Postovi: 58
Clock AMD Athlon 64 +3000 winchester
OK, now here's an example of an overclock: AMD Athlon 64 3000 (Winchester S939) Stock Speed: 1800MHz Multiplier: 9X *Remember to keep an eye on the CPU temp, try not to get it over 60C* 1. Enter your bios by pressing Del or F2 (Varies which each motherboard) 2. Set the HTT multiplier to 4 3. I'm using DDR400, so i'd lower it to DDR333 (or the lower the RAM number in the RAM:CPU ratio) to make the RAM more stable as the FSB goes up, don't forget at 250FSB, the RAM will be 400MHz again 4. Keep increasing the FSB by 3-5mhz and testing in between each increase 5. Unstable at 262 FSB 6. Increased CPU voltage by 0.025v and RAM voltage slightly 7. Stable 8. Keep increasing the FSB by 3-5mhz and testing in between each increase 9. Unstable at 267 FSB 10. Changed DDR Speed to DDR266 (because of the RAM being DDR400, over 250FSB it would run past DDR400) 11. Stable again 12. Keep increasing the FSB by 3-5mhz and testing in between each increase 13. Unstable at 282 FSB 14. Went back to last stable overclock (267 FSB), i feel this is a good enough overclock Stable Overclock: 267 x 9 = 2400 MHz Stock Speed: 1800 MHz An overclock of 600 MHz jel ovo dobar guide za clock....i jel bi mi netko mogao pomoci oko memorija i konfiguracija imam memorije 2xgoodram 400mhz 256mb i 2xsamsung pc3200 400mhz kako da ih prema ovom gore guidu konfiguriram u biosu? |
Postovi: 58
jel moze neka pomoc ovdje? |
Postovi: 58
Ekipa ![]() |
Postovi: 1,431
kolko vidim sve ok osim sto kad predjes 255-260fsb moras spustit htt multy na 3 stvar je da ti fsb*htt multy mora biti oko 1000, kolika je tolerancija ne pitaj me, ja sam se vodio logikom da preko 1020-1030 ne idem, ali to je samo moja interpretacija, zbog cega je to tako neznam pa ti konkretno nemogu ni reci zasto je bolje ispod 1000 nego iznad |
KozajeZakon.
Postovi: 303
http://icrontic.com/articles/overclo...54939_platform iako je poveci,toliko sam zavolio ovaj guide da sam stavio i uvez na isprint.varijantu ![]() |
