Staro 08.07.2007., 03:47   #1
Bishop_45
Sith'ari
Bishop_45's Avatar
Postovi: 18
Question Novi comp ???
Ok, recimo da sam uspio ustediti 13k kn, i sada bih kupio novi comp i monitor, ali neznam odakle poceti !!!; moze pomoc u slaganju nove konfiguracije ???
Bishop_45 je offline   Reply With Quote
Staro 08.07.2007., 08:39   #2
Postovi: 34,029
Šta bi ti s njime - igre, 3D, video obrada, sve pomalo,...?
Staro 08.07.2007., 13:42   #3
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
Gigabyte 965P-DS3, s775, i965, FSB 1066/800/533MHz, v3.3 733KN
Procesor Intel Core 2 Duo E4400 , 2.0GHz, socket 775, 2Mb cache, 911KN
4x DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , CL5 999KN
Point Of View GeForce 8800GTS EXO, PCI-Ex16, 320MB DDR3 2098KN
HDD Seagate 320GB, Serial ATA II, 7200 rpm, Barracuda 7200.10 579KN
Napajanje CHIEFTEC 550W, EPS, 120mm ventilator, Active PFC 479KN
THERMALTAKE Soprano VB1000BWS, MIDI, black, bez napajanja 532KN
Samsung monitor SM225BW, 22" LCD, 1680x1050, 280cd/m2, 700:1, 16 2939KN
Ukupno: 9311KN
Fali optički pogon ali to si izaberi i stavi.ako oces uzmi monitor samsung 226BW.i za ostatak pojacaj jos nesto ako bas oces da bude 13000KN ali mislim da se ne isplati.
AMD konfa:
Procesor AMD Athlon 64 X2 3800+ , socket AM2, BOX ! ,0.09, 1024K 564KN
Gigabyte M59SLI-S4,nForce 590 SLI 899KN
Point Of View GeForce 8800GTX 768MB (1.1ns) 2xDVI2 HDTV/HDCP 4124KN
U ovu sam stavio 8800GTX jer sam iso sto blize 13000kn posto si reko da bi komp od 13000kn.ali mislim da se ne isplati stavit gtx.dovoljna je gts.ali ako ti oces stavi sebi tu gtx.i ako oces stavi x2 5600+
Obe su konfe iz adm-a.
I u obe fali opticki pogon.
Tekla je offline   Reply With Quote
Staro 08.07.2007., 13:59   #4
Postovi: 7,568
Prijedlog:__________________________________________________
Procesor:
  • Intel E4400, sck. 775, BOX - 911 kn (Acquisitum Magnum)
  • Intel E6420, sck. 775, BOX - 1.272 kn (Acquisitum Magnum)
Matična:
  • Asus P5B-E Plus, sck. 775 - 1.070 kn (Acquisitum Magnum)
  • Asus P5K Deluxe, sck. 775 - 1.869 kn (Acquisitum Magnum)
Memorija: 2x1GB Crucial Ballistix DDR667 - 622 kn (Links)
Grafička:
  • Point Of View 8800GTS 640 - 2.692 kn (Acquisitum Magnum)
  • Sapphire 2900XT - 2.839 kn (Acquisitum Magnum)
  • Point Of View 8800GTX - 4.125 kn (Acquisitum Magnum)
Hard disk: 500GB Samsung, SATA II - 871 kn (Links)
DVD/RW: LG GSA-H42N, Black - 218 kn (Links)
Napajanje: Corsair HX-520W, 12cm FAN - 759 kn (Optimum)
Kućište:
  • Chieftec LBX-02B-B-SL - 480 kn (Acquisitum Magnum)
  • Antec Solo - 662 kn (Acquisitum Magnum)
Monitor: Dell E228WFP - 3.183 kn (M-Computers)
__________________________________________________________
Ukupno: 10.806 / 13.581 kn.....sve iz različitih dućana
Staro 08.07.2007., 18:32   #5
Bishop_45
Sith'ari
Bishop_45's Avatar
Postovi: 18
Autor coconut Pregled postova
Igre; maya, photoshop; pa da, zapravo sve pomalo....
@Tekla; lol, ne mora biti nuzno 13k, vazno mi je da to funkcionira ... dulje vrijeme; dok cijena, ona moze biti tako oko 13k max
moze prijedlog za 19'' monitor , jer mi je 22 jednostavno preveliko, .. doslovo, nema shanse da mi stane na stol :lol:
i, intergrirani zvuk, je to ok?, jer imam 5.1 sustav; a zvucna i nije nesto sto cu mijenjati svakih 2-3-4 god., za razliku od grafe npr !!!
BTW... thx !!!
Staro 08.07.2007., 18:36   #6
WichitaQ
Soul Eater
WichitaQ's Avatar
Lokacija: Isolated
Postovi: 538
Ako ne želiš integrušu, slobodno si uzmi audigy 4 i budeš zadovoljan.
WichitaQ je offline   Reply With Quote
Staro 08.07.2007., 18:52   #7
Bishop_45
Sith'ari
Bishop_45's Avatar
Postovi: 18
kuciste ako ga imaju u crvenoj boji ...
Staro 08.07.2007., 20:28   #8
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
ok.kuciste.
