#32 |
Lokacija: negdje
Postovi: 1,798
Kakav bi bio Centurion 534 ? |
#34 |
waiting waiting waiting
Lokacija: Okolica Samobora
Postovi: 57
šarkoon rebel je jako dobro kučšte
GET SMOKED |
#35 |
Torrent freek
Postovi: 3,949
#36 |
In the ghetto
Postovi: 1,943
Znaci ovo je samo prijedlog i moje misljenje o kucistima na nasem trzistu. Ovo je samo ko pomoc onima koji neznaju kaj bi uzeli. Pri tome ne ulaze u obzir kucista koje imaju po defoultu ugrađeno napajanje. Kucista po cijeni: do 200 kn: - Aplus CS-185A - 200kn (Links, ADM) do 350 kn: - Chieftec SG-01B - 280kn (ADM) - THERMALTAKE Mambo VC2000BNS - 315kn (ADM) - CHIEFTEC DG-01BD-UW, MIDI Dragon - 320kn (Links) - COOLERMASTER Elite 333, RC-333 - 325kn (Links) - Gigabyte mid tower GZ-X2BPD-100 - 333kn (Vemil) - SHARKOON Rebel9 Economy-Edition - 350kn (ADM) do 500 kn: - Cooler Master, Centurion 534 - 360kn (Feniks) - ANTEC NSK4000 - 425kn (ADM) - ANTEC NSK6000 - 435kn (Optimum) - Cooler Master, Centurion 5 - 435kn (ADM) - Chieftec mediumtower LBX-02B-B-B - 490kn (Vemil) - Chieftec mediumtower LCX-01B-B-SL - 490kn (ADM) do 700 kn: - Chieftec mediumtower LCX-01SL-SL-B - 540kn (Vemil) - Coolermaster CM 690 - 550kn (ADM) - Chieftec Big tower BA-02B-B-B - 550kn (ADM) - Chieftec midi tower Aegis CH-05B-B -570kn (Vemil) - CoolerMaster CM 690, prozirna stranica - 590kn (Feniks) - ANTEC SOLO - 660kn (ADM) - NZXT Hush, crno, MIDI - 660kn (Links) - Cooler Master, Mystique 632S - 715kn (Feniks) do 1000kn: - Gigabyte mid tower GZ-FSCA1-ATB (3D AURORA) - 800kn (Diskont24) - SILVERSTONE Temjin TJ04 - 900kn (Hgspot) - ANTEC NINE HUNDRED-EU (Gamer case) - 840kn (ADM) - ANTEC P182 EU (gun metal-crno) - 1040kn (ADM) Naravno da su dopune vase i moje prijeko potrebne. Znam da ima i gresaka pa slobodno dopunite i upozorite. Vecinu kucista sam vidio uzivo ali ipak tu ostaje i stvar subjektivnog dojma - nekom se nesto svidja a nekome ne.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor Zadnje izmijenjeno od: elvis again. 24.01.2008. u 01:49. |
#37 |
Chaotic
Postovi: 212
Vidim da nisi stavio Silverstone i Lian Li kućišta u popis što je zbilja šteta pošto su veoma kvalitetna. Recimo Silverstone Temjin TJ02/04 ili Lian Li PC-7B možeš slobodno staviti među modele do 1000kn. |
#38 |
In the ghetto
Postovi: 1,943
Nisam ali s nijima stvarno nemam iskustava niti sam ih vidio uzivo a ni usmena predaja o njima nije do mene dosla. Inace znam da su Lian li jako kvalitetna ali ona ipak doalze samo ako ih se posebno naruci. Nekak mi se cine ipak previse za obicnog korisnika. Slobodno ti dopisi svoju tabilicu sa cjenama i ducanima pa cemo vec to nekak spojit. Edit evo stavil sam ti jednog SILVERSTONE Temjin TJ04 da nebus tuzan (po review-uima vidim da je dobro kuciste)
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor Zadnje izmijenjeno od: elvis again. 19.11.2007. u 22:24. |
#39 | ||
Chaotic
Postovi: 212
![]() P.S. Baš za to kućište imaš review i na PC Ekspert-u, a ima review-a i za par malo starijih (1, 2) Lian Li modela. |
#40 |
Postovi: 12
Jel se može ovaj popis stavit u zasebnu temu? Ja bi još dodao (makar ga nisam vidio u živo) Gigabyte 3D AURORA 797kn (Diskont24), potpuno aluminijsko kućište, ima zbilja odlične recenzije po netu |
#41 |
In the ghetto
Postovi: 1,943
To pitaj moderatore. Iako sumnjam jer to nije za nesto sto ce bit tako duze vremena vec je samo trenutno stanje stvari na trzistu i mog skromnog misljenja.
#42 |
Lokacija: Vz - Zg
Postovi: 2,930
evo jos jednog prijedloga, ja sam ostao odusevljen kad sam vidio to kuciste. Zbog samog izgleda ga nebi kupio, vec bi uzeo prije cm 690 rc, ali kuciste kao kuciste je skroz fora i ima ga u raznim bojama (+solidni reviewi): NZXT Apollo - 660kn
#43 |
In the ghetto
Postovi: 1,943
Evo malo sam updejtal listu po vasim prijedlozima (Linan Li ipak nisam stavil -ako neko bas hoce ima ih u linksu).
