#151 |
Postovi: 41
Da skužio sam... Evo upravo sam na kokainu, ne primječujem ništa da je drugačije... |
#153 |
Postovi: 41
Pa i jesam lego... Nije bilo neš posebno... Budem navečer probo neš da me uspava... |
#154 |
Postovi: 993
jer mogu hititi na mp3 i onda slušati prije spavanja u mraku? |
#155 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
ja sam jucer u miru preslusal marijuanu i negdje poslje polovice su mi se poceli grciti misici ![]() ![]() ![]() Sad cu probati onu stvar sta ste spominjali za inspiraciju jer trebam poceti uciti za prijemni koji je btw 11,7 ![]() |
#156 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#157 |
Postovi: 1,431
#158 | |
Inquisitor DeathWatch
Lokacija: Zagreb-Rijeka
Postovi: 918
FAQ Ok so to clear up a few questions that I have a feeling will be common, here's a small FAQ I put together to go with this. How does I-Doser Work? I-Doser works by sending one frequency to one ear, and one to the other. It has been proven that your brain balances out between these frequencies and syncs to the DIFFERENCE between the ears. (ex: 70 and 30 will result in 40) Does this mean I need to use headphones? Yes, most definately. If you try this with speakers, the reality is that both of your ears will hear both of the frequencies, and no effects will be felt ccc. sta nitko ne cita uputstva. ![]()
#159 |
Does youer dewg byte?
Postovi: 1,941
A što ako se netko fakata napuši ili uzme neku pravu drogu (djeco, nemojte to slučajno raditi), može li se onda koristiti ovaj reset da se vrati čovjek i tada na normalu? :-D
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() |
#160 |
Postovi: 918
#162 |
Postovi: 11,642
#163 |
Postovi: 667
#164 | |
Postovi: 1,431
***eno, znaci zabrijao sam ![]() mocno |
#166 |
Postovi: 11,642
OMG! 10GB ![]() Nije li to malo puno za ''samo'' 70 doza (mislim većinom je svaka po ~50mb)... |
#167 | ||
Lokacija: ????
Postovi: 208
![]() EDIT 2: Evo popis svih doza: Citiraj:
Zadnje izmijenjeno od: Enigma neo. 08.07.2007. u 14:19. |
#168 |
Postovi: 11,642
ok then ![]() |
#169 |
sto da napisem ?!
Postovi: 880
ovaj LSD mi se cini dobar ![]() ![]() |
#171 | |
Postovi: 7,568
![]() Ili nek nabave Electrixx - Live@Tresor/@Alcaparra Club ili Tiga - Live@Studio 88. Kojih 5 do 6h materijala (repeat se fino stavi), a poslije kuda koji... ![]() |
#173 |
Avocado
Postovi: 7,853
Spoiler alert! |
#174 | |
Lokacija: ZG županija
Postovi: 509
virtual pc for mac, i nisam isprobo, al nadam se da će bit nekaj z toga |
#175 |
Postovi: 509
ovo ne djeluje. već dve noći slušam lucid dream , sana se ne sjećam, kamoli da je bio lucidan, i 2 jutra slušam french roast, opće me nije razbudilo. slušam na slušalice, u sobi u mraku i opušten sam, kao što piše u uputama, a french roast naravno ne slušam dok ležim jer bi me trebo razbudit. ima li neko neki savjet? |
#176 |
Soul Eater
Lokacija: Isolated
Postovi: 538
A vjerojatno si imun na to, dok je mene peyote smlavio, a slušajući hand of god sam čini mi se pao u nesvijest ![]() ![]() |
#177 |
Postovi: 135
ni ja nisan osjetia neku drasticnu promjenu na sebi kad san slusa F.Roast...osim sta su mi noge bilo nesto laganije ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#178 |
Soul Eater
Lokacija: Isolated
Postovi: 538
Brzo smanji broj tih smajlija da ti ne bi mod zagorčao život ![]() |
#179 |
Udaram Ljude Za Pare
Lokacija: BEHIND YOU
Postovi: 835
Just say NO ![]() ![]() |
#180 |
The All Seeing Eye
Postovi: 1,103
Otkako je počelo ovo drogiranje, čudne reklame se pojavljuju na ovom forumu: http://img125.imageshack.us/img125/3...shot005ei6.jpg ![]() |
