Lokacija: Dalmacija
Postovi: 5,857
Jel ova konfiguracija valja (7000 kn)
Intel Core 2 Duo E6550 BOX, 2×2.33GHz, 1333MHz, 775-pin, 4MB 1.204,43 MB Gigabyte 965P-DS3P, s775, i965P, DDR II, SATA II, FW, GLAN 891,27 DDR2 1GB PC5300 (667MHz) Kingmax 195,87x2= 400,00 *HDD Seagate ST3250620AS/ST3250410AS, 250 GB 16MB, S-ATA300, NCQ3, 7200 497,60 *DVD+RW/-RW/RAM NEC AD-7173S, LabelFlash, SATA, bulk 208,00 Albatron GF 8600GTS, PCIE, 256MB, TV out, dual DVI 1.123,07 Monitor Philips 190WV7CS Silver, 19” LCD, 850:1, 300 cd/m2, 5 ms,WXGA, SmartManage, SmartControl 1.499,00 Thermaltake VD6000BNS mid tower Soprano VX, bez PS, crno, USB, Fire wire, 1×120mm fan 439,00 *Codegen power supply 480W, ATX 2.03, PFC, 2×12V, 2×8cm fan, 2×SATA connectors 294,74 Samsung Pleomax Standard Combo desktop PKC700B tipkovnica + SPM-710B miš crna USB/PS2 /PKC-700B 84,18 i ~6.561,00 + Logitech Speakers S500 5.1 set black OEM /970187-0914 376,98 6.937,00 + Skener Scan. Canon LiDE 25, USB 2.0, 48 bit, (600 x 1200 dpi optic.rez.) 395,00 ~7.332,00 kn i šta izabrat i isplati li se uzimat DX 10 grafičku ili ne |
#2 | ||
Wannabe Pilot
Lokacija: High In The Sky
Postovi: 493
CPU: Intel Core 2 Duo E6750 - 1193kn MBO: Gigabyte P35-DS3 - 744kn RAM: 2*1GB Kingmax 800MHz - 348kn HDD: Samsung SpinPoint T166 320GB - 569kn VGA: XFX 8800GT 512MB - 1875kn DVD: Pioneer DVR-112D - 220kn PSU: Chieftec 400W - 299kn CASE: Chieftec midi tower SG-01B - 266kn LCD: ASUS VW193D 19'' - 1399kn KEY+MOUSE: Samsung Pleomax PKC700B - 70kn SPEAKERS: Logitech S-220 - 150kn PRINT/SCAN: HP All-In-One Deskjet F2180 - 498kn Ukupno: 7632kn Greške na prvoj konfiguraciji: CPU: Ista cijena kao i 6750, lošiji je, neisplativ. MBO: Čemu 965 chipset, kada P35 vlada?!? HDD: Ne Seagate, već Samsung/Hitachi/Western Digital. PSU: Ajme Codegena na toj konfi, jedino što bi učinio bi bilo pokapanje matične ili cijele konfe. CASE: Chieftec/Antec/Coolermaster/Silverstone umjesto tog Thermaltake
#3 | |
Datum registracije: Apr 2004
Postovi: 887
Lokacija: Dalmacija
Postovi: 5,857
e killerbee di si naša te cijene??? ja san ovo u vemila e da vidim da je ovo iz adma al posto san iz tg treba uzet u vemila il hgspot ili linksa (znam za dostavu besplatnu i tako al osoba kojoj je konfiguracija namjenjena neželi dostavu nego oće u ruke dijelove sve) links mi se čini najprihvatljiviju no onda ovako izgleda CPU: Intel Core 2 Duo E6750 - 1368 MBO: Gigabyte P35-DS3 - 779kn RAM: 2*1GB Kingmax 800MHz - 450kn HDD: Samsung SpinPoint T166 320GB - 615kn VGA: XFX 8800GT 512MB - 1999kn DVD: SAMSUNG SH-S203N - 229kn PSU: Chieftec 400W - 329kn CASE: Chieftec midi tower SG-01B - 303kn LCD: ASUS VW193D 19'' - 1399kn KEY+MOUSE: Samsung Pleomax PKC700B - 70kn SPEAKERS: Logitech S-220 - 163kn SCAN(print ima laserski) CANON LiDE 25 410kn sve skupa impresivnih 8114 kn ( a granica bi tribala bit 7000 kn) a mogu uštedit lipe pare na slabiji proc (oko 400-500 kn-e4400) grafa li la.. al je mašina pa vidit kako se cijene kreću u hg i vemila i tako Zadnje izmijenjeno od: OuttaControl. 03.11.2007. u 01:24. |
MiningMod
Postovi: 8,715
CPU:Intel Core 2 Duo E4400 BOX, 2×2.0 GHz, 800MHz, 775-pin, 2MB 878kn MBO: Gigabyte P35-DS3 - 779kn RAM: 2*1GB Kingmax 800MHz - 370kn HDD: HDD HITACHI HDT725032VLA360 320GB SATA-300 7200rpm 16MB 591kn VGA: Powercolor Radeon X1950Pro PCIE, 256MB, TVout, dual DVI 972kn DVD: DVD+RW/-RW/RAM NEC AD-7170BKSA, SATA, bulk, black 222kn PSU: Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 500kn CASE: Chieftec midi tower SG-01B - 299kn 4611 kn VEMIL mislim da ti je to sasvim dovoljno ostatak po izboru |
