Staro 21.11.2007., 00:35   #1
zmajri
Rugby a way of life
zmajri's Avatar
Postovi: 65
low budget kanta cca 2k kn
sta mislite....
svi komentari su dobro dosli....
MBO ABIT AN52 nForce 520, DDR2, zvuk, G-LAN, S-ATA Raid, PCI-E, s. AM2 .....400kn
http://www.links.hr/index.php?naziv=...kl=050.303.296
CPU AMD Athlon64 X2 4000+ BOX, s. AM2, Brisbane, 2.1GHz, 1MB c., HTT 2000MHz ......455kn
http://www.links.hr/index.php?naziv=...kl=050.603.120
RAM PC-6400, 1 GB, KINGMAX, DDR2 800 MHz .....180kn
http://www.links.hr/index.php?naziv=...kl=051.207.053
HDD 160.0 GB SEAGATE, SATA, 8MB c., 7200 okr/min .....396kn
http://www.links.hr/index.php?naziv=...kl=051.510.005
VGA PCI-E SAPPHIRE ATI RADEON HD2600 PRO, 256MB DDR2, DVI, TV .....558kn
http://www.links.hr/index.php?naziv=...kl=051.806.260
Kućište FRONTIER Luster LU09A-BK/IBK, crno, 400W ATX2 .....280kn
http://www.links.hr/index.php?naziv=...kl=052.603.024
total: 2269kn
sad pitanja...dali je to to???
optiku i periferiju imam doma tako da netreba....
sad dali vrijedi razlika izmedu 2600pro i 2600xt tih 200tinjak kn???
najcesce ce se koristit za multimediju uz povremeno igranje....
od polovnog sam odustao jer jednostavno nemoze se nista pametno nac ali ako imate sta.....pm me
Zadnje izmijenjeno od: zmajri. 21.11.2007. u 00:37. Razlog: sitne izmjene
zmajri je offline   Reply With Quote
Staro 21.11.2007., 00:44   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Mozes razmislit i o intelu:
cpu - Procesor Intel Pentium Dual-Core E2140 , 1.6GHz, socket 775, 1Mb
mbo - Gigabyte P35-DS3L, s775, intel P35+ICH9, FSB 1333 4xsata gblan
ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5
hdd - HDD Samsung 160Gb SpinPoint, Serial ATA II, 8 MB cache, 7200 okr
psu - Napajanje FORTRON 350W, PNF, Super Silent, 12cm ventilator, ATX2
cas - Aplus CS-185A PC Case, w/o PSU, RoHS
vga - VGA Ati Radeon HD 2600 Pro, 256Mb DDR2, 128 bit, TV out, DVI
2.507,88Kn
Inace osobno nebi isel na to integrirano kuciste i napajanje mislim da je ovo gore navedeno puno bolje rjesenje a skuple je samo 100-injak kn.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 21.11.2007., 07:09   #3
zmajri
Rugby a way of life
zmajri's Avatar
Postovi: 65
sta nije bolji ipak amd za tu lovu....
dc na 2.1GHz a ovaj intelov 1.6
Staro 21.11.2007., 07:53   #4
Postovi: 33,983
Ako misliš uzeti AMD razmisli o Gigabyte MA690G-S3H (vemil). Isto tako, memorija ti je tamo jeftinija.
Staro 22.11.2007., 07:27   #5
zmajri
Rugby a way of life
zmajri's Avatar
Postovi: 65
sve isto osim sto cu stavit powercolor hd2600xt 256mb gddr4
i vjerovatno jos 1gigu rama
Staro 22.11.2007., 10:42   #6
elvis again
In the ghetto
Postovi: 1,943
Autor zmajri Pregled postova
Inace ovaj E2140 se puno bolje oc-a a na defoultu po performansama su tu negde mozda je amd mrvicu bolji.
Evo na koliko ide E2140:
http://valid.x86-secret.com/show_oc.php?id=262110 -rekli su decki stabilno
http://valid.x86-secret.com/show_oc.php?id=262487 -a ovo je vec bolestina
http://www.egielda.com.pl/?str=art&id=2906-6 -ovo su usporedbe oc-anih intela i amd-a na raznim testovima (je**** na poljskom su ali grafovi su bitni )
Staro 22.11.2007., 12:18   #7
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
da, budget kante se sklapaju bas zbog ekstremnih OCova....
konfa koju je slozio je ok. mogao bi jos usparati kunu vamo-tamo ali nije toga vrijedno.
ja bi recimo samo ubacio jos gigu rama. jeftin je a njega nikad viska.
Staro 22.11.2007., 13:01   #8
Postovi: 7,568
Autor elvis again Pregled postova
Bez clockanja se more slikat s tim E2140. Bome niti svaki kupac Intel procesora ne misli naclockavat, (kolko god je to teško za povjerovat) zadovoljni su ljudi i s tvorničkim taktovima. Svaki čitatelj Cosma koji drži do sebe zna da na defaultu E2140 i 4000+ X2 nisu tu negde, nego da je AMDov procesor bolji.
Staro 23.11.2007., 00:10   #9
zmajri
Rugby a way of life
zmajri's Avatar
Postovi: 65
nebi se to jako clockalo,eventualno nesto sitno....
konfa bi se najvise koristila za multimediju i eventualno igranje nekih naslova(rts freak )
Staro 23.11.2007., 13:03   #10
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
to "eventualno nesto sitno" je kod ovih intela na 3ghz kamo dodu bez da puste zrno znoja i rade jednako stabilno kao na pocetku, pa stoga vidi dal ces drzat na osnovnim vrijednostima ili ipak overclockat.
naravno i AMD je ok, ide i on nesto, al ne tolko bez muke.
sta god kupis od ponudenih neces ostat razocaran to budi uvjeren
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
