Lokacija: PcEkspert forum
Postovi: 554
First go to ur To-do List. Make a note and input as follows Subject: Speed Due Date: 29-01-2005(dd-mm-yy) Priority: set to High then press Done Go to option again and make a second note and input as follows Subject: Qoukie Due Date: 29-01-2005(dd-mm-yy) Priority: set to Low then press Done Do not exit yet. Highlight the Speed note, select Options and Mark as done. Then highlight the Qoukie note, select Options and Mark as done. Now, reboot your mobile. Kod mene radi a i kod vecine drugih koji su iprobali!!!
Bez linkova u sigu... |
Postovi: 18,879
Mogao si barem napisati koji mob imaš. Probao sam davno na 6600 i N70, nema ni trunke ubrzanja. Sve je kako je i bilo... |
Soul Eater
Lokacija: Isolated
Postovi: 538
Nokia N80, rekao je već. |
Datum registracije: Jul 2004
Postovi: 1,771
to ti je kao da krizas shitsua i bulldoga dobijes bullshit |
