Staro 03.10.2007., 20:26   #1
antebr
antebr's Avatar
Postovi: 421
Problem sa overclockom 7900gs
Instalira sam rivatuner 2.05 i nvidia drivere 163.71 na cistu instalaciju windowsa XP. Kad idem na Overclocking, i ukljucim driver-level hardware overclocking.
Ako maknem slajder i za 1Mhz i pritisnem test ispise mi se:
"The driver failed to pass internal test with the clock frequencies you are about to set. Please decrease clock frequencies and try again."
Inace grafika je Gigabyte 7900gs.
Ista se stvar desava bilo da pomaknem slajder od core clock ili od memory clock.
Ima li ko kakvo rješenje.
Ante
antebr je offline   Reply With Quote
Staro 03.10.2007., 20:41   #2
Slash555
Slash555's Avatar
Lokacija: Slatina
Postovi: 363
skini atitool i radit će ti bez problema
Slash555 je offline   Reply With Quote
Staro 04.10.2007., 08:50   #3
antebr
antebr's Avatar
Postovi: 421
Znam, proba sam sa atitool i radi, ali me zanima zasto nece sa Rivatunerom, i sa gigabaytovim programom.
Znam da mi je prije radilo.
ANte
Staro 10.10.2007., 11:32   #4
Wolverine
Wolverine's Avatar
Postovi: 12,425
tavi starije drivere, ionako sumnjam da si nekaj dobio s najnovijim
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
