Lokacija: Požega
Postovi: 1,271
Lg L226wtq Lcd
danas sam vidio ovaj monitor u eurotradeu, kosta 2158kn i odusevio me. citam review po netu, uglavnom su dobri, osim sto u jednom spominju rtc artefakte. no citao sam o tome i pise da je to jako tesko primjetiti ako se ne ide za tim. u ponedeljak cu ga jos jednom isprobati pa ako sve bude stimalo ga uzimam. nisam pitao da li dvi kabel dolazi uz monitor, nadam se da da. zanimaju me dojmovi onih koji ga posjeduju ili su radili na njemu. |
COD2 expert
Postovi: 1,920
daj link na neki review.. |
Lokacija: Požega
Postovi: 1,271
http://www.reviewspring.com/lg-l226wtq-lcd-a21.php http://www.xbitlabs.com/articles/oth...nch.html#sect0 - u ovom review spominju rtc artefakte, ali sam procitao da novije revizije nemaju taj problem. aperently all monitors manufactured in march 2007 have ghosting problems have that same monitor, mine was produced August 2007 and it's great with it's 2ms response time. same here but mine is 5000:1 contrast ratio and its made in korea The RTC mechanism is set up better in later revisions of the monitor's firmware (version 1.14 and later) To see the firmware version, turn off the screen, press the menu button and while pressing it turn on the screen. Now press menu again and you will see the service menu where you can see the firmware version. Ghosting is usually due to an incorrect panel type setting, also adjustable there. (I don't remember exactly which panel type is the right one, so be careful!) do you see any serial number?? like 703 , 704, 705 or something should stand on the pakage, or i think in the meny, if its an 704 or later its firmware 1.14 or later=good |
COD2 expert
Postovi: 1,920
što reći, odličan monitor prihvatljive cijene, da mi treba monitor bio bi u užem izboru ako ne i prvi. još 1 review: http://reviews.cnet.co.uk/monitors/0...9294285,00.htm |
Datum registracije: Feb 2003
Postovi: 1,556
taj Lg je "oprao" sve sasmunge i philipse u klasi (22" TN)...posebno me raduje kak je bolji u ghostingu i input lagu, odn. ima najbržu matricu i najmanje izražen lag....tko gleda 22" TN - to je najbolji izbor.. |
Lokacija: Požega
Postovi: 1,271
uzeo sam monitor i nakon dan i pol rada, mogu samo reci da ne zalim ni lipe za ulozenim. monitor je zakon. stavio sam ga pored starog crtea i lijepo se vidi razlika u slici. slika je cisca i ostrija. nemam iskustva sa lcdima ali prikaz boje po meni je bolji nego na starom crt samsungu. kut gledanja je odlican. igrao sam pes gledao filmove,citao radove i nigdje nisam naisao na problem. koliko sam primjetio oci mi se manje umaraju nakon par sati gledanja u novi monitor. ps. monitor podrzava hdcp, kontrast pri movie modeu je deklarirano 5000:1 dfc, 2ms |
COD2 expert
Postovi: 1,920
alfredo, baš gledam na stranicama eurotrade.a i tamo piše da ovaj monitor ima kontrast 3000:1, kakva je situacija na tvom? Koju si boju uzeo, ja bi crnu, znaš li da li imaju? I jesi provjerio koji je FW kao što piše u #3 postu? Pogledaj pa javi molim te.. |
Lokacija: Požega
Postovi: 1,271
