Lokacija: Orahovica
Postovi: 7,363
Gigabyte P31-DS3L Review by Crash009
Gigabyte P31-DS3L review by Crash009 Nakon sto sam odlucio preci nazad na Intela odluka je pala na budget procesor E2160 M0, I tu pocinje potraga za pločom koja je stabilna, opremljena i dobra za OC. Nakon citanja pola tone reviewa i svrljanja po domacim IT shopovima odluka je pala na Gigabyte P31-DS3L. Neki ce reci zasto nisam uzeo P35, no uzeo bih ja takvu plocu no budget je bio stvarno rastegnut maksimalno, a tih 120kn vise koliko dodje P35 nisam imao. Krenimo sada sa samu plocu i specifikacije. CPU 1. Support for an Intel ® Core™ 2 Extreme processor/ Intel ® Core™ 2 Quad processor/ Intel ® Core™ 2 Duo processor/ Intel Pentium processor Extreme Edition/ Intel ® Pentium D processor/ Intel ® Pentium 4 processor Extreme Edition/ Intel ® Pentium 4 processor/ Intel ® Celeron processor in the LGA 775 package 2. Support for Intel Hyper-Threading Technology 3. L2 cache varies with CPU Front Side Bus 1. 1333/1066/800 MHz FSB Chipset 1. North Bridge: Intel ® P31 Express Chipset 2. South Bridge: Intel ® ICH7 Memory 1. 4 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory (Note 1) 2. Dual channel memory architecture 3. Support for DDR2 800/667 MHz memory modules (Note 2) Audio 1. Realtek ALC888 codec 2. High Definition Audio 3. 2/4/5.1/7.1-channel 4. Support for S/PDIF In/Out 5. Support for CD In LAN 1. RTL 8111B chip (10/100/1000 Mbit) Expansion Slots 1. 1 x PCI Express x16 slot 2. 3 x PCI Express x1 slots 3. 3 x PCI slots Storage Interface South Bridge: 1. 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices 2. 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices iTE IT8718 chip: 1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive USB Integrated in the South Bridge 1. Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers) Internal I/O Connectors 1. 1 x 24-pin ATX main power connector 2. 1 x 4-pin ATX 12V power connector 3. 1 x floppy disk drive connector 4. 1 x IDE connector 5. 4 x SATA 3Gb/s connectors 6. 1 x CPU fan header 7. 2 x system fan headers 8. 1 x power fan header 9. 1 x front panel header 10. 1 x front panel audio header 11. 1 x CD In connector 12. 1 x S/PDIF In header 13. 1 x S/PDIF Out header 14. 2 x USB 2.0/1.1 headers 15. 1 x chassis intrusion header 16. 1 x power LED header Back Panel Connectors 1. 1 x PS/2 keyboard port Connectors 2. 1 x PS/2 mouse port 3. 1 x parallel port 4. 1 x serial port 5. 4 x USB 2.0/1.1 ports 6. 1 x RJ-45 port 7. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone) BUNDLE Ploca dolazi sa solidnim budleom, nista posebno no sve potrebno za rad. Uputstva za instalaciju ploce,knjizica, SATA kabel, IDE kabel, GB naljepnice, CD sa driverima i usluznim programima. Ocjena 3.5 / 5 |
Lokacija: Orahovica
Postovi: 7,363
Layout Layut same ploce je dobar, sve je tamo gdje bi trebalo biti, chipset je dovoljno udaljen od CPU socketa, tako da nema problema sa montiranjem vecih coolera. Ram slotovi su na dobrom mjestu tako da nema problema sa vađenjem rama ako imate vecu graficku karticu. Jedina zamjerka ide poziciji IDE konektora koji se nalazi u donjem desnom dijelu ploce, tako da je korisnicima sa big tower caseom malo nezgodno ako imamo dvije optike jer je onaj stock kabel prekratak da dohvati do drugog optickog pogona. Ocjena 4.5 / 5 BIOS Sad ide ono sto vas je vjerovatno najvise zanimalo. Osnovne postavke cu preskociti jer su manje-vise isti na svim plocama. Postavke memorije: ![]() Memorijski divideri: ![]() Ploca ima "feature" nazvan High speed DRAM DLL koji sluzi za spremanje dva profila SPD postavki, automatski ucitava drugi ako sa prvim ploca odbije bootanje. Ovu funkciju nisam isprobavao, no vidim da na stranim ekipa to bas i ne koristi. CPU postavke i Voltaze: ![]() Max FSB je 700MHz, takt PCI-E sabirnice je od 100 do 150MHz Ploca ima "famuozne" mogucnosti auto OC-a pod nazivom C.I.A.2 