Staro 16.08.2007., 23:23   #1
Vidjda
Lokacija: Velika Gorica
Postovi: 18
Da mjenjam nešto ili sutra ujutro ravno za bus za Zagreb?
e ovako
Neš sam skepao, pročitao ukrao itd.
Sad ak bi mogli prokomentirat i dat koji savjet blo bi super.
KOnf:
060008 CPU AMD Athlon64 X2 4000+ BOX, dual core, SckAM2 577,39:p>:p>
:p> :p>
22182 MB Gigabyte M55S-S3, sAM2, nVidia NF550, FW, GLAN, ATX 535,46:p>:p>
:p> :p>
22162 DDR2 1GB PC6400 (800MHz), Kingmax 345,38 x2:p>:p>
:p> :p>
21430 *HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200 578,34:p>:p>
:p> :p>
1130089 Powercolor Radeon X1950GT PCIE, 256MB, TVout, dual DVI 891,27:p>:p>
:p> :p>
7790001 Gigabyte mid tower GZ-X2BPD-100, bez PS, crno, USB, Fire wire, 2×120mm fan, airduct, 1×cd cover 331,96:p>:p>
:p> :p>
21290 Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 500,00:p>:p>
:p> :p>
22198 *Monitor LG LCD L194WT, 1440 x 900 widescreen, 2000:1, 5ms, DVI 1.359,00:p>:p>
:p> :p>
30567 *Labtec Ultra Flat Wireless Desktop USB /967680-0100 159,00 :p>:p>
:p> :p>
3993 LABTEC Pulse 285 3-set, Max-X subwoofer/ 970158-0914 119,00 :p>:p>
neznam koliko je pregledno al dobro
sad ako bi mjenjali neš samo recite- cijena je ukupno aoko 5500 al se može još malo rastegnut
kako bilo hvala
Vidjda je offline   Reply With Quote
Staro 16.08.2007., 23:46   #2
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
...vrlo dobro jefino sklepano,ostavi tako
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
joolka je online   Reply With Quote
Staro 17.08.2007., 00:05   #3
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
solidan komp!
izabrao si dobar lcd,isti takav koristim i nemogu se požaliti na njega osim jedne stvari,a to je malo svijetlija boja po defaultu al uz malo podešavanja i to se popravi!
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 17.08.2007., 00:31   #4
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Pozdrav
Jedino što bi promjenio u toj konfiguraciji je hard disk i uzeo Samsung ili Hitachi sve ostalo dobro možda jedino uzeti i hladnjak ako hočeš, ja bi uzeo ovo:
Cooler ARCTIC-COOLING Freezer 64 Pro, socket 754/939/940/AM2=167KN u Links-u ili gdje več kupuješ odličan hladnjaki operi po clocku.
Sorry na duplom postu pobjeglo mi molim moderatore da obrišu post.
Pozdrav i hvala.
Staro 17.08.2007., 11:57   #5
Vidjda
Postovi: 18
Ipak nisam ujutro otišao.
Vjerovatno ću uzet hlađenje samo me još zaima da uzimam vistu ili da ostanem kod XP ili možda ubuntu?
Staro 17.08.2007., 12:02   #6
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,771
ak je to 19" widescreen, uzmi umjesto njega 19" 5:4
Staro 17.08.2007., 13:03   #7
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
chiefteca probaj poslusati negdje(kod frenda ako ima istoga, ili u ducanu ako imaju negdje vec spojeno) prije nego kupis...
mogao bi ti smetati. zna cvrcati iznutra.. nije vent vec zavojnice ili sto vec..
pa eto obrati paznju... ili baci oko na neko drugo.
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 17.08.2007., 13:27   #8
Buger
Postovi: 4,388
chieftec meni necvrči, ali je malo glasniji, no ako nisi noise freak nije ništa strašno
nemoj uzeti taj 19"WS jer je jednostavno prenizak, ako hoćeš WS onda gledaj minimalno 22"
ploču uzmi "MB Gigabyte MA69G-S3H, sAM2, AMD 690G, VGA, SATA II, GLAN, FW, ATX"
i samo da te upozorim da je ova grafa dobra ako zanemariš dvije činjenice; nema temp. senzor i ima glasan vent!
Staro 17.08.2007., 13:36   #9
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
Za ovaj komp bi bio i više nego dovoljan Chieftec 400W.
