Staro 19.06.2007., 22:17   #331
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor sandilove Pregled postova
jesam,reinstaliro sam je par puta i imam directx 9.oc, ali fakat neznam kaj bi moglo vise bit. Al nadam se da ce patch pomoci ( ako ikad izađe) !
R@zzoR se rušio na Core Duo i Go7600 i Giga RAM-a!
Valjda će patch to riješit!
Staro 19.06.2007., 22:55   #332
Facelessone
Facelessone's Avatar
Postovi: 4,205
stojim na 28% i cekam patch
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 20.06.2007., 18:19   #333
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ja stojim jer je komp s***an!
Staro 21.06.2007., 15:21   #334
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
Ne virujen da će patch to riješit jer je problem u konfiguraciji. Da imam malo jači procesor (trenutni Core Duo T2300 1,66GHz) sve bi bilo u redu.
I btw to je laptop.
R@zzoR je offline   Reply With Quote
Staro 22.06.2007., 14:26   #335
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor R@zzoR Pregled postova
I btw to je laptop.
BUG!
BSOD!
Staro 22.06.2007., 15:10   #336
Marko 123
Lokacija: ask?
Postovi: 243
1. Go to your "Vehicules" folder on your game directory (example: E:\Test Drive Unlimited\Euro\Bnk\Vehicules)
2. Choose one car you like to drive cause of handling/speed/acel and that kind of things xD, I`ll make the example with de Ferrari Enzo.
3. You will have to make the backup of 4 files you can find in Vehicules folder, in this case: "Enzo.bnk" , "Enzo_I.bnk" , "Default.bnk" and "Default_I.bnk".
4. Remove the 2 Enzo files from that folder.
5. Rename both "Default" files so their names looks exactly to the Enzo files (so the "Default.bnk" and "Default_I.bnk" will be "Enzo.bnk" , "Enzo_I.bnk")
6. Run the game
7. Now when you go and search the Enzo in your garage you will find that the Enzo now looks like this default car
But if u replace for example Enzo with default car, u can have 2 problems.
First, you can be kicked from server.
Second, other players will see Enzo, not default car
jeli mi moze netko pomoc oko ovoga.
fajlove sam mjenjao za audi tt,skin mi je kao default car ali performanse su od tt-a .bitno da imam performanse nije mi bitan skin.jeli tko pokusavao ovo.
Marko 123 je offline   Reply With Quote
Staro 22.06.2007., 20:08   #337
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
CHEATERU
Staro 22.06.2007., 20:10   #338
R@zzoR
Yippie-Ka-Yay
R@zzoR's Avatar
Postovi: 560
Autor Marko 123 Pregled postova
6. Run the game
CHEATERU.....hehe shala, nisam, a i ne namjeravam....
Staro 22.06.2007., 20:48   #339
Marko 123
Lokacija: ask?
Postovi: 243
jbg ajde cheateri pomozite. hehe.
R@zzoR-u ne spamaj.
moderatori,admini brisite mu ovo.
ovde dosa nabijat postove.looool sala mala
Staro 22.06.2007., 21:00   #340
wex[hr]
wex[hr]'s Avatar
Lokacija: Gar
Postovi: 178
Moji FPS-ovi.
Igra je grafičko smeće, zvuk u kurcu, a realnost je nerealna. Šteta mi routera što je moro progutat te gigabajte smeća.
wex[hr] je offline   Reply With Quote
Staro 22.06.2007., 21:32   #341
Baja 001
Baja 001's Avatar
Postovi: 7,504
Molim te da ne spamaš!
BTW-"Lonac se ruga loncu, a oba su crna!!!"
Inače igra je dobra!
Staro 22.06.2007., 21:36   #342
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor wex[hr] Pregled postova
Moji FPS-ovi.
Još imaš vrlo dobar FPS!
Ako ti se igra ne sviđa definitivno nije smeće!
Možda si ti od likova koji se furaju na C&C,WoW,Star (D)Trek,SW...
Igra nije realna kao GTR (i drugi) ali nije ni čista arkada!
Staro 22.06.2007., 22:04   #343
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,828
joj,kaj trza,inače igram na 1280x1024,fps varira 45-50...naravno sve na high
Zadnje izmijenjeno od: zvonac. 22.06.2007. u 22:20.
Staro 22.06.2007., 22:22   #344
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
e, da vas pitam par pitanja...
-kolko kosta original
-dal bi ja tu igricu mogao vrtit recimo na 1024*768 i na nekim low/medium detaljima a da ne steka ?!
Staro 23.06.2007., 00:11   #345
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Sad je samo pobrisano.
Drugi put će biti malo duže hlađenje...
Staro 23.06.2007., 00:14   #346
Big Guy
RPG player
Postovi: 1,574
test drive se čudno ponaša na većini konfiguracija
npr meni je na medium dobro radio na 30 fps-a
probaj prvo pitati nekoga tko ima da ti posudi da probaš a ako ne poznaješ nikoga tko ima onda se malo strpi pa pričekaj patch da budeš siguran ako je patch popravio to, 350 kn ipak nije malo
I hate to see you leave, but I love to watch you go
Zadnje izmijenjeno od: krešo. 11.03.2023. u 16:25.
