Staro 05.02.2008., 11:56   #1
///Marac
Emergency Scratcher
///Marac's Avatar
Postovi: 142
Exclamation Konfa do 2500kn
Pozdrav decki!
Ovako, trebao bi nekoga, ko ima malo vremena, da mi sastavi konfu do 2500kn. Znaci netreba ni monutor ni nista samo "kanta sa dijelovima. Treba mi nesto za pokretat wow normalno.
Znaci samo kanta sa dijelovima do 2500kn
Hvala puno unaprijed
Have you ever noticed that chicks against abortion are the ones you would never fuck anyway?
///Marac je offline   Reply With Quote
Staro 05.02.2008., 12:13   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
mbo - Gigabyte P31-DS3L, s775, intel P31+ICH7, FSB 1333/1066/800MHz, 4
cpu - Procesor Intel Pentium Dual-Core E2160 , 1.8GHz, socket 775, 1Mb
ram - DDR2 1024Mb ( 1Gb ) PC6400 SuperTalent, T800UB1GSA, Samsung ch x2
psu - Napajanje FORTRON 350W, PNF, Super Silent, 12cm ventilator, ATX2
cas - Colors-it L8027-C43, bez napajanja, midi tower
hdd - HDD Hitachi GST Deskstar T7K250 160 Gb , Serial ATA II-300 , 72
dvd - DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI,
1.986,04Kn sve iz www.adm.hr
vga - PEAK Radeon X1950GT, 256MB DDR3, 256bit, TV-out, DVI = 600kn (vemil)
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 06.02.2008., 12:02   #3
///Marac
Emergency Scratcher
///Marac's Avatar
Postovi: 142
Znaci sa grafickom ovo bi ispalo 2586kn
daj mi reci, posto se ne razumijem dobro u te stvari, maticna koju si naveo je PCI ili AGP pitam tako da znam kod kupnje graficke :P
Btw mislite da bi ovo bilo ok za moje porebe, a to su WoW :P i surfanje internetom
Tnx
btw modovi sorry na prosloj temi, zaboravio sam da sam ovu otvorio
Staro 06.02.2008., 12:17   #4
Postovi: 33,930
C2D ploče sa agp-om su izrazito rijetke, a AMD AM2 ploče sa agp ni ne postoje. Dakle, PCI-E.
EDIT: na drugom postu sam ti stavio jednu AMD i jednu Intel konfu.
Staro 06.02.2008., 12:18   #5
prasak
You'll never walk alone
prasak's Avatar
Postovi: 324
Ta matična i grafa su PCI express i sasvim su dovoljni za WoW
i5 2500k i Ryzen 5 1600
prasak je offline   Reply With Quote
Staro 06.02.2008., 12:38   #6
///Marac
Emergency Scratcher
///Marac's Avatar
Postovi: 142
Hvala decki!!