I ako uzmeš Seagate 250GB, stane još OVAJ monitor
IBM T43 > Centrino M750 > 2GB DDR2 > 60GB > DVD-RW > 14" XGA
Atom 230 > D945GCLF > 1GB Buffalo > 120GB > DVD-RW > HP L1940
Atom 330 > D945GCLF2 > 2GB G.SKILL > 160GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > GB DDR2 > 80GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > 2GB DDR2 > X1600Pro > 250GB > DVD & DVD-RW > SM932B
X4 9950 > AM2NF3-VSTA > 2x2GB G.SKILL > Parhelia 256 > 2x 640GB > DVD-RW > 2x SM205BW
E6300 > ASUS P5B > 2xGB kingmax > X1900AIW > 2x320GB > DVD-RW & DVD-RW > LG 194WT
dDario je offline   Reply With Quote
Staro 17.08.2007., 13:38   #10
jonyb
jonyb's Avatar
Datum registracije: Apr 2004
Postovi: 887
ploča koju si stavil nije baš nešto, pogotovo ak ne misliš držati na defaultu tog athlona. u tom cijenovnom rangu rađe uzmi:
Gigabyte MA69G-S3H
ili
Gigabyte M55plus-S3G
ak več misliš sve uzeti u ve-milu, umjesto chiefteca uzmi fortrona bluestorm 400 ili 500W, cijenom je tu negdje a puno bolje napajanje.
jonyb je offline   Reply With Quote
Staro 17.08.2007., 13:44   #11
Buger
Postovi: 4,388
bluestorm je dosta slabo napajanje...
Staro 17.08.2007., 14:23   #12
ECHO
Postovi: 2,354
Pozdrav
Nikako "BLU Storm" imam loša islustva s tim napajanjem i preskupo za ono što nudi.Problem je što u Ve-milunema izbora ili "čufteka" ili Fortron i to THN verzije koje su slabe a ostatak ponude preskup 7-8 stoja kuniča.
Više se isplati naručit napajanje i platit poštarinu nekih37-42kn i uzeti pošteno
tipa Coolermaster 430W ili Seeasonic 430W dotično imam i radi super(5) ili nešto slično.
Staro 17.08.2007., 14:45   #13
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
sve 5 osim napajanja i monitora
čuftek je glasan
monitor je prenizak..rade si onda pikni 5:4 ili ako bas oces wide onda si zemi neki 22"Wide (imaš podosta tema o 22 wide monitorima ovdje http://forum.pcekspert.com/forumdisplay.php?f=52 )
te o napajanjima ovdje http://forum.pcekspert.com/forumdisplay.php?f=57
Staro 17.08.2007., 15:45   #14
Vidjda
Postovi: 18
Hvala na svjetima - uzimam ih u obzir.
hvala i pozdraw
Staro 17.08.2007., 20:26   #15
fiuman 1980
Postovi: 16
čuftek je glasan
A baš sam ga namjeravao uzet
Biš li mogao neš sugerirat?
Zar je baš toliko glasan ?
Fala
fiuman 1980 je offline   Reply With Quote
Staro 17.08.2007., 20:31   #16
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Gle slobodno ubodi ćufetka ako ti ne smeta zujanje venta iz casea, iako se i tome može doskočiti sa zamjenom venta onda pušiš garanciju a to IMHO nema smisla, da ne spominjemo da moraš kupiti vent jel...
Have a nice day...
Staro 18.08.2007., 16:13   #17
jonyb
jonyb's Avatar
Postovi: 887
Autor tdominov Pregled postova
meni je npr. obični fortron 400w prdnuo a 350w i blustorm rade još i dan danas tak da je to relativno.
istina bluestorm je malo preskup ali u ve-milu i nema neki izbor... tak da je moja preporuka bila ograničena na vemuljce.
najbolje je za tu lovu uzeti seasonic.
Staro 18.08.2007., 16:43   #18
yedwy
yedwy's Avatar
Postovi: 6,956
Pod "obični Fortron" pretpostavljam da misliš na THN a BlueStorm je isto THN samo ofarban i sleevan...
Inače nisi mi javio jel ti sve ok bilo s CPUom...
Have a nice day...
