Postovi: 3
netgear dg834gtb modem
Kupila sam netgear router sa modemom i bežićnom mrežom ali ga ne mogu nikako natjerati na suradnju. iskon neću ni pokušati zvati mislim da nema smisla, svi znamo da nemogu pomoci, a niti ne znaju. Da li mi netko ovdje može pomoći? |
networking wannabe guru
Datum registracije: Sep 2002
Postovi: 1,001
pa ako napises sta si do sada pokusala, sto se desi da se nece spojit i sta nemozes natjerat na suradnju sa njim, mozda i mozemo pomoci
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb. Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon. "Now I have become death, the destroyer of worlds who has come to annihilate everyone." |
Postovi: 23,502
Ako se radi baš o Iskonovoj mreži onda ti treba netko tko je također na njihovoj mreži da bi ti mogao pomoći. Treba vidit postavke koje rade. |
Postovi: 3
Mo -->
Internet IP Address: -Get Dinamically from ISP <-- kad je ova ukljucena ne moze sam okriti postavke -Use static IP address --> IP address 192.168.0.1 --> IP subnet mask: 255.255.255.0 --> gateway ip address: 89.164.32.1 - Use IP overATM (IPoA) <-- ovu valjda ne koristimo Domain Name Server address: - Get automatically from ISP <-- na ovom opet ne radi - Use these dns servers: 213.191.128.8 i 213.191.128.9 NAT: enable Router MAC address: Use Computer MAC address 2. ADSL settings Multiplexing method: LLC-based VPI:0 VCI: 33 3. LAN IP setup LAN TCP/IP setup: - IP Address: 192.168.0.2 - ip subnet : 255.255.255.0 - rip direction: none rip version: RIP-1 Use router as DHCP server: -starting: 192.168.0.3 - ending: 192.168.0.254 to je to. ispričavam se, nekad znam biti malo šašava.
ima prvi ekran zove se basic settings: Does your internet connection require a login? -->Mo Internet IP Address: -Get Dinamically from ISP <-- kad je ova ukljucena ne moze sam okriti postavke -Use static IP address --> IP address 192.168.0.1 --> IP subnet mask: 255.255.255.0 --> gateway ip address: 89.164.32.1 - Use IP overATM (IPoA) <-- ovu valjda ne koristimo Domain Name Server address: - Get automatically from ISP <-- na ovom opet ne radi - Use these dns servers: 213.191.128.8 i 213.191.128.9 NAT: enable Router MAC address: Use Computer MAC address 2. ADSL settings Multiplexing method: LLC-based VPI:0 VCI: 33 3. LAN IP setup LAN TCP/IP setup: - IP Address: 192.168.0.2 - ip subnet : 255.255.255.0 - rip direction: none rip version: RIP-1 Use router as DHCP server: -starting: 192.168.0.3 - ending: 192.168.0.254 to je to. |
Postovi: 1,001
prvo što bi trebalo učiniti je provjeriti da li je tvoj primjerak tog routera ADSL Annex A ili Annex B verzija, te provjeriti koji od ta dva standarda koristi Iskon, vjerojatno tu informaciju možeš naći negdje na ISP podforumu ili ovdje, upotri***i search funkciju nakon toga bi trebala saznat koje ti je korisničko ime i lozinka za pristup Internetu, tu informaciju si trebala dobiti od Iskona, ako nisi, nazovi i pitaj evo, to dvoje odradi, pa cemo dalje
Postovi: 3
problem riješen nakon 20min tehničke podrške ve-mila i još nekoliko szk iskon. Iskon je annex b. problemi su bili u dns-ovima. usput, ovako izgleda 8mbitna veza na iskonu u 9navečer |
