#721 |
Postovi: 2,458
Igra ti je ili pogazila mpdata file ili si promjenio cd key... Nadi file mpdata i napravi backup ... u njemu su snimljeni leveli...nalazi se u folderu od igre ./players/profiles/ime/mpdata Svoj rank mozes prebacit i nekom drugom ako mu posaljes taj file ali on mora onda upisati isti cd key kao sto i ti imas Znaci cuvati rank = cuvati mpdata server automatski dodijeli ban na odredeno vrijeme (kako je podeseno) |
#722 |
Magister Mundi sum!
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Ak neko igra SP .. kad dojdete do kraja pustite da krediti prejdeju jer nakon toga imate još jednu misiju u avionu gde morate pokokati teroriste i spasiti VIP-a .. naravno avion celo vreme leti ![]()
#724 |
1oo1 NooB
Postovi: 1,306
Koliko će ti pomoči ali postoji cijeli problem sa time - puno ljudi je spušilo rankove. Regaj se na forum i pročitaj cijeli topic - link na kraju. 402 responded to this topic at iw.com... "Essentially here's how it works. If you are playing a Ranked server you will Rank up as normal. When you go to a Modded or Unranked server, your rank will be Level 1 and you will rank up independently of your Ranked server Rank. Those two ranks do not count towards each other and are unrelated. If you go back to the Ranked server, your Rank should be the same as it was when you left the Rank server the first time. So if you never played a ranked server, and only played modded servers and ranked up to 33 on a Modded server, then your Rank would still be Level 1 on the Ranked, because you haven't played Ranked. (this is all hypothetical) We have tested it here all day long and no one's stats have been reset from switching servers between Ranked and Unranked at all. Is anyone else experiencing this problem or want to test it out and report back more info then please do." Prenešeno sa RGN foruma - moraš se regat da vidiš sve. http://forums.raidersmerciless.com/s...ead.php?t=2334
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#725 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
postoje rankovi? znači, nešto kao leveliranje lika, ili kako to funkcionira? nisam još igrao pa ne znam, aj malo više detalja o tome.. da li ako imaš veći rank imaš prednost da možeš lika nadograditi sa boljim oružjima i sl. pa imaš prednost u multiplayeru u odnosu recimo na slabije igrače? , ili služi ničemu? |
#726 | |
Postovi: 527
#727 |
Strichek Moderator
Postovi: 9,344
Jučer navečer počeo igrat, na početku imaš izbor oružja koji je ok, ali kad ti dođe netko tko ima rank 30 a ti 1 on te preaktički odma ubije... Tak da je po meni to malo glupo, jer ja ispucam cijeli šanžer u nekog i njemu ništa a on par metaka na mene i naravno svi me pogode i bye bye..
žmnpp |
#728 | ||
Postovi: 2,458
znaci bolji level vise opcija, perkova i oruzja s kojima si mozes iskombinirati klasu ...no ako netko zna igrati moze jako dobro igrati i s osnovnim klasama...nece mozda relodati kao da je na steroidima il imati scope na nekoj puski al ce imati neke druge stvari... Citiraj:
#730 |
Postovi: 1,623
ja sam se prebacio aa lvl 17 na lvl 55 sa fileom ugl, dosta lagano je ubit bilokoga jer iam kewl perkove i premocnu pushkicu al opet sve se svodi na taktiku i skill nikakv puska ti nce pomoc ako ti neznas ciljat njome
#731 |
Postovi: 1,391
#733 |
Ultrabitchinfast
Postovi: 880
Pitanje: izbaci me van zbog punkbustera. naime tijekom instalacije ga nisam instaliral. moze se nekak client ubaciti u igru naknadno, jer ne mislim opet ponoviti instalaciju?
#735 |
Postovi: 1
Ovako. Novi sam ovdje na forumu, dobio sam preporuku od jednog člana. Imam jedan problem s CoD4. Instalirao sam ga, stavio najnoviji PB, directX 9.0c i nove drivere. Kada hoću pokrenuti SP, na sekundu mi se pojavi ona slika CoD 4 i onda mi je dalje sve normalne, zapravo neće mi pokrenuti igru. Kada pokrenem MP, pokrenem ga u 640x480 i ako stavim samo slijedeću rezoluciju, izbaci me iz igre i dobijem ovaj error. http://www.imagesforme.com/old/viewe...ntitled444.GIF Konfiguracija je: AMD Athlon 64 3000+ @ 1.81 GHz 1024MB DDR 400 GeForce 6600GT 128MB sa 163.75 Forceware Dajte hitno mi je, unaprijed hvala. ![]() |
#736 | |
sto da napisem ?!
Postovi: 880
kod mene se javlja isti problem ! samo meni bude po defoltu 800x600 ![]() |
#737 |
P.E.B.K.A.C.
Postovi: 2,304
Na COD4 dvd-u imas negdje DX9 pa ga pokreni i snimi poslije toga bi trebala raditi ![]()
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
#739 |
Avocado
Postovi: 7,856
evo odigro sam igru, mogu rec da mi je nekak prekratka... ali da cu opet na vecoj tezini prec, hocu. ona misija u gilly suit, sa snajperom, u chernobilu mi je najbolja, predobro kad se sakrijes u travi a protivnik 1 metar od tebe. moram pohvalit i muziku, predobra je, cak imaju i rap o cod-u na kraju... ![]()
Spoiler alert! |
#740 |
Lokacija: /
Postovi: 2,053
meni nisu problem rankovi itd. jer vidim da to nije mjerilo "jačine/snage" nego taktika...nego najveća zamjerka je kratkoća ![]() inače prešao i SP...černobil... ![]() ![]() |
#741 |
Postovi: 1,391
Ma meni se ne sviđaju pretrpane mape. Mape su dosta male a stavljaju na njih 32 igrača tako da je katastrofa... |
#743 |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
Ovako,prijatelj mi ima problema sa igranjem mp,naime im 6 fps :O ,a igrao je demo i imao je 40,50 naravno i manje,ali je igrivo bilo. Sad kako je nabavio full neide iznad 6 fps. Konfa je,p4 ,2.6mhz ,giga meme i x1650. |
#744 |
Postovi: 735
jel ima tko kakvu pouzdanu informaciju o tome dal se može pokrenuti igra na procu XP Barton, ostatak konfe je u MOJ KOMP pitam jer nigdije nemogu nać informaciju dal treba za tu igru SS2 instrukcija na procu ili ne ![]() |
#745 | |
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
![]() .. a ja imam komp sličan ovome kaj si ti navel jedino mi je proc klokan na cca 3.1 i imam x1650PRO .. i u MP-u imam cca 70FPS-a .. nisam preveč prtljal po postavkama za sad ali uglavnom je ovak 1024X768 , 2xAA , sve na medimu ili ti normal .. čak sam se iznenadil jer sam očekival da bum imal max kakvih 40 FPS-a međutim da je ova grafička sad več low-med segment nekakav ![]()
#746 | |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
#748 |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
ja sam i dalje oduševljen sa snagom svoje x1950st, celo vreme je na 2d taktovim ai unatoč tom mam 70-90fps na1280×1024@100. More bit da ulogu ihgra 2 gige rama i opty na 2,9ghz ![]() ![]()
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. ![]() Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
#749 |
P.E.B.K.A.C.
Postovi: 2,304
U i ja je odigrah... MP... hmmmmm neznam nesto mi fali ![]() Nema puskica ![]()
