Staro 15.08.2007., 12:12   #1
darkijas
darkijas's Avatar
Postovi: 1,804
gainward 7800gs+512 mb 1324kn (hgspot)
evo malo životne radosti za sve ljubitelje agp-a. Ukoliko se radi o onoj kartici sa g71 čipom mislim da vrijedi svake lipe..
darkijas je offline   Reply With Quote
Staro 15.08.2007., 13:03   #2
nodavilp
pUtNiK
nodavilp's Avatar
Datum registracije: Feb 2004
Lokacija: na forumu
Postovi: 342
"Gainward's AGP is a wolf in sheep's clothing"
mi se isplati prodat 9800xt i kupit ovog "vuka" i uparit ga s athlonom na 2,5ghz i gigom rama ?
nodavilp je offline   Reply With Quote
Staro 15.08.2007., 13:06   #3
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
nekako mi se za 100 kn ovo cini boljom investicijom !
http://www.links.hr/index.php?naziv=...kl=051.803.346
Staro 15.08.2007., 13:28   #4
darkijas
darkijas's Avatar
Postovi: 1,804
Autor Željac Pregled postova
Pa ako je ovaj gainwardov model onaj sa punokrvnim g71 čipom dakle 24pp8vs plus 512mb memorije definitivno je bolja kupnja od ovog xfx 20/7 256mb.
Ulkoliko pak GAYinward ima čip od 7800gt modela xfx je isplativiji
Staro 15.08.2007., 13:40   #5
nodavilp
pUtNiK
nodavilp's Avatar
Lokacija: na forumu
Postovi: 342
GAINWARD, BLISS 7800GS 512 GS+ DDT, 512 MB,
-Memorija 512 MB 1.2ns DDR3, 256 bita,Memory clockspeed 1250 MHz,ova ima vise memorije i i brzu memoriju
-GPU clockspeed 425 MHz
GeForce PCX 7900GS 450M, 256MB GDDR3
-256 MB GDDR3 1.4 ns 1320 MHz
-GPU clockspeed 450 MHz
ova iz hgsrota je jeftinija ima stariji chipset, ali vise memorije i brzu memoriju, "If you compare the standard 7900GS vs 7800GS, the 7900GS wins hands down. 7900GS has a little bit faster clocks for both core and memory, has 12 ROPs vs 8, has 20 pixel shaders vs. 16, has 7 vertex shaders vs. 6. In addition it has the few optimizations the G71 has over G70 ( some 7800GS cards are based on the G71 core though)."
1.ako ova gainward ima G71 cip, cu je onda moc otkljucat ili neku fintu napravit da dobim 7900
2.gainward ima vise memorije kolko je to bitno ? cu osjetit razkliku izmjedu 256 i 512mb ?
3.imam 5% popusta u linksu tak da cijenovno dodju skoro isto
Staro 16.08.2007., 02:33   #6
darkijas
darkijas's Avatar
Postovi: 1,804
gainwardovi "special" 7800gs+ modeli nemaju puno veze sa modelima ostalih proizvođača (referentni nv 7800gs su zapravo osakaćeni 7800gt čipovi sa samo 16pp proizvedeni u 1,10nm proizvodnom procesu-te kartice 7900gs popapa za doručak). Gainward je jedan od rijetkih koji je ispod 7800gs"haube" ugrađivao gpu iz pci-e modela 7900gt/7950gt/7900gtx. mislim da je na ovoj iz hgspota mema 1,4ns(gainward u 7800gs modele nije ugrađivao 1,2ns memoriju) ukoliko se radi o punokrvnom g71 (postoji dvojba jer je gainward izbacio dva slična modela, prvi special 7800gs je imao gpu od pci-e kartice 7800gt a nešto kasnije se pojavio 7800gs+ sa čipom iz 7900gt) nema se tu šta otključavat, samo klokaj i deri!
Naravno uvjek postoji i alternativa, ak nemaš ništa proti ati-ja možeš recimo u adm-u nabavit sapphire x1950gt agp za 1050kn, to je isto jako dobra kartica za agp i definitivno je isplativija od 7900gs u linksu
Staro 16.08.2007., 07:30   #7
peroW1
peroW1's Avatar
Lokacija: Croatia Čk
Postovi: 551
Gor for it ako mislis ostati na toj konfi jos neko vrijeme.
Imao sam ja 7800GS+ i zmaj od kartice sto se tice AGP-a.
7800GS = 7800GT (20/7)
7800GS+ =7900GT (24/8)
Ovo GS je Gainwardov znani "Golden Sample", a nVidia je kasnije ubacila taj naziv u svoje oslabljene modele.
Btw..ima ju kolega De5troyer,pa ti on moze dati info,znam da ju je zvjerski naklokao.
i5 2550K 4.1GHz *Gigabyte Z77-D3H, 32 GB RAM KINGSTON HYPER X FURY, ASUS GTX 1060Ti , SSD 1TB, CoolerMaster 850W, ASUS 32'' 4K
peroW1 je offline   Reply With Quote
Staro 16.08.2007., 11:37   #8
nodavilp
pUtNiK
nodavilp's Avatar
Lokacija: na forumu
Postovi: 342
x1950gt agp za 1050kn...hmm, da alternativa.
morat cu malo proucit testove na netu pa odlucit.
btw hvala
Staro 17.08.2007., 00:05   #9
darkijas
darkijas's Avatar
Postovi: 1,804
uh tek sad vidjeh, na cjeniku od adm-a za ovog sapphira piše da je 128bit, vjerovatno su krivo napisali ali ipak valja provjerit prije eventualne kupnje
ista kartica u optimumu 1011kn
Zadnje izmijenjeno od: darkijas. 17.08.2007. u 12:07.
Staro 17.08.2007., 09:36   #10
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
ako je to 7800gs+ onda kupuj narode. iako sumnjam, gs+ grafa je napravljeno 10k komada, ja kad sam kupio u linksu je bila zadnja u hrvatskoj, kad sam nosio na servis pod garancijom rekli su da nema vise uopce te graficke niti u tvornici.
inace pogled na cjenik iznad gs+ je "obicna" gs i cijena je 2k kn visa. mora da je neka greska...
Spoiler alert!
Staro 17.08.2007., 15:59   #11
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
..mali OT..ali u srazu s temom..da li je 7950GT iz linksa najbrža AGP kartuša trenutno..512mb DDR3...2000 i nešto sitno kuna....da je malkice barem jeftinija..hm..
Staro 17.08.2007., 16:56   #12
darkijas
darkijas's Avatar
Postovi: 1,804
ma ta 7950gt je totalno neisplativa, zapravo isti gpu i jednaku količinu jednake memorije bi trebao imati i ovaj gainward, samo sa manjim tvorničkim klokovima.
Staro 18.08.2007., 15:00   #13
Fera_os
Ne znam šta da napišem
Fera_os's Avatar
Postovi: 984
Podrazumijeva se da je neisplativa ali Thedream to nije pitao nego je pitao koja je najbrža kartica na AGP-u i još je sam reko da je barem jeftinija.
Nemam ništa pametno za reć!
Fera_os je offline   Reply With Quote
Staro 18.08.2007., 15:08   #14
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
stock je 7950gt najbrza. ali sumnjam da se da klokat ko 7800gs+...
sa stocka od 450 (ili 425 nisam ziher) bez vmoda ili icega na 610 radi... a da ne govorim o kvaliteti kulera na 7950 naspram gs+...
Spoiler alert!
