#121 |
Postovi: 3
ista stvar se desila i mene a rjesenje je bilo sljedece 1. NVIDIA Control Panel > Display > Manage custom timings. 2. Click both "Treat as HDTV" and "Allow modes not exposed by the display" 3. Click [Create...] 4. Under Custom display mode values: Horizontal desktop pixels: (Example: 1440) Vertical desktop lines: (Example: 900 GDI Refresh rate: (max supported by your monitor at desired resolution) Bits per pixel: 32 (don't have "Interlaced" checked) 5. Click [Advanced >>] 6. Under "Back-end parameters": Timing standard: DMT Desired refresh rate: (max supported by your monitor at desired resolution) (the rest of the fields are grayed out) 7. Under "Front-end paramers" Scaling type: Display (none) 8. Click [Test] 9. Click [OK] opd br2 je ono sto je falilo da bi uspjelo... |
#122 |
Lokacija: nin
Postovi: 133
Driver za NIVIDIA geforce 6600
Posto vec dugo vremena iman ovu NIVIDIA geforce 6600 graficku karticu i jos nikad joj nisan mjenja drivere zanima me koji su naj novi za nju,I gdje ga mogu skinit ako netko zna link za skidanje neka mi ga napise. Unaprijed hvala. |
#124 |
Postovi: 1,431
...del me.. |
#126 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
GeForce 6 Series --> Windows XP / 2000 i time dobijas link na 162.18WHQL drivere. -->
Ako hoces bas 94.24 evo ti LINK za njih. Graphic Driver --> GeForce 6 Series --> Windows XP / 2000 i time dobijas link na 162.18WHQL drivere.
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#127 |
Postovi: 1
Driver za NVidia GeForce Go 7300
Di mogu skinut nove drivere za GO 7300? hvala |
#128 |
White Rabbit
Postovi: 5,326
Hm...www.nvidia.com? |
#129 |
aka Mali Mirko
Postovi: 3,138
Koje forceware drivere danas koristiti za 6800LE (AGP) ?
Dakle sve je u naslovu? Svoju 6800LE još uvijek vozim sa nekim starim driverom v81.95. Da li bi imalo kakve koristi instalirati neki driver serije 160? PS ne prodajem "grafulju" ![]() |
#130 |
Ultrabitchinfast
Postovi: 880
Nemoj popravljati ako nije pokvareno... ![]() mozes probati.., zadnji su 168. serije... za sve kartice.. prijasnji su ti 94.24 prije serije 168. forcewara
Zadnje izmijenjeno od: daytripper. 01.10.2007. u 13:29. |
#131 |
Postovi: 34,072
Instalirao sam frendu jednu takvu prije par dana i koristio sam driver za starije modele (6xxx,...) koji se nalazi na DVD-u od PC Chipa. Mislim da je neki 92.44 ili sličan. Kartica radi bez problema s njima.
#132 |
Lokacija: zagreb-dubrava
Postovi: 70
7300gt driver pitanje
trebao bih drivere da maknem ono sli u trayu sa svakim paljenjem kompa pa ako bi mi netko mogao dati točan link stavio sam najnovije drivere ali nisam riješio problem,ma imao sam taj driver ali sam izbeisao sa memory usb sricka |
#134 |
Ev1LMa5ter
Lokacija: Koprivnica
Postovi: 675
Ja koristim XTreme-G 163.71 i mogu reci da su ok, igram na njima World in Conflict, Company of Heroes, Hitman Blood Money, MOHA, STALKER, Oblivion, FEAR, COD4 i sve igre rade ok.... samo nekad mi se zblesira kod videa u igri, ali sa CTRL+ALT+DEl izadem u wind. i ponovo se vratim i opet je ok...
androidhrvatska.com |
#135 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
xtreme g dere nvidine..
#137 |
Adrenaline junkie
Postovi: 3,593
Preporucljivo je da ih pobrises DC-om iz safe moda.
#138 |
Postovi: 174
nf590sli problem-vista driver
Molim za pomoc. Ovako stvar ide: Instalirao sam vistu ultimate i sve je proslo ok ali kada sam instalirao driver za plocu koja je abit an9-32x fatal1ty koji sam skinuo sam nvidia starnice 15.01 verzije i stariji sa abitove starnice v1500 sistem mi se rusi i javlja ovu gresku royal.sys addres 80442389 base at 8043e000 date stamp 45e7c315 to se dogadja samo sa driverom za plocu za moj chip.HVALA ![]() |
#139 |
In the ghetto
Postovi: 1,943
Koji driver za Gainward Bliss 7950GT 256MB?
Koji driver bi mi preporucili? Do sad nism koristil nijeden drugi nego onaj koji dolazi s njom na CD-u. Jel bolje stavit origigi nvidiin ili neki modani? Inace OS je XP.
#140 |
Postovi: 11,642
Probaj najnoviju verziju Xtreme-G drivera. |
#141 |
In the ghetto
Postovi: 1,943
Jel mi mozes rec koju verziju? Jer tu ih ima dosta a ja nebi htel nekaj zaj*****!
#142 |
Postovi: 11,642
Za XP: XTreme-G 163.75 XP 32bit. |
#143 |
In the ghetto
Postovi: 1,943
Hvala.
#144 |
Lokacija: Požega
Postovi: 706
smetnje sa novim driverima 169.01 i 169.04
evo ovako nikada vidio i nikada cuo takvo sta kada stavim ove drivere kada udjem u igre graficka mi pocme cudno fuckati zvizditi i slika mi na tv-u poludi nesto strasno pocme skakati cim izadjem iz 3D-a vrati se u normalu ![]() |
#145 | |
Lokacija: /
Postovi: 2,053
ali temp. normalne, grafika odlična..ne bunim se ![]() btw. događalo se i prije ^^ drivera |
#146 |
Lokacija: Požega
Postovi: 706
meni je nekad prije zafuckala ali mi je presmjesno sto poludi slika na tv-u koji je udaljen nedno 4 metra da dtugom kraju sobe i na posebnoj je utisnici i osigzracu tako da nije do struje mislim presmjesno |
#149 |
Lokacija: Zagreb,Dubrava
Postovi: 2,281
ej ljudi jeste mozda skinuli crysis demo s nvidine stranice i odmah skinuli nove drajvere??? ak jeste nemojte ih instalirat!!!! vratite se starijim drajverima ja imam gf 66oo i kad sam instaliro nove drajvere svako malo bi mi bilo kakva igra zastekala na tren(vise je stucalo i svakih 30ak sekundi bi mi zastekalo na 5 sekundi)igre tipa:nfsu2 crysis... e sad jel to je zbog moje grafe a mislim da nije kad sam se vratil na starije drajvere sve po plinu(igro crysis na 1024x768 i sve low a shadere na medium i ne trza!!!) pa ak ima netko neka slicna iskustva neka to podijeli a ak se samo to meni desava onda... P.S.-posto se radi o nvidinijim drajverima stavil sam ih tu |
#150 |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja sam skinuo Crysis i imao sam prilično nove drivere još od prije instalirane (sad dal je ona kad sam se s njim zabavljao bila baš aktualna verzija neznam više ali sad je) i meni nije trzalo ništa... Sad nemam crysis demoa vipe na kompu ali ništa od ostalih mi ne trza...
-- Have a nice day... |