#45 |
In the ghetto
Postovi: 1,943
Evo do 400kn ovo se cini ko najbolja kupnja ali ima mjesta samo za 3x120 veta: http://www.adm.hr/product_info.php?c...oducts_id=3825 tu imas i jeden od "novijih" review-a iz 2006: http://reviews.pcapex.com/cases/cool...4_atx_case.php Ovo je također jako tiho kuciste i ima mjesta za 3x120 venta: http://optimum-online.hr/shop/view_p...roduct=1702143
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor Zadnje izmijenjeno od: elvis again. 21.11.2007. u 21:36. |
#46 | |
Postovi: 306
#47 | |
The mighty pirate
Lokacija: London
Postovi: 9,132
#48 | |
In the ghetto
Postovi: 1,943
http://www.links.co.jp/html/press2/nsk66002.jpg http://www.thequietrevolution.ca/qui...0/IMG_6369.JPG http://www.mypoweris.com/image/produ...000_case13.jpg http://www.links.co.jp/html/press2/nsk66001.jpg
#49 |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Isto kao i 1v@n i ja sam morao skužiti da jedan 120mm na isohu nije dosta za hlađenje moje 6800 ultra peče mi se memorija na grafi kad zatvorim case iako je moddan da ima 120mm ispuh (originalnih 2x80mm neću niti razmatrati posebno ne kad se tišina gleda) jer moraš jaaako navit ventove ako ti je case zatvoren da se ne pregrijava u full loadu, a to meni jaaako smeta, ja nisam jako uber osjetljiv pa da mjenjam default ventove na zalmanima ali sam ipak dovoljno osjetljiv da im ne dajem nikako preko 7V a preferrabilno je da je 5V i zato treba puno ventova koji su spori a ne jedan koji se vrti ko mutav...
-- Have a nice day... |
#50 | |
In the ghetto
Postovi: 1,943
Npr. GigaByte 3D Aurora: http://www.cluboverclocker.com/revie...rora/page3.htm i Chieftec BA-02B-B-B:
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor Zadnje izmijenjeno od: elvis again. 22.11.2007. u 12:13. |
#51 |
Postovi: 6,956
Jesus a Antec Nine Hundred ili RJ690 ih imaju kolko ono? Aha jedno ima 120 + 200 mm (to je ekvivalent 2 komada od 120mm IMHO) dakle 3 + jedan ako baš treba na stranici se može stavit za ispuh, a Coolermaster ima 3 komada 120/140 mjesta za isuh iza + gore, a mogu se isto i oni na stranici tako okrenuti ako baš treba dakle još 2 iliti - ukupno 5 mjesta za 120/140 - tolko o tome kako nema caseova sa 120mm isuphom u množini...
#52 |
In the ghetto
Postovi: 1,943
Da ali oni imaju po jedan 120 vent na bacak panelu a 200 onosno 2x140 na vrhu kucista. Nebi znal koje je bolje rjesenje ![]()
#53 |
Postovi: 6,956
A daj ti meni objasni u čemu ti je to točno razlika dali imao na vrhu casea montirane ventilatore ili ti je PSU na pola casea iznad matične a iznad njega je praznina u kanti u kojoj je iza na back panelu jedan 120mm ventilator?
#54 |
In the ghetto
Postovi: 1,943
Pa u smjeru strujanja zraka kroz kuciste. A mozda to stvarno i nije bitno?
#55 |
Postovi: 6,956
Aha dakle ako zrak ide oko PSUa pa gore na vrh, da bi opet došao u veliku praznu šupljinu na vrhu i išao natrag van to je dakle bolje rješenje nego ako jednostavno izlazi ravno gore???
#56 |
In the ghetto
Postovi: 1,943
Neznam kaj bi ti rekel. Je ti sad mene prozivas ili? Rekel sam da nemam pojma koje je bolje rjesenje jer sam i sam u potrazi za odgovarajucim kucistem.
#57 |
Postovi: 6,956
Ne ne prozivam te - poanta je da je svejedno dal je gore rupčaga pa ventilator koji ide iza ispuhivati ili jednostavno odma ventilatori koji ispuhuju van... ![]()
#58 |
In the ghetto
Postovi: 1,943
I jesi se ti vec odlucil koje ces uzet?
#59 |
The mighty pirate
Lokacija: London
Postovi: 9,132
Meni se zasad CM690 čini kao najbolji izbor, nabavi se tih 7 ventova i krene gledat kod kakve konfiguracije se sve uspije lijepo ohladiti. Uzeo bih ga ja odmah da ne moram prvo ovo prodat, ah brzopletost i vjerovanje slinim reviewima na kojima je dobivalo 5/5. |
#60 |
Postovi: 6,956
Odlučio sam se ja odavno bit će Coolermaster 690 ziher čim se vratim u ZG (to će bit za kojih tjedan-dva) idem po njega jer neću niti nosit natrag u ZG ovaj šrotcase rastavit ću stroj i odnjeti elektroniku, diskove i ostalo u ZG i tamo ću složit sve odma u novi case, ako nebude bilo onih sharkoona s uzet ću coolermastere ili zalmane pa stavit na 5 odnosno 7V (ovisno o modelu) i to je to, zapravo možda probam prvo sa "stock" postavom ventova čisto da vidim kako se u toj izvedbi ponaša, jedino neznam dal da uzmem onaj s prozorom ili bez jer zapravo nisam siguran da je ona rupetina iznad proca baš pretjerano korisna za moj postav hlađenja kojeg planiram...