In the ghetto
Postovi: 1,943
CPU - Procesor Intel Core 2 Duo E4500 , 2.2GHz MBO - Gigabyte P35-DS3L, s775 RAM - DDR2 1024Mb PC5300 Kingmax MARS HDD - HDD SAMSUNG SpinPoint T166 320GB 7200rpm 16MB PSU - FORTRON 350W, PNF DVD - DVD upisivač Liteon DH-20A3P-06C VGA - VGA Ati Radeon HD 2900Pro, 512Mb GDDR3 ili 8800GT za istu cijenu otprilike kad stigne PRINT/SCAN - CANON PIXMA MP210 MONITOR - Philips 190C8FS, LCD, 19" CASE - Aplus CS-185A 7.007,90Kn sve iz www.adm.hr (narucis ljepo, dostava je besplatna za iznose vece od 2000kn i uzivas) Jedino me muci jel bude to ovaj Fortron usple vuci? Cul sam da ova nova 8800GT vuce dota manje struje pa sa mislil da bude to napajanje dosta.
In the ghetto
Postovi: 1,943
Samo kaj je ja ne vidim u cjeniku ili sam stvarno slep ko sismis
Postovi: 33,998
Lokacija: Dalmacija
Postovi: 5,857
al kad pogledan 8800 gts je samo 100 kn skuplja a neznan kakva je razlika ( u stvarnosti) nego još nisan naša konfiguraciju koja zadovoljava parametre zasad je najbolja killerbeeova samo ipak malko skupa |
Wannabe Pilot
Postovi: 493
Evo malo ublaženije i jeftinije, ali ništa slabije konfiguracije. CPU: Intel Core 2 Duo E4400 - 782kn MBO: Gigabyte P35-DS3L - 653kn RAM: 2*1GB Kingmax 800MHz - 348kn HDD: Samsung SpinPoint T166 320GB - 569kn VGA: XFX 8800GT 512MB - 1875kn DVD: Pioneer DVR-112D - 220kn PSU: Chieftec 400W - 299kn CASE: Chieftec midi tower SG-01B - 266kn LCD: LG L194WT 19'' - 1479kn KEY+MOUSE: Samsung Pleomax PKC700B - 70kn SPEAKERS: Logitech S-220 - 150kn PRINT/SCAN: HP All-In-One Deskjet F2180 - 498kn Ukupno: 7209kn
#14 | |
In the ghetto
Postovi: 1,943
PS ima trazilica na njihovom cjeniku i ni jednu GT njie izlistala vec samo GTS i GTX
#15 | |
Lokacija: Dalmacija
Postovi: 5,857
puno hvala killerbee e sad san vidio http://www.autronic.hr/4za2.asp hmmm jel se to isplati naručit nekako čini mi se jeftino za takvu konfu... samo grafička... al to se sredi |
#16 |
Lokacija: Dalmacija
Postovi: 5,857
Evo ovo je preporka iz ve-mila sta kazete na nju Kućište 220,00 *CODEGEN midi tower C6218-CA, 400W PSU w/12cm fan, Fire wire, USB 2.0, audio, 8cm extra fan Matična ploča 589,93 MB Gigabyte M57SLI-S4, sAM2, nForce 570-SLI, SATA, FW, GLAN Procesor 892,41 CPU AMD Athlon64 X2 5200+ BOX, dual core, SckAM2 Memorija x2 371,88 DDR2 1GB PC6400 (800MHz), Kingmax Grafička kartica 949,22 Powercolor Radeon X1950GT PCIE, 512MB, TVout, dual DVI Čvrsti disk 451,27 *HDD Seagate-Maxtor STM3250820AS/STM3250310AS, 250 GB 8MB, S-ATA300, NCQ, 7200 Optički pogon 222,53 DVD+RW/-RW/RAM LG GSA-H12L Dual Layer, LightScribe, 18x, bulk, black Modem 48,12 Fax Modem Int. soft V.90/92 PCI Conexant Pro-Nets Tipkovnica 79,00 Logitech Internet 350 Keyboard PS/2 crna HR OEM / 967674-0133 Miš 71,98 Logitech B58 crni, opt.miš s kotačićem, USB/PS2 OEM Zvučnici 364,78 LABTEC Arena 685 5.1 set , Max-X subwoofer / 970128-0914 Monitor 1.549,00 *Monitor Philips 190S7FS Silver, 19” LCD, 700:1, 300 cd/m2, 8ms, DVI-D, SmartManage, SmartControl |
#17 |
Postovi: 33,998
Intel kombinacija je bolja - bolje kućište i napajanje, bolja grafa, SLI ploča nepotrebna, bolji hard,... U njegovoj kombinaciji, jedino što bih zamijenio je Pioneer 112 (IDE) za 212 (SATA).
