Staro 29.07.2007., 15:08   #151
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
A što ako hoću imati password na svom accountu?
frANZi je offline   Reply With Quote
Staro 29.07.2007., 15:47   #152
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
pa onda tak i tak moras vidjet onaj log-on screen od windowsa, sta ti smeta sta ima jos par imena na njemu : )
a mozes i namjestit password u BIOS-u pa ce ti se on pojavljivat cim upalis komp
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 29.07.2007., 20:08   #153
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
E pa neću. Najlakše ići linijom manjeg otpora.
Staro 01.08.2007., 00:43   #154
mighty
mighty's Avatar
Postovi: 519
može pomoć?
očajan sam više...
situacija je ovakva...
komp: IP 192.168.0.1
subnet 255.255.255.0
laptop: IP 192.168.0.2
default gateway 192.168.0.1
situacija sljedeća... laptop samo šalje... komp samo prima...
obratno ne ide nikako...
što da radim?
mighty je offline   Reply With Quote
Staro 01.08.2007., 00:50   #155
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,948
Firewall ?
Koji OS ?
Jesi napravio usere i dodjelio im password ?
Jel spajaš preko switca ili izravno ?
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 01.08.2007., 00:55   #156
mighty
mighty's Avatar
Postovi: 519
isključen firewall...
win xp oba... sp 2
izravno spajam...
upio sam ga spojit preko mrežne na koju mi je modem spojen...
ali sad kad sam prebacio na kompu na drugu mrežnu (ploča, gigabitna) ne radi...
Staro 01.08.2007., 17:12   #157
hakaa
Lokacija: tamo gdje je dom
Postovi: 31
Samo nešto...
Rak reče:
Sada dolazimo do moje najomraženije teme. Dijeljenje interneta ili Internet connection sharing je nešto što bi svaki korisnik male mreže htio imati i ne shvaća da je to vrlo opasno za njegovu mrežu.
Zasto je to toliko opasno i jel se šta promjenilo zadnjih 3 god.?
hakaa je offline   Reply With Quote
Staro 01.08.2007., 17:18   #158
Mr.Ex.President
Torrent freek
Postovi: 3,948
Autor mighty Pregled postova
Vjerovatno je onda problem s tom mrežnom
Autor hakaa Pregled postova
Samo nešto...
Ma nije to toliko opasno, pogotovo sad u doba ADSL-a i ako znaš šta činiš
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 03.08.2007., 14:27   #159
MAXx
Čupavac
MAXx's Avatar
Postovi: 261
Imam komp sa vise mreznih kartica kako umreziti jos jedan komp i laptop na njega. OS je Win Xp na svima. Koje kablove moram korstiti dali patch ili crossover
MAXx je offline   Reply With Quote
Staro 17.08.2007., 12:04   #160
pitagoraxp
Postovi: 2
može pomoć?
očajan sam više...
što da radim?
Postavi na kompu da ti je gateway ip od laptopa
pitagoraxp je offline   Reply With Quote
Staro 26.08.2007., 16:46   #161
TXS
TXS
TXS's Avatar
Lokacija: CRO
Postovi: 125
evo ja pokuso kak pise al nest nevalja al mislim da je do toga sto sam pokuso umrezit XP i Win98 pa neznam jel kad tak radis ide na drugaciji nacin
TXS je offline   Reply With Quote
Staro 28.08.2007., 14:15   #162
Xan
Xan's Avatar
Postovi: 1,001
hmm, moze malo detalja?
Staro 06.09.2007., 22:37   #163
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Evo da i ja uletim s jednim pitanjcem. Situacija:
a) ADSL modem spojen mrežnim na switch (IP 192.168.1.100)
b) svi kompovi spojeni preko switcha (IP 192.168.1.1, 1.2, 1.3, etc)
c) jedan server 2003 konfiguriran kao Domain server (IP 192.168.1.99)
d) svim kompovima je Gateway server znači 192.168.1.99
e) serveru je Gateway ADSL modem znači 192.168.1.100
Niti na jednom kompu NE radi internet kada im je gateway server....WTF?!?! Jel treba nešto dodatno uključiti? Ne da mi se baš definirati Remote Access & Routing na serveru. Firewall na serveru je off za LAN (ionako zabranjujem pristup mreži po MAC adresi). Eh da, kad kompovima stavim Gateway od ADSL-a tada sve radi. Meni je poanta napraviti da bez servera ne radi ni internet. Imate ideje?
