Staro 22.09.2007., 17:08   #1
Wolverine
Wolverine's Avatar
Postovi: 12,425
PC P&C Silencer 610W recenzija
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 22.09.2007., 17:39   #2
Don
je gladan!
Don's Avatar
Postovi: 1,698
Ovakve stvari ne kužim:
"the single fan was without a doubt the most noticeable fan in the case where it was installed" - i što sad to znači? Napajanje može biti debelo glasno a da je njima tiho
Don je offline   Reply With Quote
Staro 22.09.2007., 18:15   #3
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
"This power supply was whisper quiet until it came to the SLI tests where its lone 80mm fan picked up speed like a freight-train rolling down a mountain."
Valjda ovo pojašnjava situaciju? Bilo je über tiho, no kad su došli SLI testovi mhmmhmm da
Predobro napajanje
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 22.09.2007., 18:26   #4
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
49A na 12v
none
Staro 22.09.2007., 18:28   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Bezveze, radije bih uzeo Cors-a HX620. 100 puta radije.
Staro 22.09.2007., 20:30   #6
vex
vex's Avatar
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,320
A vidi kako to ekipa xtreme systemsa vidi ;
WHICH ONES TO BUY ??
Tier 1 can handle 4Ghz Conroe or 3Ghz AMD along with Oced Quad Crossfire/SLI With Ease.
Tier Z offers quality and power unequalled in its wattage range and is second only to other Zippy units.
Tier 2 offers almost as much power and stability as Tier 1 at Comparable Wattage levels with lower price/better availability.
Tier T offers the high quality components of Tier 2 with slightly less Rail stability due to Topower internals.
Tier 3 is ONLY Recommended if Price difference is present between Tier 3 and Tier 2 or due to availability issues with Tier 1/2 PSUs.
Tier 4 is recommended for stock or low power systems if Tier 3's are more expensive or are not available.
Tier 5 are NOT RECOMMENDED, but some brands have high/medium quality components in Tiers 2 through 4.
-----x-----x-----x-----x-----x-----x-----x-----
Tier 1 Brands - The Most Powerful And Stable Components On The Market
Enermax Galaxy
PCP&C TurboCool
PCP&C Silencer >610
Zippy/Emacs SSL
Zippy/Emacs GSM
Zippy/Emacs PSL
Silverstone ZF (Etasis 85/75/56)
Seventeam ST >600 (SSI, V2.91)
Silverstone OP/DA >700W
Tier Z - Less Powerful Than Tier 1 Zippy Units...but they're still Zippys
Zippy/Emacs HG2
Zippy/Emacs HP2
Tier 2 Brands - Top Quality components With Top Notch Stability - For Those With Price/Availability Issues With Tier 1
Antec Neo HE
Akasa PowerGreen 80+
CoolMax CTG-750W/850W/1KW
Cooltek CT
Corsair HX
Enermax Liberty
Enermax Infiniti
Enhance ENP-GH
Fortron (FSP) GLN
Hiper Type-M >650W
Hiper Type-R >650W
iStarUSA PD2
iStarUSA PD3
OCZ GameXStream
OCZ EvoStream
PCP&C Silencer <610
Seasonic S12
Seasonic M12
Seasonic Energy Plus
SevenTeam ST <600
Silverstone EF
Silverstone OP/DA <700W
Supermicro/AbleCom
Thermaltake Toughpower >600W
Xclio GreatPower
Zalman ZM
Ultra X3
Ultra X-Pro
http://www.xtremesystems.org/forums/...d.php?t=108088
Ja imam to napajanje, i fakat ; pod klokanim 6600 , klokanom 8800gts , 2 kile rama, 5-6 ventilatora i ostalo - 0 bodova , nema buke . čuje se ako staviš uho 1cm od ventilatora
Ako je njima gut - i meni je
Zadnje izmijenjeno od: vex. 22.09.2007. u 20:41.
Staro 23.09.2007., 10:21   #7
bego2
bego2's Avatar
Postovi: 2,724
+12=49A
to ganja šta hoćeš.
bego2 je offline   Reply With Quote
Staro 23.09.2007., 11:22   #8
Wolverine
Wolverine's Avatar
Postovi: 12,425
Da sada kupujem napajanje od 600W stvarno bi se jako dvoumio između tog Silencera i Corsair-a.
