Staro 05.02.2008., 23:25   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
BSoD sa porukom Driver not less or equal si3132.sys
Lijep pozdrav svima!
Dakle kao što piše u nazivu, imam problem sa rušenjem windowsa zbog SATALink controllera SiL3132 koji nikako da riješim. ČAk sam formatirao disk i instalirao Win XP ponovo, ali problem je i dalje prisutan. 3132 je momentalno u device manageru "disabled" i sve radi savršeno.
Što da napravim? Update drivera je napravljen, no nije pomoglo, dobio sam kasnije novu poruku "driver not less or equal", no ovaj puta sa SCSIPORT.sys.
Možda tajna problema leži u IRQ-ima?
Matična ploča je Asus P5N32-SLI Deluxe sa nforce 4 chipsetom.
CPU P4 @ 3.0GHz, !GB Ram-a... 3 sata diska, Geforce 6200 Turbo Cache grafička..
Hvala unaprijed!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 06.02.2008., 12:46   #2
domy_os
domy_os's Avatar
Postovi: 18,828
Pa ako ne koristiš taj Silicon Image SATA kontroler, jednostavno ga isključi u BIOS-u i maknut će se iz Device Managera.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 06.02.2008., 12:51   #3
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Neće jer kad se dignu windowsi i preuzmu kontrolu opet će ga nać i aktivirati... Tako je i kod mene sa mojim kontrolerima...
Have a nice day...
Staro 06.02.2008., 13:02   #4
domy_os
domy_os's Avatar
Postovi: 18,828
Ne bi trebali jer Windowsi ne utječu na postavke u BIOS-u. Ako u BIOS-u isključiš, u Windowsima ga više nema i gotovo.
Staro 06.02.2008., 13:06   #5
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor domy_os Pregled postova
Palo mi i to na pamet, ali il u mom BIOS-u nema te opcije il sam slijep.. ali ipak mislim da nemam tu opciju
Staro 06.02.2008., 14:04   #6
Misak
Misak's Avatar
Lokacija: Donji Miholjac
Postovi: 391
Autor Traitorous_8 Pregled postova
probaj kad budes u BIOS-u stisnuti CTRL+F1.. s time bi mogao dobiti dosta dodatnih opcija.. makar mislim da bi morala biti opcija da iskljucis SATA kontroler po defaultu...
.....:::: There is no place like 127.0.0.1 ::::.....
Misak je offline   Reply With Quote
Staro 06.02.2008., 14:07   #7
yedwy
yedwy's Avatar
Postovi: 6,956
A gle to što bi trebali ili ne ne igra ulogu, recimo ja ugasim svoje IDE kontrolere u BIOSu i kod boota sve ok ne listaju se niti nišata na njima spojeno nije vidljivo BIOSu ali kad se dignu windowsi oba momka su tamo i spremni čekaju sve uredno instalirano, zašto je tako neznam ali je tako, neznam dal je i vice versa slučaj (kadd su ti uređaji na ATA a ugasiš SATA) jer iako sam imao ATA na ovoj ploči saugašenim SATA više se fakat ne sjećam jel ih pokazivao ili nije ali za ATA je ziher tako kako ti velim, LPT, COM i ovo ostalo to normalni ide, kad ugasiš neki od njih ostaje ugašen ali disk kontroler ne, i to i podd XPima i pod Vistom jednako...
Sad možda je to zato jer mi je SATA u IDE modu ali u svakom slučaju je tako dakle samo gašenje u BIOSu nije garancija da će gamad nestati iz device managera...
Have a nice day...
Staro 06.02.2008., 23:33   #8
domy_os
domy_os's Avatar
Postovi: 18,828
Čekaj, ti si isključivao onaj IDE kontroler što ga kontrolira southbridge/chipset? Imaš baš opciju za isključiti kontroler ili si samo u Standard CMOS Features sve prebacio s Auto na None? Ako je to u pitanju, naravno da se uređaji vide u Windowsima, na dosta ploča se to događa...
Staro 07.02.2008., 07:51   #9
yedwy
yedwy's Avatar
Postovi: 6,956
Ugasio IDE kanale u BIOSu stavljeni na Disabled, piše nešto u stilu IDE Primary Channel - Enabled/Disabled ima (ne sjećam se točnog teksta a neda mi se gledati) i isto za drugi i onda imaš ispod još SATA 1/2 i SATA 3/4 isto tako sa Enabled/Disabled (tj u tom stilu) na mojoj ploči...
I ako staviš na disabled ide kanale onda imaš kako gore velim, ja neznam kako bi ih drugačije mogao ugasit, tako sam godinama radio na drugim pločama i uvjek je radilo ali na ovoj nforce4 neće...
Have a nice day...
Staro 11.02.2008., 14:34   #10
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor yedwy Pregled postova
Pitam se jedno, jel moguće da je otišao taj chip na ploči?
Staro 11.02.2008., 14:50   #11
yedwy
yedwy's Avatar
Postovi: 6,956
Misliš da je kontroler crko? Hmm moguće je i to naravno, probaj s nekim PCI kontrolerrom ako si u prilici pa vidi...
Jesi gledao dal ima noviji BIOS za ploču?
Have a nice day...