Thnx.
PS: Na routeru sam podesio "Connect on demand" i kad ga disconnectam te pokušam surfati ne spoji se. Moram se spojiti na router i kliknuti na connect. Uf?
EDIT: Ovo u crvenom sam riješio...dovoljno je na serveru uključiti Routing and Remote Access i sve je proradilo...ma bilo je kasno nije mi se dalo misliti. Ostaje pitanje Connect on demand.
Case: ThermalTake Shark VA7000BWA -> ulaz: 1x120mm BlueLed izlaz: 1x120mm BlueLed
PSU: Corsair CX-750M Modular @ Blazer UPS 600VA
MBO: Gigabyte GA990FXA-D3
CPU: AMD FX 6100 Black Edition @ 3300 MHz -> cooler: Scythe Zipang 2
RAM: 4x 4GB Corsair XMS3 1600MHz
VGA: Sapphire HD7870 2GB GDDR5 GHz Edition
HDD: Patriot Pyro SSD 120GB
HDD: Seagate 1TB SGT-ST1000DM003 SATA 6
DVD±RW: LD DVDRW
DVD±RW: LG BlueRay BE06LU10
I/O units
Monitor: LG 25UM58-P 21:9 IPS LED
Keyboard & Mouse: Logitech MK710
Sound: Vivax HT-100 5.1
Headphones: Trust 640-U
Printer: Canon Pixma MX475
Zadnje izmijenjeno od: Racker_CRO. 07.09.2007. u 18:29.
Racker_CRO je offline   Reply With Quote
Staro 07.11.2007., 12:43   #164
Matija1312
Matija1312's Avatar
Lokacija: Cro
Postovi: 21
pozdrav svima.
Na poslu imam dva kompa u mrezi, koja su radila savrseno dok mi nije naredjeno da acaunti na kompovima moraju imati sifre.
Prilikom stavljanja sifri na glavnom kompu su zakljucani svi podaci, tako da ja sa svoga nemogu doci do njih.
Probao sam sve, mjenjao worgrupu, radi izpocetka mrezu i sve postavke, ponovo šerao sve diskove i sam neznam sta vise.
Mislim da je probem u ovome:
http://img452.imageshack.us/my.php?image=problemiu6.jpg
Kada bi mi netko mogao reci kako to odkljucati bio bih vam jako zahvalan.
I stvarno vas molim ako se mozete potruditi stvarno mi je bitno!!
Unaprijed se svima Vama zahvaljujem i pozdravljam Vas.
Matija
Matija1312 je offline   Reply With Quote
Staro 07.11.2007., 12:46   #165
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Kao prvo pod Folder Options si isključi Use Simple file Sharing pa onda share na neki folder te mu dodjeli usere koji imaju pravo pristupa. To bi trebalo raditi.
DVD±RW: LD DVDRW
I/O units
Staro 07.11.2007., 13:52   #166
Matija1312
Matija1312's Avatar
Lokacija: Cro
Postovi: 21
nisam uspio ovom tvojom metodom.
Vratio sam sys. restore na jucerasnji dan.
Stanje se popravilo. Imam veci pristup glavnom racunalu, ali mi i dalje odbija dati pristup my documentsu (u kojemu se nalaze svi potrebni mi dokumenti za rad) i one word i excel dokumente sto imam pristup nemogu otvoriti jel kaze da nemam pravo pristupa.
Staro 07.11.2007., 13:56   #167
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Autor Matija1312 Pregled postova
Čekaj, gdje se nalaze ti my docsi? Na serveru ili na lokalnom računalu? Ako su na serveru tada je normalno da nemaš pristupa my docu sa drugog računala...eventualno preko admin share-a \\ime servera\c$ a ako su lokalno trebao bi imati pristup jedino ako nisi mijenao usera ili komp dodao na domenu (isti slučaj kao da si mijenjao usera). Tada bi trebao preuzeti Ownership ili se logirati kao stari user pa te dokumente negdje prebaciti. Daj još malo podataka....teško je ovako.