Snaga je ista 49A (PC P&C) vs 50A (Corsair) jedino je pitanje kolika je stvarna razlika u buci
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 23.09.2007., 12:44   #9
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Napajanje je 1250kn, to je presmijesno. Za tu lovu si uzmem dva Cors-a VX550W, koje sigurno nije nesto posebno losije napajanje.
Glede liste na XS-u, generalno je sve tocno, ali u ovom slucaju radi se o istim napajanjima (Cors HX620 i PC P&C Silencer 610W), tako da...
Staro 23.09.2007., 13:52   #10
bego2
bego2's Avatar
Postovi: 2,724
Ja bi radije corsaira, odlično napajanje. Hvaljen svugdje, jefiniji ohhhhoo od ovog silencera.
Staro 24.09.2007., 22:50   #11
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
pcp i c (mada) quad 750w radi ko urica. tih i jak. vjerujem da i 610 nema nekih problema.
i fakat nemogu kuziti balkance...meni je dobar ee burke onaj eee jeftilen ee radi supe ee r ono supe eee burke r je
znaci niko nebi vozio jaguare i maseratije itd jer ee burke golf isto ide ee razbu fest zobr ee razbu
Gradjanin je offline   Reply With Quote
Staro 24.09.2007., 23:48   #12
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor Gradjanin Pregled postova
nova pošiljka je stigla vidim
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 24.09.2007., 23:58   #13
Razer
Razer's Avatar
Postovi: 11,642
Mali OT: tek sad vidim da Gradjanin ima GTX SLI. Pa ajde pohvali se sa kojom rezom da vidimo kako to ide.
Staro 25.09.2007., 09:18   #14
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
ma sht...stavio sam konfu u opis jer takva treba biti.
naravno ima i ali. bez alija nema nista.
nemogu dobiti jos jednu gtxcu kakvu trebam, a niti nema 24" kojeg hocu. smrch..zato i nisam jos uvijek stavio "Srebrnog Letacha" u opticaj narucis, dodes po robu a ono, ovaj, znate, greska, skladiste nije unjelo bla bla...balkan...i tak, cekam...
trenutna je reza s def jednom gtx i procom na 3.0 11250.
ajde jedan OT: preporuka za dobar proc hladnjak. pasivac po mogucnosti. izguglao sam milion testova, no onak, savjet iz prakse dobro dode.
Staro 25.09.2007., 09:51   #15
Razer
Razer's Avatar
Postovi: 11,642
Taj procesor nećeš moći ohladiti pasivno...
Od coolera:
Do 250kn: Freezer 7 Pro, Coolermaster Hyper UC, Scythe Katana 2
Preko 250kn: Thermaltake Sonic Tower/Big Typhoon, Scythe Infinity/Ninja Plus.
Staro 25.09.2007., 10:48   #16
Don
je gladan!
Don's Avatar
Postovi: 1,698
Ako imaš love ThermalRight 120 ultra extream, pasivno hladi proc iz siga do 42C u idle-u.
Staro 26.09.2007., 08:43   #17
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
Minja 1000 je dosla tiho...a hoce li u legendu, recenzija kad sve sklopim
Staro 26.09.2007., 23:35   #18
vex
vex's Avatar
Lokacija: sl. brod
Postovi: 1,320
Autor Don Pregled postova
pa ima sli gtx-ice , valjda će iščeprkat iz džepova i za neki ladnjak
Staro 26.09.2007., 23:42   #19
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Da, kao 2 GTX-ice su turbo tihe...pa treba pasivni hladnjak za proc
Staro 27.09.2007., 09:15   #20
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
hmm neznam za tvoju grafulju, no moja je vrlo vrlo tiha. pogotovo na def postavkama. pogotovo u kucistu koje imam. zaustavim na tren stock cooler i mmmmmm tisina.......a mozda imam preklempave usi i cujem ko sismis pa me smeta svaki fijuk
no, cak i da je bucno, zasto buku podizati jos i s coolerom od hladnjaka? btw..cak i nemas brige da ce vent krepat...a i ono...fora izgleda ta hrpa lima slozena u tower.
i da...sli jos nije upogonjen...nazalost...gemini moje gtxce jos uvijek nije dobavljiv ali je zato sve ostalo na mjestu. a slot samo ceka..vruc..mokar..zeljan
