Lokacija: a tu negdje
Postovi: 6
Novi Komp do 5000kn
Sta Kažete na ovu konfiguraciju? Trebaju mi samo ovi dijelovi koje sam naveo, ostalo prebacim sa starog kompa. Ako mozete slozit bolju konfiguraciju a da nikako neprijeđe 5000kn postajte pls ^^ comp je iskljucivo za gameing i ocu da vrtim "Silverfall" sa max detaljima *CPU AMD Athlon64 X2 4600+ BOX, dual core, SckAM2 863,30kn *MB Gigabyte M59SLI-S4, sAM2, nForce 590-SLI, SATA, FW, GLAN 852,78kn DDR2 1GB PC6400 (800MHz) OCZ, gold XTC 508,80 x2 = 1017,60kn *HDD Maxtor 6V200E0, S-ATA300, 200 GB/8MB/7200rpm 437,16kn *Gigabyte Radeon X1650XT 256MB DDR3, PCIE, TVout, DVI 1.030,90kn Mode Com midi tower Harry, bez PSU, USB 2.0, audio, 92mm fan, 2×cd cover, crno 155,00kn Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 500,00kn --------- 4856,74Kn |
Postovi: 11,642
Procesor: A64 3600+ x2 - 454kn, Borg Matična: GIGABYTE GA-MA69G-S3H - 636kn, Ve-Mil Memorija: 2x1gb Kingmax 667 - 500kn, ADM Grafička: Sapphire Radeon X1950GT 256MB DDR3 - 998kn, Optimum ili Gigabyte GF8800GTS 320MB DDR3 - 2062kn, ADM Hard disk: Hitachi Deskstar 250gb, sata2, 8mb - 469kn, Ve-Mil Optika: LG GSA-H30N, SATA, black - 249kn, Ve-Mil Napajanje: Chieftec 550W - 478kn, ADM Kućište: Sharkoon Rebel9 EE - 330kn, Links ---------------------------------------------------------------------- UKUPNO: 4114kn / 5178kn (ovisno o kartici) |
Postovi: 7,568
Prijedlog:______________________________________ Procesor: Athlon64 4000+ X2, sck. AM2, BOX - 744 kn Matična: ECS nForce4M-A, sck. AM2 - 381 kn Grafička: ECS 7900GS, 256MB GDDR3- 964 kn Memorija: 2x1GB GoodRAM DDR800 - 546 kn Hard disk: 320GB Hitachi, SATA II - 577 kn DVD/RW: LG GSA-H42N, Black - 219 kn Napajanje: Fortron 350W, 12cm FAN - 208 kn Kućište: Chieftec DG-01B-D-U - 325 kn ______________________________________________ Ukupno: 3.964 kn.....sve iz Ve-mila |
Asshole
Lokacija: RH
Postovi: 2,361
intel konfa iz ve-mila: CPU: E4300, 893 kn MBO: Gigabyte P35-S3, 883 kn HDD: Seagate 250 GB, 494 kn VGA: Gigabyte GF 7950GT, 1772 kn RAM: 2* 1GB PC5300 (667MHz), GoodRAM, 556 kn PSU: Chieftec 450W, 370 kn CASE: Mode Com midi tower Harry, 155 kn UKUPNO : 5.134,76 KN |
Postovi: 6
e da, Šta je AEGIA PhysX? Uz Silverfall sam dobio taj program za optimiranje procesora a nemam pojma sta je to jel mi kaze da takav proc nemam..... Koja je razlika izmedu E4300 (kojega svi hvale) i AMD-a?? |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Aegia PhysX je ime za koprocessor karticu koja treba služiti za izračunavanje fizike u engineima koji je podržavaju (fizika znači npr odbijanje zrnaca pjeska, kapi kiše po vodi i sl) i nema veze sa optimiziranjem procesora... Da bi mogao koristiti Aegia Pysix mod moraš imati karticu koju sumnjam da iko normalan kupuje i koristi...