DVD±RW: LD DVDRW
I/O units
Staro 07.11.2007., 16:21   #168
Matija1312
Matija1312's Avatar
Lokacija: Cro
Postovi: 21
Da objasnimi situaciju.
U uredu je bio jedan komp, sa userom=admin(standardbno kada se inst. win).
Svi podaci (obcno su to word., exc. i pdf. podaci) se spremaju u my doc/desktop i odatle se otvaraju po potrebi.
Tada se kupuje jos jedno racunal. Spajam ih u lan, pravim workgrupu, dodjelim IP adrese, šeram diskove itd.
Sve to radi, znaci sa toga novoga kompjutera sam mogao na starome otvarati cijeli my doc, otvarati sta zelim sa desktpa itd. Misam mogao jedino u program files i win, ali za to nije bilo ni potrebe.
Sve je to radilo do danas, dok tajnica nije htjela da se na acaunte stavi sifra.
Prilikom stavljanja sifre pita vas se zelite li zakljucati osobne dokumente da vam nemogu do njih doci iz mreze, i naravno kliknuto je YES.
Tako da ja vise sa svoga (novoga) kompa nemogu doci do my doc. i otvoriti niti jedan word, excel i pdf format.
Da nebude tako sve crno, taj problem se javlja samo na C disku, dok na D disku mogu raditi sta zelim.
Mozda bi se dalo to rjesiti kada bi napravio novog usera ili instalirao nanovo win.
Ali moram uzeti u obzir da je tajnica starija gospođa i da svaka promjena bi me stajala mogo zivaca u objasnjavanju, stoga to moram napraviti kako je bilo.
POMOZI MI, MOLIM TE......
Staro 07.11.2007., 16:25   #169
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Sad je jasnije! Ja sam isti takav problem doma riješio ovako:
Na kompu na kojem se nalaze dokumetni kojima želiš pristupiti kreiraj usera koji se zove ISTO kao na računalu SA kojeg pristupaš (mora imati i istu lozinku), daj mu prava admina i to bi trebalo raditi. S obzirom da nema domene XP radi autorizaciju po userima, na ovaj način ti autoriziraš usera drugog računala na ovom računalo kao admina (mora biti ista workgroupa). Tako sam ja riješio problem...ako netko ima bolju ideju slobodno.
Javi jel radi .
Pozdrav.
DVD±RW: LD DVDRW
I/O units
Staro 07.11.2007., 17:37   #170
Matija1312
Matija1312's Avatar
Lokacija: Cro
Postovi: 21
Ovako,
Napravio sam novog usera sa svim postavkama.
Probao sam sa pasvordima i bez pasvorda.
Naravno nista od toga.
Hvala ti prijetelju na trudu.
Staro 07.11.2007., 20:51   #171
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Ajmo ovako. Imaš SERVER koji na sebi ima dokumente i imaš KLIJENT pc koji tim dokumentima pristupa.
Mreža je običan LAN, workgroupe.
Naziv workgroupe = WORK1
Naziv servera = SERVER1
User na serveru = MIRKO
Pass usera mirko= MKO11
Naziv klijenta = KLIJENT1
User na klijento= SLAVKO
Pass usera slavko= RKO22
E sad, na SERVER1 pod Users u Computer managementu kreiraš usera pod nazivom SLAVKO sa passom RKO22. Na KLIJENT1 na isti način kreiraš usera MIRKO sa passom MKO11. Oba usera su u admin grupi. Na SERVER1 i KLIJENT1 ISKLJUČIŠ Simple File Sharing pod Folder Options. Na koji način pristupaš My docsima.....pa u run probaj upisati \\SERVER1\C$\Documents and Settings\MIRKO\My Documents (ili Mirko's Documents). Bolji način je da na KLIJENT1 mappiraš disk...Normalno podrazumjeva se da su oba ručnala u istom segmentu LAN-a (znači npr. SERVER1 ima adresu 192.155.0.1 a KLIJENT1 192.155.0.2 a Subnet je 255.255.254.0).