#18 |
Lokacija: Dalmacija
Postovi: 5,857
a ovo CPU: AMD Athlon64 X2 5200+ BOX, dual core, SckAM2 892,4 MBO: MB Gigabyte M57SLI-S4, sAM2, nForce 570-SLI, SATA, FW, GLAN 589 RAM: 2*1GB Kingmax 800MHz - 348kn HDD: Seagate-Maxtor STM3250820AS, 250 GB 8MB, S-ATA300, NCQ, 7200 451 VGA: Gigabyte GF 8600GTS PCIE , 256MB – 1,123 DVD: DVD+RW/-RW/RAM LG GSA-H12L 222kn PSU: Chieftec 400W - 299kn CASE: Chieftec midi tower SG-01B - 266kn LCD: Monitor Philips 190C8FS Silver 1650 kn KEY+MOUSE: Samsung Pleomax PKC700B - 70kn SPEAKERS: LABTEC Arena 685 5.1 set , Max-X subwoofer / 970128-0914 364 kn PRINT/SCAN: Canon lide 25 - 379 kn |
#19 |
Lokacija: Vz - Zg
Postovi: 2,930
kod ovog amd-jca hdd je srot, bilo sta samo ne to (wd, hitachi, samsung.. seagate imaju problema s firmwareom, a seagate-maxtor su jednostavno smece), graficka kartica - usparaj malo i uzmi 1950gt, brza je. napajanje uzmi fortrona 400w ak je pnf u vemilu (zadnjih 2 tjedna 2 frenda uzeli tamo), bitno je jace sve u svemu, ta amd konfiguracija ce pod punim overclockom u igrama bit sporija od intel varijante s e6750 procesorom na defaultu, al je 400kn. EDIT: aha, da, monitor, za 50kn vise imas philips 200ws8fs/b, ima osjetno vecu radnu rezoluciju, pa je puno ugodniji u svakodnevnom zivotu
#20 |
Postovi: 4
bar dan! vidim da se razgovara o konfiguracijama a ja sam se baš namjerio na novu pa me zanimaju prijedlozi. Ovo sve navedeno gore mi je ok jer mi i cijena paše jedino postoje neke razlike pa me zanimaju prijedlozi..uglavnom ja bi neki hard od recimo 80gb i kupio bih jedan vanjski sa više štajaznam recimo 300GB(može i manje), ne trebaju mi zvučnici ni printer ni scanner, dvoumim se da li uzeti 16:9 monitor, neki od 19 dolazi u obzir, iako sam laik čujem uglavnom da se intel pokazuje bolji u zadnje vrijeme pa ne znam da li da ciljam u tom smjeru..i to do nekog iznosa od 7000, 7500kn. |
#21 |
In the ghetto
Postovi: 1,943
Cemu sluzi konfa? Za posel ili igru? mbo - Gigabyte P35C-DS3R, s775, intel P35+ICH9R, FSB 1333/1066/800MHz cpu - Procesor Intel Core 2 Duo E6750 , 2.66GHz, socket 775, 4Mb cache ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 hdd - HDD Samsung 160Gb SpinPoint, Serial ATA II, 8 MB cache, 7200 okr hdd - HDD SAMSUNG SpinPoint T166 320GB 7200rpm 16MB cache Serial ATAII exk - Eksterno kućište 3.5'' IDE - USB 2.0, Canyon, CN-HDD35, al vga - VGA Ati Radeon HD 3850, 256Mb GDDR3, Dual DVI, PCI Express 16x dvd - DVD upisivač Pioneer DVR-112DBK, DVD±RW, 18x DVD±R ,8x DL, black psu - Napajanje FORTRON 400W, Super Silent, 12cm ventilator, ATX2 cas - Coolermaster Centurion 534, silver-black , bez napajanja mon - PHILIPS 220WS8FB, 22" LCD, widescreen, 1000:1, 5ms, VGA, DVI-D 7.538,45Kn sve iz www.adm.hr Mozes jedino ustedit ako ulovis koju grafu u hgspotu gdje su nesto jeftinije ali se jako brzo rasprodaju.
