#631 |
lar~
Postovi: 1,557
#632 | ||
1oo1 NooB
Postovi: 1,306
@All: SN Margin (AKA Signal to Noise Margin or Signal to Noise Ratio) Relative strength of the DSL signal to Noise ratio. 6dB is the lowest dB manufactures specify for modem to be able to synch. In some instances interleaving can help raise the noise margin to an acceptable level. The higher the number the better for this measurement. 6dB or below is bad and will experience no synch or intermittent synch problems 7dB-10dB is fair but does not leave much room for variances in conditions 11dB-20dB is good with no synch problems 20dB-28dB is excellent 29dB or above is outstanding Line Attenuation Measure of how much the signal has degraded between the DSLAM and the modem. Maximum signal loss recommendation is usually about 60dB. The lower the dB the better for this measurement. 20dB and below is outstanding 20dB-30dB is excellent 30dB-40dB is very good 40dB-50dB is good 50dB-60dB is poor and may experience connectivity issues 60dB or above is bad and will experience connectivity issues
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#634 |
1oo1 NooB
Postovi: 1,306
#635 |
Postovi: 718
#636 |
Lokacija: n/a
Postovi: 900
Sweet. Me happy. Odličnije od Mr.M-a (onog bez simpson avatara lol ) http://www.imagesforme.com/images/8993screenshot.jpg |
#637 | |
Sruk
Datum registracije: Sep 2004
Postovi: 1,163
t-komovci su idioti, kod nas se zna dogodit da niko u naselju nema telefon po dan-dva...nista....i onda ih zoves sa mobitela i vele, da nemaju saznanja o tome i da je sve u redu i da nema kvara i onda nakon tih dan dva svi telefoni rade....tak da ko zna zasto je kod t.coma pucala veza, kak stvari stoje vjerojatno to ni t.komovci neznaju.kaj se infrastrukutre tice. pa drukcije je nesto, vidis da na amisu, nemas onaj spliter kaj si imo kod t.coma nego ti sve ide preko thompsona...i kad nemas struje u kuci onda nemas ni telefona, jer telefon ti ide preko Thompsona,a bez struje thompson ne radi i nema ni telefona,ni interneta.....zapravo nema niceg bez struje ![]() |
#638 |
Postovi: 86
Ak se ne sjećaš već ste mi takve stvari govorili prije mjesec dana ali od onda još uvijek nije ni jednom bilo problema niti pucanja linka... Zapravo postoji pucanje pppoe konekcije svakih 24h he, he... Evo već sam tri mjeseca na Iskonu i nikad ni jednog problema... Samo sam ih jednom zvao da me prebace u fast mode i to je to... |
#639 | |
1oo1 NooB
Postovi: 1,306
Tvoja veza do centrale je dobra i to je razlog za dobar rezultat. ![]() @bakaideda - ja kad pričam pričam isključivo o online igranju - inače mi net leti sve dok: ![]() ![]()
#641 |
Honda Prelude 2.0i driver
Lokacija: Zagreb Dubrava
Postovi: 1,128
meni je danas veza u banani. pingovi 3 do 5 puta veći i brzina downloada 30-50 %
#642 | |
lar~
Postovi: 1,557
#643 |
Lokacija: Ispred kompa
Postovi: 2,004
Izgleda da amis opet puko danas. Sve ide preko iskona sto je totalno cudno kad imaju svoj debeli lik preko slovenije. Hmm mozda je jednostavno testiranje peeringa sa iskonom iako sumnjam, eto kome treba Tracing route to www.l.google.com [209.85.135.104] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.1.200 2 9 ms 9 ms 9 ms zagreb5-ge-0-1.amis.net [194.146.109.23] 3 9 ms 9 ms 9 ms zagreb2-ge-0-0-0-1.amis.net [194.146.109.1] 4 10 ms 12 ms 9 ms 213.191.134.133 5 10 ms 10 ms 10 ms cat01-vl3.net.iskon.hr [213.191.142.1] 6 10 ms 10 ms 9 ms cat02-vl18.net.iskon.hr [213.191.142.82] 7 75 ms 80 ms * 212.73.203.1 8 79 ms 79 ms 139 ms ge-1-0-0.mp1.vienna1.level3.net [4.68.125.233] 9 92 ms 83 ms 88 ms as-0-0.bbr2.frankfurt1.level3.net [4.68.128.1] 10 98 ms 85 ms 88 ms ae-12-53.car2.frankfurt1.level3.net [4.68.118.80] 11 92 ms 92 ms 89 ms 212.162.4.42 12 86 ms 90 ms 84 ms 209.85.249.180 13 97 ms 94 ms 93 ms 209.85.248.248 14 95 ms 99 ms 202 ms 66.249.94.83 15 102 ms 101 ms * 72.14.239.58 16 98 ms 93 ms 100 ms mu-in-f104.google.com [209.85.135.104] Trace complete.
#644 |
Postovi: 1,128
znači nisam jedini?
#645 |
1oo1 NooB
Postovi: 1,306
tracert www.amis.si Tracing route to www.amis.net [212.18.32.18] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms server.... 2 68 ms 100 ms 99 ms 192.168.1.254 3 8 ms 8 ms 8 ms zagreb5-ge-0-1.amis.net [194.146.109.2 4 8 ms 8 ms 8 ms zagreb2-ge-0-0-0-1.amis.net [194.146.1 5 78 ms 79 ms 70 ms maribor2-so-0-2-1-0.amis.net [212.18.3 6 15 ms 15 ms 15 ms maribor3-ge-2-8.amis.net [212.18.35.74 7 66 ms 65 ms 69 ms www.amis.net [212.18.32.18] Trace complete. ![]() ![]() ![]()
#646 |
Postovi: 2,004
eh sad ocito su s***ali onda rute. jer na amis.si ide preko maribora a sve ostalo ide preko iskona, ukljucujuci i google.si. sto znaci da su im lokalne rute ok ali sav eksterni promet izvan amisa ide preko iskona.