Prije 10 min sam doma na dva laptopa simulirao ovaj primjer i sve je radilo kao urica. Oba lapa su čiste instalacije sa različitim userima...
Eh, mi ovdje govorimo o XP računalima, jel da?
EDIT: Ako ti ne radi \\SERVER1\C$ bla bla probaj sa \\IP ADRESA SERVERA1\C$
DVD±RW: LD DVDRW
I/O units
Staro 07.11.2007., 23:56   #172
Matija1312
Matija1312's Avatar
Lokacija: Cro
Postovi: 21
jedno noob-ovsko pitanje.
Jel moze to sve raditi ako nekoristim pass na userima??
Staro 08.11.2007., 08:37   #173
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Meni nije radilo bez passa. Uporno me tražio username i password kod pristupa pa sam stavio passworde i sve 5.
DVD±RW: LD DVDRW
I/O units
Staro 10.11.2007., 13:21   #174
Matija1312
Matija1312's Avatar
Lokacija: Cro
Postovi: 21
Rjeseno.
Radi ko sat
Hvala ti
Staro 12.11.2007., 15:13   #175
Racker_CRO
Silent killer
Racker_CRO's Avatar
Postovi: 181
Rjeseno.
Radi ko sat
Hvala ti
No frks, bitno da radi.
DVD±RW: LD DVDRW
I/O units
Staro 20.11.2007., 22:06   #176
doc-ktor
Postovi: 3
Imam ovakav problemčić. Imam računalo koje ima dvije mrežne kartice (NIC). Jedna kartica je preko switcha spojena u mrežu sa još dva računala (workgroup:mshome). Ta mreaa nema pristup internetu. Druga kartica je je preko ADSL modem/routera spojena na internet i u mrezu s jednim kompjuterom (workgroup: WORKGROUP). Dakle računalo je simultano spojeno na dvije mreže. Na internet mogu ali mrežu (odnosno računala u mreži) koja je spojena preko switcha uopće ne vidim, niti računala na toj mreži vide mene. Dakle negdje je pitanje kako konfigurirati racunalo da bude simultano na dvije mreze (ako jasno ima dvije mrežne kartice). OS je winXP
Zadnje izmijenjeno od: doc-ktor. 20.11.2007. u 22:36.
doc-ktor je offline   Reply With Quote
Staro 20.11.2007., 22:47   #177
jurbAs
jurbAs's Avatar
Postovi: 2,583
probaj staviti da su iste workgrupe.... hmm makar to sa time nema veze... probaj pingat racunala u obje mreze pa da vidis... jer ako ti ping prolazi onda te zezaju workgrupe...
ako ti ne prode ping stavi racunala u odvojene subnete tj ruter i switch
Staro 20.11.2007., 22:52   #178
doc-ktor
Postovi: 3
Prvobitno su bile iste workgrupe, a moje racunalo je vidjelo samo racunalo vezano preko ADSL modem/routera, a mrezu vezanu preko switcha nije vidjelo. No moram reci da su me tada druga racunala iz te mreze vidjela. Ja njih nisam, oni mene jesu.
Staro 24.12.2007., 16:44   #179
speedy051
Lokacija: aaaaaa
Postovi: 63
Evo spojio sam 2 kompa crossover kabelom, sljijedio lijepo sve vaše upute, premda mi je to od prije poznato... isključio simple file sharing... al idalje kad pingam kaže request timed out. U work group computers malo svaki nađe samo sebe, malo nađe i drugog al kaže kad probam otvoriti da nije accesable... Ledice svijetle... spajam komp i laptop... oba sa xp-om sp2... neznam šta više da kažem osim molim HELP ŠTO PRIJE!!!! hvala
speedy051 je offline   Reply With Quote
Staro 25.12.2007., 00:30   #180
Hrc555
Lokacija: th
Postovi: 12
Umrežio sam ih i sve, imam ping jedan drugom i vidim ih da postoje ali kad kliknem na njih onda me traži Username i password!! Koji su? Kako da to iskljucim da me vise ne trazi username i password??? Isao sam i preko wizarda i ručno ali uvjek isto. Vec sam lagano popizdio!! WIN XP je na oba kompa
Hrc555 je offline   Reply With Quote
