Staro 21.10.2007., 01:47   #1
Forum_user
Postovi: 6
Dotrajalost baterije
Imam acerov laptop (5114WLMi) i zadnjih dana me poceo brinut podatak u everestu da mi je dotrajalost baterije 10%, a laptop tek 10 dana star...
Bateriju sam prvo napunio, zatim istrosio pa napunio i odtad laptop skoro podjednako koristim kako na bateriji tako i na punjacu.
Jeli ova pojava normalna, oce li se to smanjiti ili stati na 10%? Jesu li moji postupci uredu, i kako treba pravilno koristiti tu bateriju(puniti prazniti i to)?
Unaprijed hvala
Forum_user je offline   Reply With Quote
Staro 21.10.2007., 11:04   #2
daddy1976
daddy1976's Avatar
Lokacija: Zgb/Srednjaci
Postovi: 65
copy-paste mog prijašnjeg odgovora:
desktop zamjena?
http://forum.pcekspert.com/showthread.php?t=79806
ili pravi prijenosnik?
u tom slučaju puniti-prazniti kako dođe, ali ne da se skroz isprazni, a svaki 30 - ti puta isprazniti skroz bateriju
Battery university:
Simple Guidelines
* Avoid frequent full discharges because this puts additional strain on the battery. Several partial discharges with frequent recharges are better for lithium-ion than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no memory. (In this respect, lithium-ion differs from nickel-based batteries.) Short battery life in a laptop is mainly cause by heat rather than charge / discharge patterns.
* Batteries with fuel gauge (laptops) should be calibrated by applying a deliberate full discharge once every 30 charges. Running the pack down in the equipment does this. If ignored, the fuel gauge will become increasingly less accurate and in some cases cut off the device prematurely.
HP 6715b AMD Turion64 X2 TL56 2GB 160GB 15.4''WXGA X1250
Black holes suck!
daddy1976 je offline   Reply With Quote
Staro 21.10.2007., 11:20   #3
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,398
Moj HP NX7300 je star 6 mjeseci i još je uvjek na 0%.
Radi na bateriju dok ne izbaci da je baterija prazna 10% ili manje i onda ga stavim na punjač.
Nastavljam rad na punjaču, ali kad je baterija puna 99 ili 100 posto skidam ga sa punjača.
Lap dnevno radi oko 5 do 7 sati, a vikendima i duže.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Staro 21.10.2007., 11:35   #4
igx
Datum registracije: Mar 2002
Postovi: 258
jeste vi svi opterečeni sa tim baterijama... nisam ja tu da služim laptopu i njegovoj bateriji, nego obratno
stalno radit na bateriji i bojat se spojiti punjač u njega nema smisla, on mora biti predviđen da radi duže na punjaču, ako nije loše su odradili svoj posao u tvornici.
kad se bojite toliko tog punjača pokrenite jednom na mjesec reset baterije i bok.
ako tako brzo gubi kapacitet to sigurno nije do načina korištenja nego loše kvalitete baterije tak da u večini slučajeva koliko god vi nju pazili i mazili ona gubi svoj kapacitet jer ih i vrijeme uništava, ne samo korištenje.
igx je offline   Reply With Quote
Staro 24.10.2007., 09:29   #5
tomy_t
tomy_t's Avatar
Lokacija: neposredna blizina Zagreba, DS9
Postovi: 279
everest ti na nekim lapacima laze upravo tih 10%, ja sam stavio u lap novu novcatu bateriju iz vrecice, napunio ju, i everest mi je reko 10% dotrajalost.
||DELL Inspiron 5770 || Intel Core i5-8250U || 240GB NVME + 1TB HDD || DVD RW DL || Intel UHD620@ 17,3" IPS 1920 x 1080 || 16GB (2 x 8096MB) DDR4 || 802.11a/b/g/n/Bluetooth ||2MP Webcam ||HDMI ||Windows 10 Professional ||
tomy_t je online   Reply With Quote
