Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 10.01.2008., 03:09   #1
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
[Review] Accelero Xtreme
5 heatpipeova , 3x 80 ventova i sve to 610g...
no podrska samo za radeonku 2900xt/pro i 8800 ultra/gtx/gts no ocekuje se jos i za 8800GT te HD38x0 . Instalacija doticnog je veoma laka a sve sto morate paziti je da ustekate sva 3 venta prije postavljanja
Samo je steta sto nisu testirali malo vise coolera tj samo su ga testirali protiv stocka...
The new Arctic-Cooling Accelero Xtreme 2900 is quite possibly the best all round VGA cooler we have ever seen. In fact the only real potential problem we see with this new product is its size, though given the performance we could easily live with that. Unlike the standard reference cooler the Accelero Xtreme 2900 takes up three expansion slots rather than two. However, because nearly all good Crossfire motherboards place two slots between the PCI Express x16 ports, this will not be an issue for those wanting to use the Accelero Xtreme 2900 on a Crossfire platform.
Legionhardware
Staro 10.01.2008., 03:32   #2
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Pa kome to treba? Šta fali S1-ici?
- Barney Stinson
Staro 10.01.2008., 03:38   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Mar Pregled postova
Na brzinu sam proletio review ali mi se čini da je ova puno tanja od S1-inice, a to je čini pogodnom za CF/SLI konfiguracije!
Staro 10.01.2008., 03:42   #4
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
The problem with the standard coolers when used in Crossfire mode is that the first card smothers the second graphics card, making it very difficult for the lower card to draw in air. Due to the unique design of the fan shroud featured on the Accelero Xtreme 2900 this is no longer an issue, as both graphics cards are able to draw in enough air. Furthermore, when used in Crossfire mode the Accelero Xtreme 2900 is significantly quieter than the standard reference cooler.
Staro 10.01.2008., 13:20   #5
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Perverzija! Dobro je sto je u komadu pa obuhvaca i ram. Ne moramo se vise zezat s onim ram jezicima i ljepljenjem.
Staro 10.01.2008., 13:57   #6
Dngy
Dngy's Avatar
Postovi: 507
zanimljiv hladnjak...čovječe za koju godinu/mjesec će hladnjaci zauzimati i po 3 slota...
zanima me jedino koliko je glasno/tiho ovo čudo.
Dngy je offline   Reply With Quote
Staro 10.01.2008., 14:22   #7
Neo-ST
Neo-ST's Avatar
Postovi: 8,498
OT:
meni jedna stvar konstantno nije jasna u računalnoj industriji. Cijela industrija navodno teži minijaturizaciji komponenti, a koliko ja vidim komponente postaju sve veće i veće... npr. veličina grafičkih kartica danas (2900xt, 8800gtx, a da ne spominjem novodolazeću 3870X2), nadalje, te komponente zahtjevaju veća kućišta, bolje hlađenje (više težine), itd...
Staro 10.01.2008., 14:26   #8
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
cek... spomenuo si velicinu 3870x2 ? pa vec postoji tolika kartica a i kako zamisljas dual gpu a velicinu jedne kartice? treba 2 gpu-a i memorijske cipove uspjet strpat na takav prostor
dalje... minijaturizacija komponenti nemoze sjest na svakom podrucju... nemos sad ocekivat bestiju od grafe a da je duga taman do zavrsetka pci-e slota
Staro 10.01.2008., 14:36   #9
Neo-ST
Neo-ST's Avatar
Postovi: 8,498
Autor Bullet1 Pregled postova
Zar je? A koja?
Slažem se, ali onda ne težimo minijaturizaciji
Staro 10.01.2008., 14:41   #10
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Ako želiš minijaturizaciju uzmeš si 7100gs ili x1550 ili slično nešt. A minijaturizacija kod high-end kartica i služi da bi mogao više natrpati na nju.
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 10.01.2008., 15:05   #11
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor Neo-ST Pregled postova
Zar je? A koja?
8800Ultra
nevjernicima evo i slika...
Staro 10.01.2008., 15:44   #12
Neo-ST
Neo-ST's Avatar
Postovi: 8,498
8800Ultra
Super, nisam znao
Kolika će onda bit 9800 gx2 ?
Staro 10.01.2008., 16:09   #13
domy_os
domy_os's Avatar
Postovi: 18,906
X1900AIW je svega par mm kraća od 3870x2, ako i toliko pa ne vidim u čemu je problem.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 10.01.2008., 16:55   #14
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Kolko ce kostat to cudo?
Inace, jedna stvar kaj mi se nesvida kod coolera, to su ove 2-3mm debele spuzvice koje idu na memoriju. Recimo ja sa S1 nisam stavljao ježićke, nego posao hladenja memorije obavlja vent. Jednino sam na naponski dio stavio pola pasivnjaka od GF2 MX400.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 10.01.2008., 17:04   #15
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Fali joj sto ne ide na HD2900XT/Pro.
Staro 11.01.2008., 00:58   #16
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Autor Panzer Pregled postova
To se jako lako da riješti skidanjem istih i upotrebom ljpila poput "super bond" i termalne paste.
