Postovi: 12,425
PC P&C Silencer 610W recenzija
je gladan!
Postovi: 1,698
Ovakve stvari ne kužim: "the single fan was without a doubt the most noticeable fan in the case where it was installed" - i što sad to znači? Napajanje može biti debelo glasno a da je njima tiho ![]()
Premium moderator
Postovi: 4,600
"This power supply was whisper quiet until it came to the SLI tests where its lone 80mm fan picked up speed like a freight-train rolling down a mountain." Valjda ovo pojašnjava situaciju? Bilo je über tiho, no kad su došli SLI testovi mhmmhmm da ![]() Predobro napajanje ![]()
__________________ |
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,323
A vidi kako to ekipa xtreme systemsa vidi ; WHICH ONES TO BUY ?? Tier 1 can handle 4Ghz Conroe or 3Ghz AMD along with Oced Quad Crossfire/SLI With Ease. Tier Z offers quality and power unequalled in its wattage range and is second only to other Zippy units. Tier 2 offers almost as much power and stability as Tier 1 at Comparable Wattage levels with lower price/better availability. Tier T offers the high quality components of Tier 2 with slightly less Rail stability due to Topower internals. Tier 3 is ONLY Recommended if Price difference is present between Tier 3 and Tier 2 or due to availability issues with Tier 1/2 PSUs. Tier 4 is recommended for stock or low power systems if Tier 3's are more expensive or are not available. Tier 5 are NOT RECOMMENDED, but some brands have high/medium quality components in Tiers 2 through 4. -----x-----x-----x-----x-----x-----x-----x----- Tier 1 Brands - The Most Powerful And Stable Components On The Market Enermax Galaxy PCP&C TurboCool PCP&C Silencer >610 Zippy/Emacs SSL Zippy/Emacs GSM Zippy/Emacs PSL Silverstone ZF (Etasis 85/75/56) Seventeam ST >600 (SSI, V2.91) Silverstone OP/DA >700W Tier Z - Less Powerful Than Tier 1 Zippy Units...but they're still Zippys Zippy/Emacs HG2 Zippy/Emacs HP2 Tier 2 Brands - Top Quality components With Top Notch Stability - For Those With Price/Availability Issues With Tier 1 Antec Neo HE Akasa PowerGreen 80+ CoolMax CTG-750W/850W/1KW Cooltek CT Corsair HX Enermax Liberty Enermax Infiniti Enhance ENP-GH Fortron (FSP) GLN Hiper Type-M >650W Hiper Type-R >650W iStarUSA PD2 iStarUSA PD3 OCZ GameXStream OCZ EvoStream PCP&C Silencer <610 Seasonic S12 Seasonic M12 Seasonic Energy Plus SevenTeam ST <600 Silverstone EF Silverstone OP/DA <700W Supermicro/AbleCom Thermaltake Toughpower >600W Xclio GreatPower Zalman ZM Ultra X3 Ultra X-Pro http://www.xtremesystems.org/forums/...d.php?t=108088 Ja imam to napajanje, i fakat ; pod klokanim 6600 , klokanom 8800gts , 2 kile rama, 5-6 ventilatora i ostalo - 0 bodova , nema buke . čuje se ako staviš uho 1cm od ventilatora ![]() Ako je njima gut - i meni je ![]() Zadnje izmijenjeno od: vex. 22.09.2007. u 20:41. |
Postovi: 12,425
Da sada kupujem napajanje od 600W stvarno bi se jako dvoumio između tog Silencera i Corsair-a. Snaga je ista 49A (PC P&C) vs 50A (Corsair) jedino je pitanje kolika je stvarna razlika u buci
Lokacija: n/a
Postovi: 6,128
Napajanje je 1250kn, to je presmijesno. Za tu lovu si uzmem dva Cors-a VX550W, koje sigurno nije nesto posebno losije napajanje. Glede liste na XS-u, generalno je sve tocno, ali u ovom slucaju radi se o istim napajanjima (Cors HX620 i PC P&C Silencer 610W), tako da... |
Postovi: 2,724
Ja bi radije corsaira, odlično napajanje. Hvaljen svugdje, jefiniji ohhhhoo od ovog silencera. |
Lokacija: Livingrad
Postovi: 539
pcp i c (mada) quad 750w radi ko urica. tih i jak. vjerujem da i 610 nema nekih problema. i fakat nemogu kuziti balkance...meni je dobar ee burke onaj eee jeftilen ee radi supe ee r ono supe eee burke r je znaci niko nebi vozio jaguare i maseratije itd jer ee burke golf isto ide ee razbu fest zobr ee razbu |
#12 | |
Postovi: 12,425
Postovi: 11,642
Mali OT: tek sad vidim da Gradjanin ima GTX SLI. Pa ajde pohvali se sa kojom rezom da vidimo kako to ide. |
Lokacija: Livingrad
Postovi: 539
ma sht...stavio sam konfu u opis jer takva treba biti. naravno ima i ali. bez alija nema nista. nemogu dobiti jos jednu gtxcu kakvu trebam, a niti nema 24" kojeg hocu. smrch..zato i nisam jos uvijek stavio "Srebrnog Letacha" u opticaj narucis, dodes po robu a ono, ovaj, znate, greska, skladiste nije unjelo bla bla...balkan...i tak, cekam...trenutna je reza s def jednom gtx i procom na 3.0 11250. ajde jedan OT: preporuka za dobar proc hladnjak. pasivac po mogucnosti. izguglao sam milion testova, no onak, savjet iz prakse dobro dode. |
Postovi: 11,642
Taj procesor nećeš moći ohladiti pasivno... Od coolera: Do 250kn: Freezer 7 Pro, Coolermaster Hyper UC, Scythe Katana 2 Preko 250kn: Thermaltake Sonic Tower/Big Typhoon, Scythe Infinity/Ninja Plus. |
#20 |
Lokacija: Livingrad
Postovi: 539
hmm neznam za tvoju grafulju, no moja je vrlo vrlo tiha. pogotovo na def postavkama. pogotovo u kucistu koje imam. zaustavim na tren stock cooler i mmmmmm tisina.......a mozda imam preklempave usi i cujem ko sismis pa me smeta svaki fijuk ![]() no, cak i da je bucno, zasto buku podizati jos i s coolerom od hladnjaka? btw..cak i nemas brige da ce vent krepat...a i ono...fora izgleda ta hrpa lima slozena u tower. i da...sli jos nije upogonjen...nazalost...gemini moje gtxce jos uvijek nije dobavljiv ali je zato sve ostalo na mjestu. a slot samo ceka..vruc..mokar..zeljan |