#22 |
Lokacija: Vz - Zg
Postovi: 2,930
Avantgarde dobrodosao! ovak, ima svakakvih (vise manje istih) konfiguracija za odredene svote novca ovdje, zadnjih 2-3 mjeseca se nije nesto drasticno mjenjalo pa ono sto ti odgovara najvise uzmes i miran si. Da odgovorim na neka pitanja hard diskovi - kao prvo, hard od 80gb se nikako ne isplati kupit jer su svi daleko starijih tehnologija od ovih vecih i sporiji su osjetno, a razlika u cijeni izmedu 80 i 250gb diska je 150kn svega, tu dolazimo do onog seagate-a koji je stvarno izuzetna kupovina trenutno (ST3250410AS) jer je jako brz i tih u isto vrijeme za iste novce kao i svi ostali. Eksterni hard, to je naravno tvoj izbor sta uzet, da li 2.5" ladicu pa nutra neki lap disk, da li 3.5" ladicu i unutra neki normalni disk ili jednostavno vec neki eksterni hard. Prednosti ladica + diskova su sto su uglavnom nesto jeftinije i moze se mjenjati velicina diska po potrebi, odnosno druga ladica ako se ova osteti ili sta vec, dok tvornicki eksterni diskovi ako otvoris gubis garanciju, ako se neki kabel rasklima problem jer cjeli disk na servis mora i slicno dok su uglavnom ljepsi i moguce sigurniji posto bi trebale vibracije diska bit bolje slozene u njima. monitori - preporuka je svakako pogledat kako sve izgleda na nekom monitoru, ovi 19" wide monitori osim sto su niski fizicki imaju po meni premalu vertikalnu rezoluciju za ugodno koristenje neta i uredskih alata. Dok standardni 19" 5:4 monitori imaju dobru vertikalnu rezoluciju, al pate od male sirine pa filmovi koji su svi u wide formatu jednostavno izgledaju minijaturno na njima. Caka je da razlika u cijeni izmedu 19" i 20" monitora nije bas neka, dapace za ocekivat je da ovi 19" kompletno nestanu s trzista kroz neko krace vrijeme. AMD vs Intel trenutno - Intelovi procesori su trenutno na istom taktu nesto brzi, kako koji, neki vise neki manje, imaju prednost ludjacke mogucnosti dizanja radnih taktova bez narusavanja sigurnosti cjelog sustava. Naravno ukoliko neces dizat frekvenciju procesora onda AMD ima prednost u vidu super jeftinih ploca, iako se i za intel platformu za oko 600kn dobije vec jako solidna ploca, ali se da usparat parsto kn sigurno. rasprave o konkretnim djelovima hardware-a mozes pronaci u za to predvidenim podforumima. Jedna preporuka od srca jedino, nemoj uzimat neko shrotex napajanje, pristojna napajanja se dobiju za 200-300kn vec i stvarno je grijeh stedjeti na tome a dovodit u pitanje stabilnost i uopce zdravlje cjele kante EDIT: evo dok ja ovo sve tipkao kolega elvis je predlozio vise nego pristojnu konfiguraciju koja ce zadovoljit sve potrebe a unutar cjenovnog okvira je. Jedino sto na nju jos treba dodati je DVI kabel za monitor koji ne dolazi sa samim monitorom a drasticno poboljsava kvalitetu slike (kosta 50-ak kn)
#23 |
Postovi: 4
Stvar je u tome što meni treba baš prenosni hd ili ladica pa mi stvarno ne treba veliki na pc-u, mislim nemam pojma šta će mi na kompu 320gb..do sad imam komp 5god i nisam napunio 80gb..a u biti mi treba i nešto za jednostavni prijenos, ako kažeš da je ladica bolja onda ladica..dakle definitivno LCD ispred CRT monitora? kako sam negdje čitao kažu da CRT monitori imaju bolji tj precizniji izgled boja. + što bih htio grafičku od 512 i 2gb rama jer ću sigurno i igru koju zaigrati..a sad nije problem potegnut i do 8000 al radije bi se ograničio na 7500 |
#24 |
In the ghetto
Postovi: 1,943
Mislim da je ova konfa koju sam slozil cisto ok. Ak hoces veci eksterni hard stavi ovaj hdd od 320GB u eksternu ladicu a ovaj od 160GB u komp. 3850 ti je nova grafa i radit ce ti sve danasnje igre gore mozes uzet i 3870 sa 512mb ali ovih jeftinijih bas i nema (npr. bilo je 3870 za 1370kn u hgspotu)