koje nisam imao prilike, a niti zelje isprobavati. No eto da napomenem i to. ![]() Max Voltaze su: CPU: 2.0 V ![]() MEM: +0.7V PCI-E: +0.3V FSB: +0.3V MCH: +0.3V BIOS Zakljucak: OC mogucnosti su stvarno odlicne, na ostala podesenja nemam nikakvih zamjerki. Sve je na mjestu i radi. Minus ide djelu HW monitoringa koji ne ispisuje voltaze vec samo govori OK or NOT. Takodjer mi se ne svidja sto se ponekad nakon mjenjana postavki komp ugasi te ponovo upali, no to rade i ostale ploce sa P31 i P35 chipsetom. Ocjena 4.5 / 5 Overclocking Ovaj dio ce morati malo pricekati jer nisam jos ni win sredio kako treba, no sto se tice max FSB-a probao sam onako cisto informativno staviti FSB na 420MHz, default voltaza i prolazi 3h Orthosa. Sto se tice situacije sa mojim procom ja ga trenutno vrtim na 334x9 dakle 3GHz sve voltaze na default i radi stabilno. Plocu sam testirao u raznim programima i benchmarcima, nema nikakvih rusenja. Brzinu nisam usporedjivao jer nemam prilike doci do jos koje 775 ploce, a nema smisla usporedjivati sa KN8 Ultra i Venicom 3000+ Zakljucak: Ploca privlaci ponajvise svojom cijenom, ali i OC sposobnostima sa kojima ne zaostaje ni sa puno sklupljim plocama. Preporuka svima koji traze budget plocu, dobro opremljenu i sa odlicnim OC mogucnostima. Zamjerke idu jedino poziciji IDE konektora i oskudnijim bundleom, no ne treba ocekivati neznam sta od budget ploce. Ukupna ocijena 4.5 / 5 Cijena je 508kn u ADM-u. Ispricavam se ako sam nesto zaboravio, pisao sam ovo dosta sturo, tako ako imate kakvih pitanja samo pisite. |
Lokacija: Vz - Zg
Postovi: 2,930
sweet, sad mi nije nimalo krivo sto sam tu plocu spomenuo par puta ekipi, stvarno je u rangu skuplje brace! nadam se da ces ju jos malo iscjedit ovih dana pa javit dojmove, sretno, 4+
Postovi: 1,194
Igrom slucaja sam ostal bez ploce i cital sam o ovoj po netu, ali sad je definitivno kupujem. ![]()
cpu e4300/sonictower+nexus120; mbo gigabyte p35-ds3-l; ram kingmax1024/667x2; vga hd3850; psu corsair hx 520w; dvd benq 1655; hdd wd1200jd&samsung hd321kj&ST3160021A; ZM-MFC1; lg22ws; btc6300; mx 518 i sve u chiefu s nekoliko nexusa |
Postovi: 11,642
Nice review ![]() Piva za trud ![]() Čini se kao neloša ploča za malo love Baš me zanima koliko ćeš još uspijeti potegnuti ![]() |
Lokacija: Orahovica
Postovi: 7,363
TY all ![]() cim uhvatim malo vremena i koju hladnu zuju idem ju isprobati da vidim dokle che ici, nadam se da cu nabaviti i neki bolji cooler za proc jer na 3GHz mi je temp oko 56c u loadu... sto se tice same ploce rezem si jaja ak nije u rangu sa GB P35 ![]() |
music freak
Lokacija: Sibenik
Postovi: 3,316
visoki fsb na jeftinim plocama kida performanse tako da vam malo pokvarim veselje,jednostavno pokreni npr cod 4 i gledaj ocitavanje misije kad je na defaultu i kad je clockan pa javi koja ce postavke prije ocitati misiju odnosno gdje ce ona crtica "tecnije" ici ...znam da ulecem kao padobranac ali jbga stvarnost je surova nazalost,ovo ima veze i sa mojim zapazanjima vezano za overclock...zaboravite na super pi ostale pizd*rije ![]()
Lokacija: Sk
Postovi: 275
Lokacija: Zabok
Postovi: 3,395
Ploca (bolje reći chipset) ima jednu manu, a to je da podržava samo 2 dvostrana memorijska sticka i do 4Gb rama (ovo drugo još i nije neko veliko ograničenje). |
#11 | |
Lokacija: split
Postovi: 119
Loše puno ljudi naprimjer kao ja nemamo ti pojma šta je COD 4 ili bilo koja igrica ili igretina tako da nas perfomanse igara ne zanimaju |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Jel ti ozbiljno misliš da je to slučaj samo sa igrama ili se šališ? Pa tako je sa svakim programom koji nije fuckn sintetički ben-čmark a ja baš ne priznajem čmark programe kao koristan software na kojem neko nešto konstruktivno radi (ne računam one koji ih programiraju) prema tome meni je npr bitniji podatak dal nešto vrti bolje igre/3d studio/photoshop nego dal daje 41s ili 38s u Super PIu...