Staro 19.08.2007., 15:27   #19
jonyb
jonyb's Avatar
Postovi: 887
Autor yedwy Pregled postova
moj je AX500-A, ali kad se bolje pogleda ista stvar ko i THN.
sve šljaka kak spada
Staro 20.08.2007., 19:57   #20
Vidjda
Postovi: 18
ma upravo am došaao iz vemila od moje konf nemaju više napajanje ni kučište. novo kučište sam našao al napajanje nisam znao koje - nudio mi je fortron 500w ali sam se sjetio da se neš pričali da i nije neko.
jel mi možete onda preporučiti koje drugo iz vemila iako nije ponuda neka ili ću morat uzet fortron.
Također sam vidio philipsov monitor koji mi se svidio pa se sad dvoumim između njega ili ovog widescreen. Šta vi kažete?
Philips:
http://www.vemil.hr/opis.aspx?prikaz...&Sifra=1111001
LG:
http://www.vemil.hr/opis.aspx?prikaz...=0&Sifra=22198
nadam se pomoći
Staro 20.08.2007., 20:06   #21
Buger
Postovi: 4,388
fortron 500W je dobro ali užasno glasno napajanje (osim ako nemisliš na BS, koji je tih i slabašan)
Staro 20.08.2007., 20:11   #22
Vidjda
Postovi: 18
ma ovaj
http://www.vemil.hr/opis.aspx?prikaz...e=0&Sifra=3792
kaj onda da uzmem taj s obzirom da nema chieftec 550w?
Staro 20.08.2007., 21:00   #23
tech
Postovi: 1,687
Umjesto toga 550w, uzmi Fortrona 400W PNF....
Staro 20.08.2007., 22:17   #24
Vidjda
Postovi: 18
Misliš na ovo:
http://www.vemil.hr/opis.aspx?prikaz...te=0&Sifra=752
ili?
Cijena može biti i veća (do 700) al da bude iz vemila,
Staro 20.08.2007., 22:29   #25
yedwy
yedwy's Avatar
Postovi: 6,956
AFAIK nema PNFa u VeMulju samo THN...
Ako baš mora bit iz VeMulja Chieftec 550W ili 650w, Eventualno malo skuplji OCZ drugo nema smisla...
Have a nice day...
Staro 20.08.2007., 22:41   #26
Vidjda
Postovi: 18
ma kad pola toga više nema u vemilu - većina je izvan zg.
Kaj znači opće - dobavljivo po narudžbi?
Umjesto starog kučišta odabrao sam ovo koje ima napajanje -
http://www.vemil.hr/opis.aspx?prikaz...&Sifra=7750009
jel mi treba onda neko drugo?
Staro 20.08.2007., 22:45   #27
yedwy
yedwy's Avatar
Postovi: 6,956
Da modecom je drek od napajanja...
Meni je nedavno dopalo u ruke jedno od kojeg sam jedino iskoristio 12cm fan...
Long story short - peglanje napona kod ovoga ne postoji, Prenosi 50Hz šum na zvučnike od kompa kroz ploču, jel ti trebam slikati kaj to radi sa kondenzatorima?
Kad sam skužio odma je letilo iz kompa iste sekunde...
A zašto baš mora bit u VeMulju? Imaš u ADMu PNF Fortrona od 400w ili u linksu seasonica 430w i chiefteca po drugim dućanima, enermaxa, silverstonea...
Have a nice day...
Staro 20.08.2007., 22:56   #28
Vidjda
Postovi: 18
ma ja se ne kužim u slaganje kompa a kupujem u ve milu ostatak konfiguracije pa ne vjerujem da bi m ju htjeli složit ak donesem djelove iz drugih trgovina - kaj ne?
Staro 20.08.2007., 23:22   #29
Quick22
Quick22's Avatar
Lokacija: Zagorje
Postovi: 113
Autor Vidjda Pregled postova
To ti znači da ti kod njih naručiš, i onda kad oni tu robu naruče (postane dostupna za prodaju) jedan primjerak je rezerviran za tebe ... barem sam ja jednom imal takav slučaj .. a "robu" sam čekal jedno 3 - 4 dana kolko se sječam
Quick22 je offline   Reply With Quote
Staro 20.08.2007., 23:33   #30
tech
Postovi: 1,687
Ja sam u ve-mulju uzo tog 350W fortrona PNF i nije fejk tih ni ne cujes ga...