Staro 12.01.2008., 11:41   #17
LuxZg
Postovi: 512
Evo još jedan friški review, ovaj put sa Guru3D.
Piše da će biti oko 30€..
Ma ono, super izgleda, i sve je to ok ali ima i svojih mana:
- nije ništa manja od S1+2x120mm ventovi (što se tiče zauzimanja slotova)
- sumnjam da i hladi išta bolje u istim uvijetima jer je...
- ...površina zapravo manja nego kod S1 i...
- ... ima 3x80mm? 80mm? ma zaštoooo?!
- ovo sa heatsinkom na memoriji je i pozitivno i negativno, al spužvice im stvarno nisu trebale.. zar nema boljeg načina kad to SVI rade?!?
- nema seljenja na drugu grafičku jer je svaki model rađen samo za 1 model kartica :/
Prednosti po mom mišljenju su:
- laka instalacija jer dobiješ all-in-one paket "stavi i vozi", tj. sve je odmah "po mjeri" za karticu za koju je cooler namijenjen uključujući i ventilatore (tj nema izmišljanja kao kod npr 2x120mm na S1 )
- super omjer performansi/glasnoće
- i svakako dobro izgleda sa tim nosačem za ventove
I onda kad maknemo onaj dio sa "lakom instalacijom" jer će entuzijasti i tako htjet još malo nešto napraviti i tweakati po svojoj mjeri, i to da se odličan omjer performansi/dB može postići i sa dobrim izborom ventova za S1 (again, taman za ljude koji žele osobno birati svaku komponentu ), ostaje nam samo dobar izgled (koji se kod mene i tako ne vidi ).
Ja bi radije da još malo povećaju S1 tako da sa sadašnjih 140x215 produže hladnjak na 140x280 kako bi stala 2x 140mm ventilatora E to bi bio EXTREME I nije to tako puno, S1 je već toliko širok, Extreme je već jednako toliko dug, sad to treba samo spojiti Pa na takav veći cooler stane i još jedna-dvije pipe I onda nek fino naprave ovaj držač za ventove kao na Extreme od plexija, al sa 2x 140mm ventovima mountanim isto kao turbo modul za S1 (bez "kaveza") I dobiješ idealno rješenje koje pokupi sve najbolje od oba coolera Eh da, i naravno bolje ljepilo za ježiće za memoriju, kao i opciju da se montira i sa druge strane kartice (ili alternativni drugi model koji ima tu opciju, za one izbirljive tipa Accelero S1 Extreme FRONT i Accelero S1 Extreme BACK )
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 12.01.2008., 14:35   #18
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
mislim da si falio prozor u kojem pises... da ovo nije bilo namjereno Artic Coolingu
sala... ideja je dobra no ipak cemu jos povecavat velicinu S1? i ovako nije bas mal cooler a hladi i vise nego odlicno. pa sad da naprave sve kako si ti napisao cijena nevjerujem da cijena ostala u rangu od < 200kn a i dobio bi mozda 3-4°C. Nema potrebe za njim.
A sto se tice Extreme-a vec sam reko da se planira pravit i za 38x0 serije te 8800GT a danas ljudi to na veliko kupuju pa nevidim razlog zasto bi se bunili na hladnjak samo zato sto se nemoze namontirat na sljedecu grafu. Po meni je hladnjak odlican samo sto se ne isplati stavljat na 2900 :P
Staro 12.01.2008., 22:45   #19
LuxZg
Postovi: 512
sala...
Stiltao si me skroz, jer fakat visim u 30 tabova pa nebi bilo ni čudno Srećom pa si napisao da je šala inače bi bio zbunjen još neko vrijeme ROFL
Ma znam, al ak već rade "extremne" hladnjake, onda bi ovo po mom prijedlogu bio bolji put
Staro 05.03.2008., 12:00   #20
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Evo, koliko vidim OVDJE cooler košta ispod 30€, točnije 29€ što smatram da je jako dobra cijena s obzirom na performanse.
I5 3350P
XFX XTR 650W
Silencio 650
Staro 03.04.2008., 10:43   #21
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Žao mi je što dižem ovu temu, ali ima li ovog IGDJE u Lijepoj Našoj za kupiti?
I5 3350P
XFX XTR 650W
Silencio 650
Staro 03.04.2008., 11:42   #22
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
mislim da ne... kad bestija otvori shop bit ce
Staro 08.04.2008., 13:45   #23
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Evo stigel u Links:
http://www.links.hr/index.php?naziv=...kl=050.909.126
vjerujem da ce nestat u trenu.
Ja bi ga kupil al sam narucil vec S1
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 08.04.2008., 17:29   #24
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Al zbilja sad... Čemu to kraj S1?
Da imaš sličnu temperaturu ko i S1?
Whatever...
Staro 08.04.2008., 18:16   #25
Razer
Razer's Avatar
Postovi: 11,642
Čemu to? Pogledaj kojim je karticama cooler namjenjen.
Prvenstveno G80 i R600 čipovima.
Staro 08.04.2008., 20:41   #26
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Šteta što ne može da se montira na A9200 ili GF4... bilo bi to nezaboravno iskustvo...
Meni je kod njega najzanimljiva cijena. Samo 40-45€.