-- Have a nice day... |
#14 | |
Postovi: 285
![]() Na koji način se to može izmjerit? Ak se teže učitavaju leveli to bi mogao biti problem sa hard diskom kolko se meni čini. Svaki review na netu neke kartice ili procesora ima graf performanski na stock postavkama i na ne stock postavkama, a nisam nigdje vidio review da je u nekoj igri dobiveno manje FPS kad je hardware overclockan. |
#15 | |
Lokacija: Orahovica
Postovi: 7,363
hm.. ovo je dosta relativna stvar jer meni gotovo nikad ne ucitava jednako brzo mapu bilo na defaultu ili ne, nekad sjednostavo treba koju sec vise ili manje neovisno bio proc na defaultu ili clockan |
#16 | |
Postovi: 372
ima veze sa brzinom harda, mem kontrolera memorije i hard kontrolera. P35 chipset bio on na p5k deluxe ili na p35 ds3 ili na nekoj DFI svudje ima jednake performanse clockan ili ne, onih 5% MAX ovisi o proizvođaču ploče, a ne chipsetu. Kao što je rekao MADMAX u nekom threadu nema smisla davat preko 1k kn za neke ploče na kojima njihove điđe nećemo nikad ni koristiti. Crossfire, SLI itd, po meni danas nitko nema šta gledati dalje od P35-DS3 ili abitove IP-35-E sve dalje je bacanje novaca(moje mišljenje). Došli smo u vrijeme kada se vrhunska ploča može kupiti za 600 kn, ljudi prihvatite to ![]()
#17 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Sto se mene tice meni i Presler sasma dobro sluzi za rekodiranje videa u mpeg2 u Premiereu Visoka frekvencija same jezgre to odradjuje bez problema i nemam uopce potrebe za mijenjanjem procesora jos kojih godinu dana. Jedinu dvojbu sam imao za drugi komp, a to je uzeti novu plocu za P4 630 i na koju ici...dati 400kn za Abit GD8 Pro sa i915P chipsetom ili odmah ici na P35 sa Abit IP35-E...i odlucio sam se na ovu drugu i bleknuo dodatnih 339kn iako nisam siguran da cu skoro kupovati Core 2 procesor. 630-ka i 945-ica rade sve okej. Zasto P35? Pa eto noviji je i recimo da je bolji layout same ploce sto mi se kod Gigabytica nimalo ne svidja. Ta njihova sarenost i pretrpanost mi izgleda kao Amusement park, da ne spominjem rollercoaster MSI sa onim smijesnim cijevima ![]() |
#21 |
Lokacija: ZG, Sesvete
Postovi: 123
Najbitnije razlike su u ovome: P31: 4GB DDR2 max, ICH7 southbridge, ima native IDE controller P35: 8GB DDR2 & DDR3 max, ICH9 southbridge, ima dodatni JMicron IDE controller Postoji razlika i u max. broju S-ATA i USB portova. |
#23 |
music freak
Lokacija: Sibenik
Postovi: 3,316
...cod 4 sam naveo kao primjerak,ista stvar je u recimo igri flatout...cinjenica je da meni komp bolje radi na 266x10 nego recimo 375x8,tj uvjek ali bas uvjek mi brze ocita na nizim vrijednostima,jedina razlika na vecem fsb-u koju vidim je brze otvaranje foldera,ali ovo nije prva konfiguracija na kojoj sam primjetio da je komp zagusen pri vecim fsb brzinama...bas trazim clanak na kojoj je Gigabyte P35C-DS3R pokazala losije performanse u slucaju clockanja i to joj je navedeno kako minus,kad nadjem onda postam nasao: http://www.xbitlabs.com/articles/mai..._18.html#sect0
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD) Zadnje izmijenjeno od: joolka. 31.12.2007. u 16:27. |
#24 |
Postovi: 285
Oprosti meni tu niš nije jasno na kaj misliš. Ono kaj piše u ovom review-u je da gigabytica ima slabije performanse od asusice kad su obje overclokcane, gdje ju asusica šije za nevjerojatnih 0.005879%. Al obje imaju primjetno bolje performanse kad su klockane nego na stock postavkama. |
#29 | |
Postovi: 8,438
#30 |
Postovi: 7,504
