Postovi: 74
Konfiguracija za oko 6000 kn
Trebalo bi mi složiti neku dobru gaming konfiguraciju za 6000 kn (bez monitora i periferije) za oko 6000 kn. Pošto sam iz Rijeke izbor bih suzio na Links i Ve-mil. Unaprijed zahvalan! ![]()
Intel Core 2 Duo E6300 ThermalTake Silent Tower Gigabyte DS4 2 GB Kingmax 3D Club 7900GS Seagate 320 GB 7200rpm 16MB Chieftec 400W |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Pozdrav
CPU INTEL Core2Duo E4400 2000MHz BOX, socket 775, 2Mb c., FSB 800MHz, 64 bit, DualCore=885KN MBO GIGABYTE P35-S3, iP35, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775=800KN RAM PC-5300, 2048MB, DDR2, CRUCIAL, 667 MHz=709KN HDD 320.0 GB SAMSUNG, Serial ATA II, 16MB cache, 7200 okr/min=564KN VGA PCI-E POINT OF VIEW, GeForce PCX 8800GTS, 320MB DDR3, 2 DVI-I, TV-Out=2.310KN Napajanje COOLERMASTER 430W, RS-430-PCAP, Super Silent, eXtreme power, ATX2 v2=400KN DVD±RW NEC AD-7173A, 18x, crni, Dual layer ± recording, LabelFlash, bulk=236KN Ovo je složeno u Links-u cijena 5.930KN treba samo kučište, a to je mislim osobni izbor. Ovo je složeno u vemilu:cijena 5.742KN isto bez kučišta. Intel Core 2 Duo E4300 BOX, 2×1.80GHz, 800MHz, 775-pin, 2MB=846KN MB Gigabyte P35-DS3, s775, iP35, DDR II, SATA II, GLAN=834KN DDR2 1GB PC5300 (667MHz) Kingmax X2=608KN HDD HITACHI HDT725032VLA380 320GB SATA-300 7200rpm 8MB=543KN Gigabyte GF 8800GTS, 320MB DDR3, TV-out, Dual DVI=2.085KN Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors=500KN DVD+RW/-RW/RAM LG GSA-H42N Dual Layer, 18x, retail, black=226KN Thermaltake CL-P0323, Sonic Tower rev.2,AlCu, pas.hladnjak bez ventilatora,sck AM2/775/939/754, 0 dB=250KN Glacialtech Silent Blade BLACK, 120x120x25mm, 19dBA=47KN Naravno uvjek može bolje i sačekaj ostale. ![]() |
Čiča s tamića
Lokacija: Prezid
Postovi: 326
ova druga confa je ok, možda jedino da se doda e4400 i to je to-razlika je 40kn
moj komp no2: Intel Pentium 4 Prescott 2.8GHz @ 3.4GHz, 1GB RAM 400 MHz @ 450 MHz, ASUS P4S800, Club 3D 7600GS AGP @ 470/450, 80GB WDC , 400W MS Industrial moj komp3: Intel Pentium 3 800MHz, 20GB HP HDD, 256 MB SDRAM, 200W CODEGEN PS, NvIdia TNT RIVA 32, MBO:MS-6309 LITE |
Postovi: 74
Biti će druga, jedino s razlikom što ću za cooler uzeti Thermaltake mini Typhoon. Puno hvala.
Postovi: 2,354
Pozdrav
Zašto drugi cooler??? http://www.vemil.hr/opis.aspx?prikaz...=0&Sifra=22420 ili taj ili onaj koji sam preporučio radi savršeno i nije problem namontirati Sonic Tower+ventilator izađu isto.Imam dotičnog i prezadovoljan sam.Samo savjet. ![]() Ma nema problema ti stavi šta hočeš ja sam samo preporučio dotično jer obično kad stavljam neke stvari gledam da budu"najbolje" jer nikad neznaš šta (čovjeku pirne u glavu i odluči se na nešto_overclock) a cijenom su tu negdje i hlađenje je savršeno,možda če za par mjeseci-godinu iči na neki drugi proc tipa 6750 ili Q6600 pa neka se nađe. Zadnje izmijenjeno od: ECHO. 16.08.2007. u 17:05. |
Postovi: 74
Ma to slažem za frenda koji neće raditi nikakav ekstreman overclock. Mislim kako mu ne treba big typhoon ili sonic. Ja imam Silent Tower (negdje po performansama kao mini Typhoon) i stvarno radi odlično.