#647 |
Postovi: 1,128
danas ista stvar. pingovi ogromni , download jadan
#648 |
Lokacija: Zagreb - istok
Postovi: 875
#649 |
1oo1 NooB
Postovi: 1,306
*NOTA BENE* U tijeku su radovi na mreži koji su razlogom problema od jučer. To bi trebalo potrajati još nekih 24 sata nakon čega bi se sve trebalo dovesti u red. Dakle očekujte probleme sa netom još jedan dan. Ni meni nije drago ali kaj je tu je... ![]()
#650 |
Postovi: 50
...zakaj se to nas nije moglo obavjestiti ili barem kad sam ih nazvao da mi je download od 6mbit pao na 50Kb i pingovi bogu iza nogu visoki,zakaj nekazu oprostite ili idiote radimo na mrezi strpite se,a ne pa evo sad cemo pogledat u cemu je problem!!!Mislim ono bzvz. |
#651 | |
1oo1 NooB
Postovi: 1,306
Mala je firma a valjda imaju i studente pa ono... EDIT: plus tehnička služba je odvojena od SZK...
#652 |
Postovi: 1,128
hehe meni je Danijela baš ok ja njima poslao:Poštovani, Danas mi je oko 12 h naglo pala brzina downloada. Reconnectao sam se ponovno i nakon toga mi je na speedtestu ping prema mariboru skočio sa 17 na 110 ms a prema londonu sa 55 na 150 ms. Brzina downloada na torrentima mi je max 0.7 mbit a niti na rapidshareu nije puno bolja , ovisno o serveru. Download na speedtest.net mi je još i lošiji. Danas sam dva puta zvao vašu korisničku podršku i rečeno mi je da će mi se javiti međutim još niti glasa. Prilikom online igranja battlefielda2142 pingovi su duplo veći nego prije i nemože se igrati. Jeli problem samo sa mojom paricom ili danas vaša cijela mreža ima problema? Jako sam zadovoljan vašom uslugom međutim mislim da bi bilo uredu da mi onda kažete ako imate problema sa vašim linkom prema van ili ako radite nekakve nadogradnje sustava. nadam se da ćete to brzo riješiti te da se to neće često događati jer planiram uzeti 4 mbit vezu. Hvala , pozdrav! pa onda oni meni:Poštovani, zahvaljujemo na Vašem upitu. Provjera Vaše poteškoće je u tijeku i o ishodu provjere biti će te obaviješteni u najkraćem mogućem roku. Srdačan pozdrav pa onda ja malo poizdim:Poštovani , Saznao sam da jučer nisam samo ja imao problema. Pošto vam link prema Europi opet radi, danas je sa vezom sve u redu, jedino je ping prema Mariboru malo veći no to je nezanemarivo. Ukratko – trenutno sve radi kako treba. naravno radilo je ok još pola sata ![]() i na kraju mi odgovore: Kolege iz tehnike provjeravaju vezano za pingove, no moguće je da još postoje poteškoće vezane s prijašnjim prekidima linka. lp Miro ne kužim kaj se prave grbavi
#653 |
1oo1 NooB
Postovi: 1,306
Njoj skidam kapu - kuži kaj hočeš dok veliš keks i to sredi ako može. Ako ne može veli ti kad bude. Mislim da je problem u internim pravilima pa se večina ne snalazi kaj smije ili ne smije ili kaj treba ili ne treba reči. Imaš masu firmi gdje bossovi zabrane neke normalne stvari pa.... mislim da je pitanje organizacije tj. dezorganizacije. Nemoj zaboravit da su oni novi - ima puno starijih providera koji su veča katastfofa ![]()
#654 |
Postovi: 1,128
ma kužim to s internim pravilima ali živimo u 2007 g informacije su svuda oko nas i dostupne svima. uzmi naš forum za primjer. sve se brzo sazna. zbog toga je glupo da se prave grbavi pošto se sve zna. Danijela ako čitaš ti si nam najcura iz szk i puno te pozdravljamo ![]() hehe sad sam se sjetio , neki dan sam joj poklopio , tj htjela mi je reć da isključim modem i uključim nakon par minuta a čim je ona zaustila isključite modem ja odmah na prekidač i paf-mrtva linija (full sam se glup osjećao )a hebi ga
#655 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
meni je jucer bio ping koma i dl je bio porazavujce nizak zvao sam i danas je recimo ok i ping i dl iako je manji. al ono mene nedira ![]()
#656 |
1oo1 NooB
Postovi: 1,306
#657 |
Lokacija: n/a
Postovi: 900
lol sad će se Codiac baciti na zvanje SZK dok ne dobije Danijelu ![]() btw ja dobivam Marka (zapamtim samo zato jer si zapišem da sljedeći put kad se radi o part2 istog problema, da zovem istog). Al vi znate da im to nisu prava imena? ![]() |
#659 |
Postovi: 1,128
#660 |
Postovi: 2,717
Ev moja veza: ![]() Ping prema Amisu 8ms.
MC |
