Postovi: 24
![]() evo ovo sam si planiral uzeti Zvučna: TerraTec SoundSystem Aureon 5.1 PCI Napajanje: Power Supply FORTRON BlueStorm 500W, HQ, PFC, 2x12V, 12cm fan Memorija: DDR 1GB PC3200 (400MHz), CL2, SuperTalent Kučište: Thermaltake VC3000BWS tower Armor Jr., bez PS, alu-maska, crno, USB, Fire wire, 2×12cm fan, prozor Hlađenje: Chieftec AF-0925S, 92mm hladnjak za kućište, crni Grafa: Powercolor Radeon X1950Pro Xtreme PCIE, 256MB, TVout, dual DVI Hard: *HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB Matična: MB Gigabyte M61P-S3, sAM2, GeForce 6100, VGA, SATA, FW,GLAN Procesor: Intel Core 2 Duo E4500 BOX, 2×2.2GHz, 800MHz, 775-pin, 2MB evo mene sada zanima je li ova konfiguracija dobra te treba li unijeti kakve promjene buđet mi je do 5000kn tak da imajte to u obziru EDIT: ako bi mi netko mogao složiti gejmerski komp do 5000 kuna bio bih mu silno zahvalan platim pivu (ne treba monitor samo kanta) Zadnje izmijenjeno od: Ardashir. 15.08.2007. u 15:13. Razlog: Konfa do 5000 kuna |
Postovi: 7,568
1. Prijedlog:______________________________________________ Procesor: Intel E4400, sck. 775, BOX - 808 kn (Acquisitum Magnum) Matična: Gigabyte P35-DS3, sck. 775 - 740 kn (Acquisitum Magnum) Memorija: 2x1GB Crucial DDR667 - 590 kn (Links) Grafička: PowerColor X1950Pro Xtreme - 1.134 kn (Ve-mil) Hard disk: 320GB Hitachi SATA II - 559 kn (Links) DVD/RW: LG GSA-H42N, Black - 219 kn (Ve-mil) Napajanje: CoolerMaster 430W, 12cm FAN - 398 kn (Links) Kućište: Antec NSK 6000 - 434 kn (Acquisitum Magnum) _________________________________________________________ Ukupno: 4.882 kn.....sve iz različitih dućana 2. Prijedlog:____________________________________________ Procesor:Athlon64 4000+ X2, sck. AM2, BOX - 522 kn (Links) Matična:
Grafička: Asus 8800GTS 320 - 2.000 kn (Ve-mil) Hard disk: 160GB Samsung SATA II - 363 kn (Links) DVD/RW: LG GSA-H42N, Black - 219 kn (Ve-mil) Napajanje: CoolerMaster 430W, 12cm FAN - 398 kn (Links) Kućište: Sharkoon Rebel9 EE - 321 kn (Links) _______________________________________________________ Ukupno: 5.036 / 5.043 kn.....sve iz različitih dućana |
Postovi: 24
fala ti a daj mi samo reci što je s hlađenjem? |
Prečupavi mod
Postovi: 9,107
Pa svi procesori su BOX, dakle imaju svoj hladnjak, grafulje ionako imaju hladnjake. Ti bi nesto skuplje, tise, mozda za OC? I btw, sta ce ti ovo: PCI kontroler USB 2.0 4+1 port, VIA chipset, CONNEX /6401110 ?
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
Postovi: 7,568
Kartice imaju na sebi čist vredu tvorničke coolere tak da se s tim ne trebaš zamarati. Kod procesora su i stock cooleri dosta za umjeren overclock, ali ako ti ne budu odgovarali lako kupiš kakav Freezer ili HyperTX. Za kućište si izabereš coolere koji ti najbolje odgovaraju. Imaš na forumu dosta tema di ljudi pitaju koje odabrati, a pošto se uvijek preporučuju isti modeli, prošvrljaj malo i vidi dal ti kaj od toga odgovara. |
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
uz to sto SU veli, sto ce 10/100 lan kartica kad ima GLan na maticnoj?
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() |
Postovi: 24
imam negdje 8 uređaja koji zahtjevaju usb i još tolko koje koriste usb jer ih moram produživat...kao tipkovnica i miš EDIT: evo sredio sam to |
Prečupavi mod
Postovi: 9,107
Ako mislis vec uzimati USB kontroler, onda svakako uzmi: http://www.vemil.hr/OpisMP.aspx?Sifra=513471 VIA chip zna stvarati velike probleme, za razliku od NEC-a koji radi OK.
Postovi: 24
Neke sam stvari promijenil a neke ostavil pa sada to izgleda ovako ![]() Procesor: Intel Core 2 Duo E4400 , 2.0GHz, socket 775, 2Mb cache, Matična: Gigabyte P35-DS3L, s775, intel P35+ICH9, FSB 1333 4xsata gblan Kućište: SHARKOON Rebel9 Economy-Edition, MIDI, crno, bez PS Napajanje: COOLERMASTER 430W, RS-430-PCAP, Super Silent, eXtreme power, ATX2 v2 Hard disk: HDD 160.0 GB SAMSUNG SpinPoint, Serial ATA II, 8 MB cache, 7200 okr/min Memorija: 2X RAM PC-5300, 1024MB, DDR2, KINGMAX, 667 MHz Grafulja: Powercolor Radeon X1950Pro Xtreme PCIE, 256MB, TVout, dual DVI Optički: DVD+RW/-RW/RAM LG GSA-H42N Dual Layer, 18x, bulk, black Zvučna: TerraTec SoundSystem Aureon 5.1 PCI Treba li nekaj mijenjat ili može ostati ovako? Zadnje izmijenjeno od: Ardashir. 15.08.2007. u 17:22. |
Postovi: 838
nemres parirati DDR i DDR2, tako da prodaj DDR i kupi si jos gigu DDR2, sad su cijene smijesne. |
Postovi: 24
Lokacija: korcula
Postovi: 251
ova zvucna ti je samo trosak jer ova na maticnoj je sasvim dovoljna za sve sto ti treba naravno ako se nebavis zvukom u tom slucaju negledaj ovo :-) |
Postovi: 24
evo komp sam kupio, no nekih stvari nije bilo u dućano kao matične i rama tako da sam morao uzeti neke druge, a sve ostalo je ostalo isto..nadam se da sam dobre zamjene uzeo Procesor: Intel Core 2 Duo E4400 , 2.0GHz, socket 775, 2Mb cache, Matična: Gigabyte P35-DS3, s775, iP35, DDR2, SATA II, GLAN Kućište: SHARKOON Rebel9 Economy-Edition, MIDI, crno, bez PS Napajanje: COOLERMASTER 430W, RS-430-PCAP, Super Silent, eXtreme power, ATX2 v2 Hard disk: HDD 160.0 GB SAMSUNG SpinPoint, Serial ATA II, 8 MB cache, 7200 okr/min Memorija: 2X RAM PC-6400, 1024 MB, DDR2, PATRIOT, 800 Mhz Grafulja: Powercolor Radeon X1950Pro Xtreme PCIE, 256MB, TVout, dual DVI Optički: DVD+RW/-RW/RAM LG GSA-H42N Dual Layer, 18x, bulk, black |
Postovi: 1,450
sve 5 ![]() |
