Staro 26.06.2007., 23:44   #1
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
Problem Gericom m6-t
imam problem pri dizanju novih win
imam eksterni dvd pa radim prema ovome
Installing Windows 2000, XP using the Addonics USB CD-ROM, DVD-ROM, DVD/CDRW or DVD-R/RW drive. (For Windows 98SE or Me, please proceed to the next section)
1. Download USB DOS driver and Save the file to your hard drive.
2. Use Winzip to extract the file, if you do not have the Winzip program you may get a shareware version here www.winzip.com
3. Once Winzip is installed, use the program to extract the file.
4. Open the folder name USBboot and execute the rawrite2.exe
5. When prompt for the image name, enter dosboot.img
6. Enter the floppy drive as your destination drive, which in general is the A:\
7. Place a disk into the floppy drive and press enter
8. When it is done, reboot with this disk to use the USB devices.
9. CD/ROM drives will be using the Drive R:\
10. Hard Drives will be using the next letter available. Please note there will be no letter for the hard drive if it has not been partitioned and formatted. If you are not familiar with partitioning or formatting a hard drive, please go to the following Microsoft link for the information http://support.microsoft.com/default...;EN-US;q255867
11. If everything went well, you should have a drive R:\ for the CD/ROM drive. You are now ready to copy the I386 folder from the Windows 2000 or XP installation CD to the hard drive.
12. At the prompt, go to the C:\drive by typing “C:" then "Enter”
13. At the Local Drive C:\drive, create a Folder name. For example at the C:\prompt type “MD 2k”. Doing this will create a folder name “2K” on your local hard drive.
14. Now type “R": then "Enter” to go to the R:\drive
15. At the R:\ prompt type the following “Path=A:" then press "Enter
16. Now type “Xcopy . /s C:\2k" then press "Enter” (There is a space between Xcopy and the dot)
17. Once the copy process is completed, go to the C:\drive.
18. Open the folder you have created, in this case it is the 2k folder. For example: from the C:\ prompt type “CD 2k" then press "Enter”
19. Now go to the I386 folder by typing CD I386 then Enter, from the C:\I386 type Winnt and enter.
20. Installation should now start. Follow instruction from your Operating System manual on how to install the OS. (Installation will take some time, Please be patient)
problem se javlj kada mi pocme presnimavati win ono u instalaciji kada mi je u kompu disketa za eksterni dvd onda mi napise ''setup is out of memory and cannot continue'' a kada je disketa od dosa onda mi na istome djelu izbaci '' cannot find the end user licensing agremment'' neznam vise sto da radim ludim vec dva dana ko majmun bilo kakve pomoc bi mi dobro dosla
VoodooRain je offline   Reply With Quote
Staro 27.06.2007., 08:18   #2
Postovi: 34,057
Džizus, koja zbrka. Vanjski dvd? Majko mila.
Moj savjet bi bio slijedeći. Izvadi hard i ubaci u neki drugi lap koji ima ugrađenu optiku. U BIOS-u naštimaj da je Primary Boot Device cd/dvd-rom. Instaliraj SAMO XP (bez ikakvih drivera). Izvadi hard i vrati u svoj lap. Vanjski dvd-rom će ti biti uredno prepoznat kao vanjski usb disk i onda slobodno poinstaliraj sve što fali.
Staro 27.06.2007., 08:37   #3
wex[hr]
wex[hr]'s Avatar
Lokacija: Gar
Postovi: 178
Trebalo bi radit ako si detaljno pratio upute. Koji XP, probaj non-SP i ako ideš na SP2, formatiraj hard sa default-nim 4KB cluster size.
wex[hr] je offline   Reply With Quote
Staro 27.06.2007., 09:39   #4
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
bilo bi to ljepo kada bi znao jos nekoga tko ima laptop u mojoj blizini.
a sto se tice winxp imam i obicne i sa sp1 i sa sp2 i nema nikakve razlike.
Wex[hr] ovo za formatirati jeli se to moze preko dos diskete ako ne onda mi i to otpada
Staro 27.06.2007., 10:20   #5
wex[hr]
wex[hr]'s Avatar
Lokacija: Gar
Postovi: 178
Može se. Probaj http://www.bootdisk.com/. Tu imaš image-a na kojima su ti svi potrebiti alati.
Staro 27.06.2007., 20:35   #6
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
nesto sam uspio malo nacackat ali sada mi krene
Windows XP Peofessional Setup
Please wait while Setup copies files to jour hard disk
plavi je ekran i na pocetku dolje ono kopira i nakraju prestane i vise se nista nedogađa
Staro 28.06.2007., 12:08   #7
gonzo
HW&WLAN expert
gonzo's Avatar
Postovi: 928
Ajde probaj testirati memoriju,slicna stvar mi se desila s jednim lapom koji je pri samoj instalacija windoza,tj. pocetku kopiranja bacao BSOD.Na kraju se ispostavilo da je problem u memoriji.Memtest je izbacio gomilu gresaka
HP nw8440,IBM T60
gonzo je offline   Reply With Quote
Staro 28.06.2007., 13:25   #8
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
pa kolko traje taj memtest stalno baca ista slova i brojeve ponavlja ih u razmaku od4
Staro 28.06.2007., 13:28   #9
wex[hr]
wex[hr]'s Avatar
Lokacija: Gar
Postovi: 178
Memtest ti ima nekih 10-ak do 12 testova, a za jedan 'krug' mu treba, mislim, 40-ak minuta. Glavno da on nešto vrti i da nema dolje grešaka (u prevodu crvene boje ).
Staro 28.06.2007., 15:07   #10
Postovi: 34,057
Najbitiniji su testovi 5, 6 i 8.
Staro 28.06.2007., 15:28   #11
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
ali on nemi nista nepokazuje koji je test samo vrti stalno isto vec vise od 2 sata
Staro 29.06.2007., 18:38   #12
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
moze neka praporuka programa za skeniranje hdd-a nabavio sam usb ladicu za njega pa da isprobam na stolnome kompu sve nekako sumljam da je on.
istekam svoj hdd iz kompa i preko suba inst win na laptopov hdd i sve prodje i ono kada ulazi u win izbaci plavi ekran i neki eror nesto tipa da proverim svoj hdd da ima kao neki virus na njemu pa tako da mislim da je on crko
Staro 29.06.2007., 19:59   #13
Postovi: 34,057
Za testiranje harda dobar je HD Tune, a koliko znam svi proizvođači imaju i vlastite alate za testiranje. Svi se oni mogu naći na Hiren's Boot CD-u (http://www.hiren.info/pages/bootcd).
Staro 29.06.2007., 23:21   #14
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
ajdemo dalje rami nisu i hdd nije u pitanju rade savrseno ima li jos tko kakav prijedlog?
Staro 30.06.2007., 00:21   #15
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
Autor VoodooRain Pregled postova
sad mi nista nije jasno kada stavim win da instaliram na hdd kada se restarta i boota win izbaci mi
chek your hard drive to make shure it is properly configurated and terminated run CHKDSK /F to check for a har drive corruption and then restart your computer
Tenical information:
***STOP: 0x0000007B (0xF79F7524, 0xC00000000, 0x00000000)
