ASUS
Lokacija: Beograd
Postovi: 263
Spacemaster Frozene Blood Water system
SFB Water System Test sistem ASUS Blitz Formula (P35 čipset, 02 revizija) Intel Core 2 Quad Q6600(4 X 2.40 GHz, 2 X 4 MB L2) 2 X 1 Gb Geil Ultra PC2-8500 Evga 8800GTS 320 Mb 2 X WD Caviar 200Gb/WD2000JS, 7200rpm, 8MB Coler Master Real Power Pro M1000W Alphacool NexXxos Alphacool AP1510 2 X Alphacool NexXxoS Xtreme III - Rev. 2 Alphacool AP1510 centrifugal pump 12Volts ru;no pravljeni res. 80x500 mm Glacelf Supra + H2O PVC 12/9 mm 10 x12 cm Led Red Fans Male modifikacije kućišta i iispoliran vodeni blok sa procesorom http://www.fotorola.com/uploads/eae7f4fa54.jpg http://www.fotorola.com/uploads/a33f61e31e.jpg http://www.fotorola.com/uploads/b23ea49566.jpg http://www.fotorola.com/uploads/ec6142e73b.jpg http://www.fotorola.com/uploads/7edc55e821.jpg http://www.fotorola.com/uploads/9f3ed6e873.jpg Zadnje izmijenjeno od: Vuco. 29.09.2007. u 14:32. |
ASUS
Lokacija: Beograd
Postovi: 263
Posle uloženog truda, gotov proizvod http://www.fotorola.com/uploads/985f75e450.jpg http://www.fotorola.com/uploads/a2e92cbca8.jpg http://www.fotorola.com/uploads/9444d3a562.jpg http://www.fotorola.com/uploads/c977033f8d.jpg http://www.fotorola.com/uploads/d76de972da.jpg http://www.fotorola.com/uploads/38d4e42020.jpg http://www.fotorola.com/uploads/38d6972afa.jpg http://www.fotorola.com/uploads/78435433c6.jpg Zadnje izmijenjeno od: Vuco. 29.09.2007. u 14:32. |
ASUS
Lokacija: Beograd
Postovi: 263
Benchmark rezultati 4 x prime 3.6 GHz http://www.fotorola.com/uploads/58d2061cb5.jpg 4 x prime 3.7 GHz http://www.fotorola.com/uploads/7f455f5e3c.jpg 4 x prime 3.8 GHz http://www.fotorola.com/uploads/e27cde8bf5.jpg 4 x prime 3.9GHz http://www.fotorola.com/uploads/1b39baa42d.jpg Super pi 1m -11.563 http://www.fotorola.com/uploads/12c7f167c4.jpg 3DMark 03 – 44160 http://www.fotorola.com/uploads/30aca360bb.jpg 3DMark 05 – 22535 http://www.fotorola.com/uploads/c48e91805b.jpg 3DMark 06 – 14031 http://www.fotorola.com/uploads/99d4911338.jpg Cinebench 95 – 2281 http://www.fotorola.com/uploads/a389b4bc6d.jpg Cinebench 10 – 15174 http://www.fotorola.com/uploads/7dffb79acf.jpg Zadnje izmijenjeno od: Vuco. 29.09.2007. u 14:33. |
ASUS
Lokacija: Beograd
Postovi: 263
Max clock 4478,31 MHz http://www.fotorola.com/uploads/14204e4ee5.jpg http://valid.x86-secret.com/show_oc.php?id=237304 http://valid.x86-secret.com/show_oc.php?id=237327 http://valid.x86-secret.com/show_oc.php?id=238455 http://valid.x86-secret.com/show_oc.php?id=238459 http://valid.x86-secret.com/show_oc.php?id=238784 Zadnje izmijenjeno od: Vuco. 29.09.2007. u 14:33. |
ASUS
Lokacija: Beograd
Postovi: 263
Zadnje izmijenjeno od: Vuco. 29.09.2007. u 14:34. |
Evo ostao sam bez rijeći....samo pohvale i puno ![]() |
Just don't give a fuck
Postovi: 764
Što reć, nego ![]() |
Postovi: 577
bravo space svaka pohvala ![]() inače dečki to je jedan od svjetskih prvaka 3dmark06, trenutno su drugi on i njegov tim, ali namjera je uskoro opet biti zlatni ![]() naravno i u drugim kategorijama su u samom vrhu ![]()
Zadnje izmijenjeno od: dugixy1. 19.09.2007. u 02:01. |
#13 | |
ASUS
Lokacija: Beograd
Postovi: 263
Pozdrav ma bice jos slika na Sx-u radim na gajdu "kako ispolirati procesor i blok", stoga vidimo se na mom terenu. ![]() ![]()
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Spacemaster, odlično je to sve, sjajan primjerak, ali - slike obavezno u thumb, stvarno su prevelike. Za sada ti u naslovu stoji 56k warning, ali neće dugo, a žalosno bi bilo da slike otiđu. |
Extreme Air Cooler
Datum registracije: Sep 2004
Lokacija: Kastav & Rijeka
Postovi: 491
Ovo je odlicno, fantazija kako je slozeno vodeno. Malo mi je kejs kic, ali zato su ovi vanjski radijatori i rez. cisti orgasmatron. ![]() GW!
---= The eternal mistake of mankind is to set up an attainable ideal =--- |
#16 |
Postovi: 12,600
@Spacemaster, kao prvo svaka cast na ovome, nego dali mozes reci koliko $ te ovo sve dodje? Barem cca ili samo vodeno koliko dodje?
#17 |
Postovi: 11,642
Što reći nego svaka čast. Ovo izgleda fantastično ![]() ![]() ![]() |
#18 |
ASUS
Lokacija: Beograd
Postovi: 263
Hvala dečki, radi se na još jednom projektu koji ce se zvati "Kocka" nesto slicno onome sto sam okacio dole, ali to nece biti gotovo prije Nove godine. Međutim sx tim radi na još tri projekta vodnog hladjenja, rezultati su vec poznati, ali pitanje samo vremena kad ce to biti obelodanjeno, možda cak i veceras. Naravno sve cu podeliti i sa vama ovde. Video sam da imate nekoliko tutorijala oko vodenih hladjenja, i ajde da ne bude grugo, malo su siromasni stoga kad nađem vremena napisacu i jedan za vaš forum, a do tad sve sto vam treba imate na sx forumu. P.S. U slučaju da slike budu morale da idu iz sobe zbog veličine, ali ne vidim razlog za to onaj ko želi da ih vidi može to uraditi i ovde http://www.sx-team.com/forum/index.p...st=0&#entry808 ![]()
#20 |
ASUS
Lokacija: Beograd
Postovi: 263
Ceo projekat je izasao oko 2.5k eura, ali 80% su bile donacije firmi. Kuciste uvozi Cosmosoft i smedereva, imaju celu palteu ovakvih kucista. Konkretno ovaj model teži manje od 1kg jer je od Al, a cena jos nije ni formirana, ali ne bio trebalo da prelazi 150eura.
#22 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
DAJ neseeeeeeeeeri ! ![]() fenomenalno slozeno jos jednom .
#24 |
Postovi: 2,073
nije to kic, to je svemirski brod, kak ne kuzis ![]() btw. sto se tice slika, jel se ne moze ubaciti ova fora kao na tom sx-team forumu (i jos dosta drugih) da automatski smanji slike? |
