Staro 27.12.2007., 03:43   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Koja AM2 MB za Vistu x64/jeftiniji DDR2?
Presao bih sa S939 na AM2.
Uz X2 5600+, koju plocu bi preporucili, a da radi stabilno i da nema problema sa driverima na Visti x64?
I uz koju jefitniju 4x1GB DDR2 800 memoriju u DC, a da ne bi bilo problema sa kompatibilnosti.
Ne clockam. Treba mi stabilno racunalo koje podnosi dugi rad.
Nemojte diskutirati pro-contra Vista/64bit.
Hocu misljenje nekoga tko je probao.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 27.12.2007., 11:13   #2
DannyHR
Nub azz pwnzor!
DannyHR's Avatar
Postovi: 97
Ploča - ASUS M2N - nforce 430 - LINK
Memorija - Kingmax PC-6400, 1 GB, 800 MHz - LINK
Ploča ima sve što trebaš, pa iako ne clockaš ima podršku za spremanje profila za OC.
Nek se nađe. Za svoju cijenu jako dobra ploča.
'Cause we hunt you down without mercy
Hunt you down all nightmare long
Feel us breathe upon your face
Feel us shift, every move we trace
DannyHR je offline   Reply With Quote
Staro 27.12.2007., 12:49   #3
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ma, koja god nforce ploča za AM2, jer je Nvidija već odavno ponudila drivere za Vistu x64. RAM bi mogao i Kingmaxov 667 da uštediš koju kunu (doslovno ).
Svako računalo bi trebalo biti stabilno i podnositi dugi rad. Ako su mu komponente ispravne.
Drugi je problem to što Vista nekima jednostavno raditi kako spada (mada je i to pitanje koje bi se moglo dotaknuti i same stručnosti korisnika), dok onima kojima od prvog dana radi - radi odlično. Ali velim, na svim matičnim pločama, barem sa nforce chipsetom za koji postoje driveri za Vistu 32/64, trebala bi raditi odlično.
Staro 27.12.2007., 15:35   #4
jimi
Postovi: 80
Uzmi Athlon x2 5000 BE, stvarno nemaš nikakvih problema kod overclockanja jer samo trebaš mu promjeniti množitelj kaj je lako, a nema problema s kompom dok ne diraš volatažu. Jeftiniji ti je od 5600, a L2 cache ti kod amd-a nema toliko veliku važnost kao kod Intela.
Kingmax 800 Mhz- keksi od 1 GB su u vemilu po 139 kn kaj je malo, a i memorija je dobra.
A kod ploča uzmeš uzmeš onu za koju imaš para a chipseti us ti n560, 570, 590, amd 690g ili690v
jimi je offline   Reply With Quote
Staro 27.12.2007., 16:31   #5
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ja furam tu vistu na gigabyte m55s-s3 + x2 3600+ na 5400+ i 2x1gb super talent cl4 ddr800 + 2x1gb goodram cl5 ddr800 i radi u dc i ta vista mi radi i stabilnije i bolje od xp-a sp2
Staro 27.12.2007., 18:54   #6
Vuco
Vuco's Avatar
Postovi: 9,505
Autor Mihael Pregled postova
Ma, kad radi - radi odlično koliko god trebalo i ne čini se uopće lošim OS-om . Ali ako od prvog trenutka počne zezat, onda te ubije u pojam, opako.
Nevezano sada za tvoj post, rekao je da neće OC-at, tako da ne vidim ćemu kupovati nešta više od najjeftinijeg x2 i memorije koja ide na 667 ili 800 pošto se onda može sa djeliteljem dignuti na toliko. Mada se razlika neće niti vidjeti, radila ona na 667, ako se slučajno zalomi Kingmax koji neće ići kao 95% ostalih (koji idu i preko 900 bez problema)
Staro 27.12.2007., 23:13   #7
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Aha.
Moze malo konkretnije; kao DannyHR.
Ime modela npr.
Bit ce definitivno 4x1gb Kingmax dr2 800 i 5600 x2. Pa ono; koja je najbolja MB do 500kn.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.12.2007., 23:24   #8
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
MB Gigabyte M55S-S3, sAM2, nVidia NF550, FW, GLAN, ATX531,98
MB Gigabyte M56S-S3, sAM2, nVidia NF560, FW, GLAN, ATX469,40
Pogledaj si ove dvije.
Ja imam ovu prvu, ova druga je novija.
Staro 28.12.2007., 01:59   #9
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Evo Miha ti je rekel sve,,uzmi jednu od tih dvije i imaš super ploču, prva ti je ak misliš OC, a druga je novija i malo manje moreš klokat zbog "gljupog" northbridgea tj. pasivca na njemu!!! Al ja imam drugu ploču i mogu reći samo dobro. Bolju za tu cijenu nebuš našel, i u ADM-u ti je oko 330kn, pogledaj si još.!! www.adm.hr
danc00 je offline   Reply With Quote
Staro 28.12.2007., 04:51   #10
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Obje ploče podržavaju AM2+ odnosno Phenom procesore.
Ova M56s je možda i bolja ako imaš više PCI uređaja jer ima 4 slota, dok m55 ima 2.
http://www.gigabyte.com.hr/Products/...ProductID=2607
Staro 28.12.2007., 13:36   #11
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Hvala na odgovorima.
A sto kazete na:
Gigabyte MA69G-S3H, AMD 690G, S. AM2, 4 x Serial ATA II - 485kn ADM?
Nije li ta bolja i novija o spomenutih?
Ne ponasa se dobro u visti?
I jos jedna stvar, imaju li te maticne 2xLAN?
Koje imaju? Nije nuzno, ali je dobrodoslo.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 28.12.2007., 14:01   #12
Postovi: 34,046
Nijedna od navedenih ploča nema 2xLAN. Dapače, malo današnjih ploča to ima, a ako i imaju koštaju previše.
Ova Gb je odličan izbor. Imaš na ovom podforumu poveliki članak o njoj pa baci oko.
Staro 28.12.2007., 14:03   #13
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor estugarda Pregled postova
A sto kazete na:
Ova ti ima itegriranu grafičku pa sad neznam kolko to tebi treba a ak netreba onda je nemoj uzimat....al M56s-S3 je bolja!!! Da evo naveo ti je i sve kaj ima ova M56 ja sam zaboravil, i nema ni jedna od tih 2X LAN