nisu imali monitor crne boje, ali ova sivo-crna, meni je taman. na monitoru je naljepnica na kojoj pise digital fine contrast 5000:1. izgleda da ima modela sa 3000:1 kontrastom, ali ovaj moj je 5000:1. podrzava hdcp i ima odaziv od 2ms. probao sam igre i odlicno rade, nisam primjetio ghostanje ili neki drugi problem. citao sam da je contrast 5000:1 samo kada se stavi movie mode, a normalno je valda 3000:1. firmware je 710, a pise da od 704 nadalje sve radi odlicno, sto potvrdujem. monitor je proizveden u decembru 2007. pogledas, pise na straznjoj strani monitora. uz monitor dolazi i dvi i vga kabel, te dva cdea jedan za driver i jedan sa programom forte manager pomocu kojeg se kalibrira monitor, te nudi opciju da se mjenjuju predefinirane postvka unutra windowsa, bez manualne akcije usmjerene prema monitoru, sto je za mene pohvalno. isto nudi opciju za ugasiti led lapicu, sto je isto pohvalno, jer moze smetati pri radu. ako te jos nesto zanima pitaj. |
In the ghetto
Postovi: 1,943
Mogel bi i par slikica postat :-)
#17 | |
COD2 expert
Postovi: 1,920
u biti koliko sam ja skužio delaultni kontrast je 3000:1 al imaš tipku na monitoru (movie mod) kojom se kontrast diže na 5000:1 ali naravno to te ne spriječava da odmah po paljenju monitora ne stisneš tipku i prebaciš na viši kontrast, vjerovatno to funcionira i u igrama ili svakodnevnom radu. Inače i mene zanima kakvi su kutovi gledanja na monitoru i prikaz boja (alfredo, rekao si da nema iskustva s LCD.ima ali reci za kutove gledanja...) |
#18 |
Postovi: 2,583
heheh da nesto razjasnim 3000:1 5000:1 to ti je sve DC mene zanima pravi kontrast ja nisam susreo veci od 1500:1 na monitorima... tako da nevjerujem da i jedan ima veci... mozda cak i ima neki IPS ili tako nekaj... ali sumnjam da ima tn.ovac..... morat cu ja malo po netu potrazit podatke.... |
#20 |
Postovi: 2,583
heheheh imas jedan preko 1000 tj 2 971p 1500:1 i 245T 1500:1 tj radi se o istoj matrici samo je razlika u velicini....evo gledam bas prade.de i oni kazu da i taj monitor prikazuje 1030:1 sad mozda moze 1500:1 ne kuzim u cemu je caka... ![]() |
#21 |
Lokacija: Požega
Postovi: 1,271
kut gledanja je zaista odlican. prikaz crne i bijele boje je bolji nego na starom crteu, crna je crna, to mogu potvrditi. sto se tice predefiniranih postavka, po meni nisu dobro napravljene, npr. kada se stavi tekst onda monitor pojaca osvjetljenje, sto mi pocne smetati jer previse isijava. za razliku, samsung 226bw na tekst modu smanji osvjetljenje. podesio sam si sliku, stavio na normal i to i to. ovako je slika za mene odlicna. na ovom monitoru nije gust gledati divx i kopirane dvd-e jer se jako vide kockice, tako da sam se prebacio na nabavljanje hd materijala. koliko kuzim kontrast je bitan zbog detalja na tamnim dijelovima slike, ako grijesim ispravite me. pogledao sam malo hd materijala, demo filmic od samsunga i jedan sample star wars revenge od the sith i po meni slika je odlicna. na movie modeu boje budu previse izrazene, pogotovo osnovne. |
#23 |
Postovi: 2,583
#26 |
Datum registracije: Apr 2008
Postovi: 1
molim vas ljudi, di bi se u rijeci mogao kupiti LG L227WT? Ako ga je itko kupio, neka posta di ga je uzeo i za koju cijenu... Sve di sam ja tražio nema. Ni u eurotrade-u.. Please help... inače, ekipa, zakon ste. ![]() |
#27 |
In the ghetto
Postovi: 1,943
Naruci ga u ADM-u i dopelaju ti ga besplatno. http://www.adm.hr/product_info.php?c...oducts_id=5425 http://www.adm.hr/shipping.php
#30 |
Lokacija: Križevci
Postovi: 307
Recimo da je naglasak na onome: razlika u cijeni je 1000kn. Nisam baš pri parama i puno bi mi se lakše bilo odlučit kad bi znao da razlika u slici postoji, ali da nije ogromna (gledano sprijeda). Ali očito ovdje to nije slučaj Jooj, ne znam, na kraju ću izgleda završit s LG-em. |
