Staro 01.11.2007., 20:14   #31
Wolverine
Wolverine's Avatar
Postovi: 12,431
Autor Uber Gosu Pregled postova
@ovca
Zalman 9500 i 9700 nisu isti cooler malo si se zabunio(9700 ima veci i tisi vent). + Freezer 7 NEJDE na p35-DQ6 bez piganja listova na radijatoru sto ne dolazi u obzir u mom slucaju....sto se OC tice mozda si ti s***o stvar(MBO u banani).
misliš?
vidim nisi čitao
The Zalman 9700 is a slightly better cooler than the 9500, but the performance differences are very small - the 9500 tops out in OC at 3.81 GHz where the 9700 reaches 3.83 GHz. Also the 9500 is a bit quieter across the board than the 9700
If you are looking for value - the best performance and noise control for your dollar - then there are much better choices in the market than the Zalman 9500 and 9700
lova mi nije bitna, tocnije bitniji mi je vizualni dojam coolera
ovime si sve rekao
P.S. pogledaj ovo što se tiće buke i hlađenja 9700 vs BT
nebi baš reko da 9700 vrijedi 4xxkn
http://sobitza.com/portal/index.php?...d=84&Itemid=32
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 01.11.2007., 22:08   #32
peroW1
peroW1's Avatar
Lokacija: Croatia Čk
Postovi: 551
ma LOL.
Nakon tolikih drama oko Zalmana...ajde, nek na ovom forumu ne vrijedi nista, mene ne dira. Moze tu pljuvat koliko tko hoce, to je njegova osobna stvar. Kao i moja,npr...cooler mora biti lijep. (subjektivno). Dakle, osobno su mi Zalmani najljepsi. Prvo bijase prica, coretemp krivo pokazuje. Ok, skinuh najnoviji, temp-i vise nego odlicne.(tj.nisu se promijenile nakon onog "koji je krivo pokazivao".
Tada rekose, laze ti senzor na ploci...ok, kupih novu plocu. Temp-iste.
Ajd reko, cpu ne valja,....kupih drugi proc...TEMP- jos bolje.
I taj moze radit sad na 3.55 (3.7 isto)pri 1.4v i trenutni idle ok ovo pisem je 35,37,40,43.
U loadu prilikom igranja crysisa nije prosao 60'C. Sad...nema veze sto je taj bijedni zalman toliko los...ali zamislite sto bi tek bilo kada bi stavio neki bolji...mozda bi temp bile blizu nuli...
Vec si mjerkam i 8700NT, jer je prelijep.
Eto...sorryte na poduzem postu.
i5 2550K 4.1GHz *Gigabyte Z77-D3H, 32 GB RAM KINGSTON HYPER X FURY, ASUS GTX 1060Ti , SSD 1TB, CoolerMaster 850W, ASUS 32'' 4K
peroW1 je offline   Reply With Quote
Staro 01.11.2007., 22:23   #33
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,128
Teska ironija poslje pregleda tvog stackera, (visednevnog yebavanja s kablovima i kojecime) da das ovakvu izjavu.
Gledaj, ovo sto si ti izjavio i sa cime si zapoceo thread je neusporedivo sa mojim picajzljenjem oko kucista. Meni jest bitan izgled, ali ne u sminkerskom smislu, nego u funkcionalnom, a to ima direktan utjecaj na performanse i dugotrajnost sustava. Ako si primjetio moj blok na procu nije neka teska skupa sminka, nego je rucne izrade, neonki i slicnih modding idiotarija nema, sto ce reci da mi izgled uopce nije bitan. Prijasnji cooler mi je bio Sonic Tower koji, ruku na srce, nije neki ljepotan. Meni osobno je bitan red u kucistu, jer sa onoliko komponenti da nisam drzao do reda stvorio bi se kaos.
Al zanemarimo sve to, meni ispocetka nije jasan smisao ovog threada... korisnije bi bilo da si napisao review neke komponente koje imas ili nesto slicno.
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
