Staro 14.01.2004., 11:06   #1
Univited noob
Univited noob's Avatar
Postovi: 55
ATI radeon 8500
e kako san pomorac nea me često doma tako da nemogu pratit sve događaje i vjesti....pa bih zamolija da mi date nekake sheme za ovu moju kantu...tipa programi drajveri i šta da napravim...inače sam i komplitli noob u tome...pa bi i koji tutorial doša ka mana sa neba...plus toga da overklokiram ovo???i ako da kako...molim vas??help noob
Univited noob je offline   Reply With Quote
Staro 14.01.2004., 19:03   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Sory ali ništa te nisam skužio. Kanta je inače naziv za cijeli komp (kučište i ono u njemu) a ti si napisao u naslovu model grafičke. AK ti trebaju driveri, postupak instalacije i tome slično reci. Ali ajd prvo navedi ostatak kompa i jel si ti sad kupio novu grafulju pa bi je htio ubaciti, ili hočeš reinstalirati windoze itd... Malo pomoči pa onda i mi tebi možemo.
tor je online   Reply With Quote
Staro 14.01.2004., 20:43   #3
Univited noob
Postovi: 55
Manufacturer: AMD
Family: AMD Athlon(tm) XP 2000+
Internal Clock: 1.68 GHz
Internal Clock Maximum: 1.68 GHz
External Clock: 133 MHz
Socket Designation: Socket A
Type: Central
Upgrade: ZIF Socket
Capabilities: MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version: Model 6, Stepping 2
CPUID: 0x00000662
SERIES
Description: Primary Display Driver
Manufacturer: ATI Technologies Inc. (Omega 2.5.04)
Name: RADEON 8500 SERIES (Omega 2.5.04)
Total Local Video Memory: 64 MB
Total Local Texture Memory: 64 MB
Total AGP Memory: 53 MB
Display Driver: ati2dvag.dll
Display Driver Version: 6.14.10.6404
Driver WHQL Certified: Yes
Max Texture Width : 2048
Max Texture Height: 2048
Max User Clipping Planes: 6
Max Active Hardware Lights: 8
Max Texture Blending Stages: 8
Textures In Single Pass: 6
Vertex Shader Version: 1.1
Pixel Shader Version: 1.4
Max Vertex Blend Matrices: 57
Max Texture Coordinates: 6
Vendor ID: 0x1002
Device ID: 0x514c
Sub-System ID: 0x013a1002
Revision: 0x00
eto to je to...a sad ako bi moga pomoć da mi kažeš koje programe za overklok....koje drajvere da koristim i kako da podesim svoju karticu....da radi malo lipše...
kanta(ma sve manje više....)TNX za trud...
Staro 14.01.2004., 21:24   #4
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Lijepo ti nama reci ako znaš koja je to grafa-LE ili "pravi" 8500, dakle pogledaj kaj ti piše na kolikom taktu ti radi GPU i memorija.
Da li je 250-250 ili 275-275.
U BIOS-u si možeš komotno promjeniti iz 64 u 128 MB.(AGP Aperture Size)
Nove drivere imaš-eventualno si skini i instaliraj RadClocker.
Staro 15.01.2004., 00:05   #5
ZMAJ
Postovi: 2,937
jos bu si podkurio grafu lol...
nek kaze odmah i tvrtku
ZMAJ je offline   Reply With Quote
Staro 15.01.2004., 00:05   #6
Univited noob
Postovi: 55
250-250 mi je...e pa da te pitam šta to znači...mislim valjda je to lošije...jel?i u biosu to promjenim i bi ce 128...ludilo...mislim znam da pilam gluparijama ali moj nick ti kaže sve...tnx na trudu još jednoom
Staro 15.01.2004., 00:18   #7
Univited noob
Postovi: 55
e da zaboravih reć proizvođač je manli...ako može pomoć...
Staro 15.01.2004., 00:40   #8
Srky
Srky's Avatar
Postovi: 3,263
Uh.... Manli, tesko da ce bit onda sta od clocka
Staro 15.01.2004., 00:44   #9
Univited noob
Postovi: 55
nea veze ako nemože...šta je taj proizvođač neki u grču...??
pa jeli može barem ta shema sa biosom šta je Jelc spominja...?
Staro 15.01.2004., 00:56   #10
Srky
Srky's Avatar
Postovi: 3,263
Ma taj Manli ti je jedan od losijih ako ne i najlosiji proizvodjac grafulja tak da sumnjam da ces moci neznam kako clockat ali vrijedi pokusat.
Ono s aperture size sto ti je Jelc reko napravi u BIOS-u cisto zbog toga da bi ti normalno radilo ali neces dobit neznam kako na performansama. Stavi si neki program za clockanje i baci se na poso pa ces vidit dokle ide Manli...
Staro 15.01.2004., 01:01   #11
Univited noob
Postovi: 55
hvala srky...e da te pitam...program za clock...skinija radeonator neam pojma mnogi ga hvale sad jeli istina ili ne...i dokle mogu svoju kloknit...a da radi ok da se nešto nepregrijava....e i šta je jelc reka RadClocker nigdi nemogu nać taj program za download...pa ako znaš odakle bi ga moga skinit....
Staro 15.01.2004., 01:14   #12
Srky
Srky's Avatar
Postovi: 3,263
nekuzim se bas u programe za ATI kartice, to nek ti Jelc preporuci al sto se tice clockanja princip je isti kod svih, znaci ako ti sad po defaultu radi na 250/250 ti je povecaj u malim koracima po recimo 10Mhz i onda vrti malo testove (3dmark) ili neke igre pa ces vidit jel stabilno ili nije, u slucaju da ti se smrzne ili pocne bacat crtice (artiefekte) smanji clock za 5Mhz i sve tako dok ne nadjes neke stabilne freqve. Probaj za pocetak stavit 275/275 pa ces vidit kak ti se ponasa. Sretno!
Staro 15.01.2004., 01:18   #13
Univited noob
Postovi: 55
ok hvala na trudu pokušat ću pa bumo vidili....
Staro 15.01.2004., 15:16   #14
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Što se tiče OC-anja. MOci ces dosta OC-ati GPU ali memoriju skoro pa nimalo. Ja sam sa defaulta (250/250) uspio doc do 285/255. Nisam isao dalje sa GPU-om jer mi ovaj hladnjak bas i nehladi najbolje.
Staro 15.01.2004., 15:22   #15
Univited noob
Postovi: 55
e hvala primjetia san to san to sinoć...a nisi mi reka priko čega radiš OC
