Lokacija: ZG Dubrava
Postovi: 471
OC intel P4 Northwood,matsonic MS9147c
imam ovu konfu a memorija je SuperTalentCL2, 2 x 512 mb pa me zanima kolike su okvirno mogucnosti OC-a? cijela konfa: ---------------------------------------------------------------- CPU Type Intel Pentium 4 CPU Alias Northwood CPU Stepping B0 Engineering Sample No CPUID CPU Name Intel(R) Pentium(R) 4 CPU 1.80GHz CPUID Revision 00000F24h CPU Speed CPU Clock 1800.1 MHz (original: 1800 MHz) CPU Multiplier 18.0x CPU FSB 100.0 MHz (original: 100 MHz) Memory Bus 100.0 MHz DRAM:FSB Ratio 1:1 CPU Cache L1 Trace Cache 12K Instructions L1 Data Cache 8 KB L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed) Motherboard Properties Motherboard ID 62-0905-001131-00101111-040201-VIA_P6$MS9147C_MS9147C RELEASE 09/05/2002 Motherboard Name Matsonic MS9147C (4 PCI, 1 AGP, 1 CNR, 4 DIMM, Audio, LAN) Chipset Properties Motherboard Chipset VIA VT8753A Apollo P4X333 Memory Timings 2-3-3-5 (CL-RCD-RP-RAS) Command Rate (CR) 2T SPD Memory Modules DIMM1: Xerox MALABS 512 MB PC3200 DDR SDRAM (2.0-3-3-7 @ 200 MHz) DIMM2: Xerox MALABS 512 MB PC3200 DDR SDRAM (2.0-3-3-7 @ 200 MHz) BIOS Properties System BIOS Date 09/05/02 Video BIOS Date 03/09/04 DMI BIOS Version 07.00T Graphics Processor Properties Video Adapter Tul Radeon 9200 GPU Code Name RV280 (AGP 4x 1002 / 5961, Rev 01) GPU Clock 250 MHz (original: 250 MHz) Memory Clock 200 MHz (original: 200 MHz) -------------------------------------------------------- mbo chipset: VIA P4X266 (VT8753) southbridge:VIA VT 8235 sta ako na mbo promjenim jumper sa 100 na 133 MHz, sta bi dobio! |
Postovi: 471
evo promjenio jumpere sa 100 na 133 i sad radi na 2.4 GHZ memorija je sad 133, DRAM:FSB Ratio 1:1 znaci 33% dobio na brzini cpu-a i ddr-a temperatura je sad bez nekog opterecenja 33 jel to u redu jel bi se jos sta dalo dic gore? |
Postovi: 7,504
To sa jumperom je za minjanje FSB-a isto radi ko OC, ali mislim da ta matična što se tiče BIOS-a i svega ostaloga nije za OC. To znači ako je tako stabino i BIOS nema još nekih dodatnih opcija super, temperatura je u redu BTW zvrti Orthos ili SuperPI 32M pa onda vidi temperature! |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
to ti je to nemos vise nis sa tom maticnom . imao sam ju pa znam ![]()
Postovi: 471
vratio sam jumpere jer se stalno restartirao! jer se moze to izbjec pa da radi stabilno na 2.4 GHz mislim sa 1.8 na 2.4 je zadovoljavaju ci cloc s obzirom na mbo! codiac jel imas mozda manual od tog matsonica? |
Postovi: 8,236
matsonic MS9147c=> uštekaj u komad daske i bolje ćeš moći klokat neg na matsonicovoj ploči. Imao sam 2 i vjeruj ni jedna neide. Neznam kako tvoja al moja ms9307c nije ni imala p4 priključak, samo standardni atx. nije htjela ni mhz više. |
#7 | |
Laughing Man
Postovi: 3,041
Nije ni taj steping northija neka sreća za oc. Moj je na abitici is7 išao max na 2.8....
