materijala. koliko kuzim kontrast je bitan zbog detalja na tamnim dijelovima slike, ako grijesim ispravite me. pogledao sam malo hd materijala, demo filmic od samsunga i jedan sample star wars revenge od the sith i po meni slika je odlicna. na movie modeu boje budu previse izrazene, pogotovo osnovne.
Staro 24.02.2008., 18:25   #22
SmallDaddyMata
Lokacija: Bj
Postovi: 7
Stvarni kontrast ekrana je 3000:1, ali je digitalno poboljšana na 5000:1
Staro 24.02.2008., 23:27   #23
jurbAs
jurbAs's Avatar
Postovi: 2,583
Autor SmallDaddyMata Pregled postova
ufff jooj 1000 put 3000:1 je dinamicki kontrast ili krace receno marketing max kontrast pravi je 1000:1 kako je rekao gabre makar neki monitori kazu da mogu i 1500:1 ali iznad toga nema ekrana!!!
Staro 24.02.2008., 23:35   #24
darkijas
darkijas's Avatar
Postovi: 1,806
Autor Alfredo nr.3 Pregled postova
uff, u ovo nekako sumnjam ali kako ti kažeš
darkijas je offline   Reply With Quote
Staro 25.02.2008., 00:55   #25
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
to kažu i ova 2 testa u prvih par postova...
Staro 18.04.2008., 20:41   #26
Mano
Datum registracije: Apr 2008
Postovi: 1
molim vas ljudi, di bi se u rijeci mogao kupiti LG L227WT?
Ako ga je itko kupio, neka posta di ga je uzeo i za koju cijenu...
Sve di sam ja tražio nema. Ni u eurotrade-u..
Please help...
inače, ekipa, zakon ste.
Mano je offline   Reply With Quote
Staro 19.04.2008., 00:01   #27
elvis again
In the ghetto
Postovi: 1,943
Staro 19.04.2008., 01:15   #28
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Kolko je isplatljivo uzet Lenova l220x kraj 226WTQ? Jel je slika na njemu puno bolja gledano okomito, ne pod kutem?
Razlika u cijeni je 1000kn, znači lenovo je za trećinu skuplji!
Vasili je offline   Reply With Quote
Staro 19.04.2008., 12:49   #29
Uber Gosu
FORD Fix Or Repair Daily
Uber Gosu's Avatar
Postovi: 872
Autor Vasili Pregled postova
Cek, ti se salis ili?!?
Uber Gosu je offline   Reply With Quote
Staro 19.04.2008., 13:14   #30
Vasili
Vasili's Avatar
Lokacija: Križevci
Postovi: 307
Recimo da je naglasak na onome: razlika u cijeni je 1000kn. Nisam baš pri parama i puno bi mi se lakše bilo odlučit kad bi znao da razlika u slici postoji, ali da nije ogromna (gledano sprijeda). Ali očito ovdje to nije slučaj Jooj, ne znam, na kraju ću izgleda završit s LG-em.