Big Guy je offline   Reply With Quote
Staro 23.06.2007., 00:17   #347
Girrari
drug Mile
Girrari's Avatar
Postovi: 356
350kn ti košta original. Mogao bi je ziher vrtit na toj rezoluciji uz neke slabije pa čak i srednje detalje bez AA. E sad, hoće li štekat, nemam pojma... moguće da hoće barem dok ne izađe patch. Nakon toga vjerujem da bi trebala normalno radit.
EDIT: Big guy je bio brži.
Ne postoje glasni ventilatori, postoje samo nedovoljno glasni zvučnici!
Girrari je offline   Reply With Quote
Staro 23.06.2007., 00:46   #348
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Jelc Pregled postova
Ne promoviram pirate smo sam mu dao prečicu do igre koja ga neće stajati 350 kn ako ne bude valjala!
Ako valja naglasio sam da kupi original!
NEMA BED-a!
Staro 23.06.2007., 01:26   #349
rib@
rib@'s Avatar
Postovi: 1,194
Eto i ja sam skompletiral konfu i prvi dojmovi tdu - nije lose.
Jedino mi je dobra slika na 800x600, ali sam spojil neki yusmart monitor.
cpu e4300/sonictower+nexus120; mbo gigabyte p35-ds3-l; ram kingmax1024/667x2; vga hd3850; psu corsair hx 520w; dvd benq 1655; hdd wd1200jd&samsung hd321kj&ST3160021A; ZM-MFC1; lg22ws; btc6300; mx 518 i sve u chiefu s nekoliko nexusa
rib@ je offline   Reply With Quote
Staro 23.06.2007., 01:43   #350
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor rib@ Pregled postova
Dobar FPS!Čekam patch možda i ja dobijem toliko!
Staro 23.06.2007., 19:01   #351
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
heh, ja sam si je instalirao, nakon instala je pokrenem i za neko divno cudo sve ama bas vse radi bez ikakvog trzanja na 1024*768 i medeium detalji, ja reko mrak, igrao 10 min i idem ja jesti, najeo se i pokrenem je i imao sam sto vidjet, kaos, trza, ne mozes krenut...
u biti evo SS
http://www.imagesforme.com/images/9665kakojeutdu.JPG
EDIT:
nakon restarta igra radi savrseno, samo ne znam, idem prema kuci i ima ona utrka honolulu nesto i kad idem na start tu stoji, ne zabloka se nego se nista ne dogada, pa me zanima jel to normalno ili nije ?
jehehebemu patch kad ce vise, igra mi je savrsena.
Zadnje izmijenjeno od: Željac. 23.06.2007. u 19:45.
Staro 23.06.2007., 19:24   #352
mislav_os
freak
Postovi: 2,688
Joj,igra mi se cini dost dobra...Ali,izgleda da ima isti problem kao STALKER....bez patcha nemos igrat na normalnim FPS-ovima ...
A mozda cu moci igrat na 1280x1024 sa nekim Medium...Vidjet cemo,kad uzmem,javim...
Staro 24.06.2007., 00:02   #353
svebee
Lokacija: /
Postovi: 2,053
Autor Željac Pregled postova
ovo mi mene hebe u zdrav mozak... nemogu dalje u igri doć od prve utrke
svebee je offline   Reply With Quote
Staro 24.06.2007., 00:05   #354
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
Autor zahpic Pregled postova
drago mi je da nisam jedini
ahhh nista, cekat patch i molit se da ce se to rijesit
Staro 24.06.2007., 01:33   #355
Baja 001
Baja 001's Avatar
Postovi: 7,504
Probajte Reinstalirat igru?!?!
Staro 24.06.2007., 11:00   #356
svebee
Lokacija: /
Postovi: 2,053
khm, da...to najprije probao...
btw. probao i reinstall windowsa i the same
Staro 24.06.2007., 11:44   #357
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
ja sam uspio rijesiti to sto nezeli uci u utrku, svi koje to zanima mogu me PM-at jer nije u skladu s pravilima ovog foruma da bi to pisao ovdje
a ovo sto moram svaki put restartat komp prije igranja da bi normalno radio cekam patch jer tu ne mogu nista.
Staro 24.06.2007., 13:21   #358
Baja 001
Baja 001's Avatar
Postovi: 7,504
To sam jednom liku objašnjava kako napravit ali preko PM jer administratori brišu sve što nije po pravilima!
Inače može se lako riješit!(Pravila su da se krše)!
Staro 24.06.2007., 13:31   #359
svebee
Lokacija: /
Postovi: 2,053
zahvaljujem Željcu na pomoći
sad sve radi i uživam u maximalnoj grafici/igri
Staro 24.06.2007., 14:17   #360
zvonac
zvonac's Avatar
Postovi: 5,828
Autor mislav_os Pregled postova
ček malo...pa na kojim postavkama igraš?
