#841 |
P.E.B.K.A.C.
Postovi: 2,304
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
#842 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
auuu... danas sam prvi puž doživio da mi se procesor PREGRIJAO, i to nakon 20ak minuta igre, smrzne se igra, i to mi se desilo svaki put dosada. i sad odmah nakon što sam resetirao komp, uđem u windoze i idem pogledat temperaturu procesora, I? 73C nakon restrata, pa bio je sigurno na 90 stupnjeva ![]() ![]() ![]() |
#843 | |
1oo1 NooB
Postovi: 1,306
* Intel Pentium 4 2.4 GHz or AMD Athlon 64 2800+ processor or any 1.8Ghz Dual Core Processor or better supported * 512MB RAM (768MB for Windows Vista) * 8GB of free hard drive space * NVIDIA Geforce 6600 or better or ATI Radeon 9800Pro or better I ako samo to imaš sve na low i još malo štekanja i kašljucanja - osobito RAM i grafa.... PS ni ja nemam ni za crni kifl...... ![]()
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#845 |
P.E.B.K.A.C.
Postovi: 2,304
Pih ja nisam uspio na SLAVE-u to pokrenuti,,, hebena fx5200 a kazu meant to be played Nvidija... seronj*... Evo svjeze ispeceni SS: http://www.max-save.org/viewer.php?i...42shot0005.jpg ![]() Ipar slikica kak to slicno izgleda kao sa CNN-a: http://www.max-save.org/viewer.php?i...41shot0009.jpg http://www.max-save.org/viewer.php?i...62shot0010.jpg http://www.max-save.org/viewer.php?i...30shot0011.jpg http://www.max-save.org/viewer.php?i...35shot0013.jpg Pih nece na 125 da ga ubijes.. ![]()
#848 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
#850 |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
OK, lagano pizdim, zadnji puta sm abio jučer na serveru i sada s eželim spojit i obavijet. You have been temporaily banned from this server. DUMA,ET WTF???
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. ![]() Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
#851 |
Postovi: 2,458
Nisi jedini ..i adi ima isti problem i jos neki... trenutno pristup serveru ima samo duma pa moramo njega uhvatiti da vidi u cemu je problem |
#852 |
Lokacija: ----
Postovi: 107
Danas sam preso jedo 5-6 misia, i igra je odlicna,ima malih propusat u detaljima, al teksture sjene osvjeljenje i ostalo su savrseni! I za ove sto gledaju i govore za Procesor i RAM, to nisu najvazniji dijelovi za igrice, tu bitanu ulogu ima Graficka Kartica! I to kad ulozi te malo kuna ili eura vidjet cete rezultate!
#854 |
Strichek Moderator
Postovi: 9,343
Jel to neki žešći problem ili nije.... Kad mi je FSAA 2x imam 60-70FPSa a kad mi je isključen imam zabetoniranih 91FPS, istina igra mi izgleda ko da je 4 upaljen a ne 2, ali ako i je 2 kak mogu tak pasti FPSi?
žmnpp |
#855 |
Magister Mundi sum!
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
#858 | |
P.E.B.K.A.C.
Postovi: 2,304
![]() Inace ne koristim AA uopce samo mi zdere bezveze FPS-e, mislim sa AAx2 stoji na 125 ali neka bliza borba kada netko izleti ispred mene pa oba dvojica pocnemo rostiljati pada na nekin 70fps-a pa sam odhebo taj AA... Inace mi je na 1280x1024, iskljucen je AA, AF, smooth edges, vsync, dynamic lights ostalo sam ostavio na koliko moze i ide na zabetoniranih 125 ![]()
#859 |
Postovi: 50
...evo da kazem par stvari sto se tice hardwerskih zahtjeva.Pomocu moje konfe koju mozete vidjeti sa strane meni cod4 vuce sve na low 800x600 100-125fps.S 4xAA mi vuce 60-110,tako da se moze izvuci fpsa i na losijim kompjuterima bez problema,s obzirom da u ovoj igrici sve preko 30fps nije uopce lose za igranje.Cheers |
#861 |
P.E.B.K.A.C.
Postovi: 2,304
#863 |
P.E.B.K.A.C.
Postovi: 2,304
Ovisno kaj igras, za S&D je dovoljno kada se pegla 6 na 6.. Ali se ta razlika ugodnoga igranja COD4-ke drasticno mjenja kada uletis na TDM od 25-30 igraca... za to je minimum 50-60 fps-a ako nemislis se zaleci negdje i cekati da ti tko naleti..
#864 |
Lika u mom srcu
Postovi: 9,887
25-40 je onako minimum minimuma, nakon što sam primijetio da mi nema razlike u fps između LOW i HIGH postavki tekstura, te nakon što sam pogasi SVE (dynamic ligts, bla bla blur, ovo ono, znači sve off, ne mogu dobit preko 50. jedino ako stanem i gledam u pod ![]() |
#865 | |
Postovi: 527
#866 | |
Postovi: 12,602
Ovo. Citiraj:
#868 |
Lika u mom srcu
Postovi: 9,887
ja stavio, i igra radi normalno. no ja ionako nisam imao problema sa gubitkom rankinga, a ionako sam tek na 13... :8 iako me ti rankinzi užasno nerviraju, jer je praktički nemoguće ubit nekoga tko je daleko veći level od tebe, a da ne govorim koliko su muoružja jača, preciznija, manji reciol, brži pucaju (mislim ono, sačmara dere ko hebeni poluautomat) a ja kad sačmarom hoću igrat je ono, bam, pa onda 3 sekunde reload, pa opet bam... do tada me 7 puta ubiju... |