-- Have a nice day... |
Postovi: 34,067
Netko je bio rekao da je sve osim X2 3600 i 4000 čisto bacanje para, pa zato ti savjetujem da uzmeš te procesore. SLI ploča je nepotrebna jer će i obična dobro raditi, a sigurno je jeftinija. Maxtor disk zaboravi i uzmi Samsung ili WD. Chief 550W je overkill i bio bi dovoljan i Fortron 350W PNF iz ve-mila (208kn). Mema je definitivno preskupa. Za svu razliku u lovi uzmi X1950Pro umjesto X1650XT.
Postovi: 6
Konfig, po vasim savijetima....Jel bi to sta valjalo? I dali je 400W napajanje dovoljno za taj Konf? CPU AMD Athlon64 X2 4000+ BOX, dual core, SckAM2 744,29kn knMB Gigabyte MA69G-S3H, sAM2, AMD 690G, VGA, SATA II, GLAN, FW, ATX 636,29kn DDR2 1GB PC5300 (667MHz), GoodRAM 283,48kn *2 = 566,96kn HDD HITACHI HDT722525DLA380 250GB SATA-300 7200rpm 8MB 469,82kn Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 370,00knMode Com midi tower Harry, bez PSU, USB 2.0, audio, 92mm fan, 2×cd cover, crno 155,00kn Powercolor Radeon X1950XT PCIE, 512MB, TVout, dual DVI 1.772,11kn (ili PRO, ovisi o raspolozivosti) __________ 4714,47kn Sve cijene su iz Ve-mila (posto je to jedina trgovina koju imam na raspolaganju tu di zivim )Zadnje izmijenjeno od: q3clayman. 28.06.2007. u 20:20. |
Postovi: 11,642
Najbolje od svega ![]() Dobro složena konfa, OSIM napajanja, problem je tak što u ve-Milu imaš samo 350W model Fortrona PNF, dok je u ADM-u onaj od 400W, tak da umjesto tog ubodeš drugo napajanje, tipa Chieftec 400/450W... EDIT: nisam ni skužio da je ubacio single-core 4000+, slažem se s kolegom McG-om, go for x2 3600+ ![]() Zadnje izmijenjeno od: Razer. 28.06.2007. u 20:15. |
Postovi: 7,568
Zemi si 3600+ X2 umjesto tog jednojezgrenog 4000+. Ne vredi te pare taman da ti Marta Žegura osobno sastavi kompjuter i svima veli da ju privlačiš. |
Postovi: 6
Onda cemo ga zamijenit sa: Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 370,00kn Nadam se da ću čuti jos par mišljenja o ovome Thread će biti aktivan dok mi plaća nesjedne :P:O nisam ni skuzio da sam obicni XP stavio "ispravljeno" a zašto 3600+ X2 a ne 4000+ X2?? razlika je 270kn... Zadnje izmijenjeno od: q3clayman. 28.06.2007. u 20:24. |
Asshole
Lokacija: RH
Postovi: 2,361
Postovi: 6
sta je ADM? (znam, glup sam :P) jel ima to u osijeku? |
Postovi: 11,642
#16 | |
Postovi: 6
#17 |
Postovi: 7,568
Svejedno ti je dal bu 3600+ X2 ili 4000+ X2, kad imaš para za bilo koji od navedenih. Hoćeš 3600+ X2 kupiš taj, hoćeš 4000+ X2 kupi njega. S 5.000 kn na rspolaganju komotno si moreš zeti i veći (320GB) disk i 4000+ X2 i još ti ostane koja kuna. |
#18 |
You'll never walk alone
Postovi: 324
Kod ADM-a ti je dostava besplatna za kupnje preko 2000kn, a kartica ti je 2060 tak da ju možeš dobiti pred vrata. Neke trgovine imaju besplatnu dostavu i za preko 1000kn (links) tak da sve uzmeš u obzir. |
