Lokacija: //
Postovi: 136
Odabir laptopa
Ovako laptop bi se koristia dosta za AutoCAD,znaci potrebni mu je brzine da to sve otvara koji preporucujete od ova 3 1. *HP 6710s GB893EA Core 2 Duo T7500 2x1GB 160GB 15.4'' WXGA DVDRW DL X1300 Vista Business Zaslon 15.4-inch WXGA BrightView Rezolucija 1280 x 800 Procesor Intel Core 2 Duo T7500, 2.20GHz (4MB cache) HDD 160 GB (5400 rpm) FDD - Optički pogon DVD+/-RW DL Memorija 2 x1 GB DDR2 667MHz (proširivo do 4GB) Grafika Integrirana, ATI Radeon X1300 Fax modem 56K Mrežna kartica 10/100/1000 Ethernet Mbps LAN WiFi kartica Multimedia Ugrađeni stereo zvučnici I/O 4x USB 2.0 port, PC Card slot tip I/II, VGA izlaz, mic in, line out, 1 x RJ11, 1 x RJ45, S-Video Out Dimenzije 357 x 265 x 35 mm Masa 2.7 kg OS Windows VISTA Business Ostalo Ugrađen Bluetooth modul Čitač kartica 5u1 FPR modul Priključak za docking 2. *HP 6715b GB835EA Turion 64 X2 TL60 2GB 160GB 15.4'' WXGA DVDRW DL WiFi BT 4u1 W Vista Buisness Zaslon 15.4" WSXGA anti-glare display (1600 x 1024) Procesor AMD Turion 64 X2 TL60 2.20GHz, L2 Cache 2x 512 KB HDD 160 GB (5400 okretaja) FDD - Optički pogon DVD+/-RW DL Supermulti Fixed Memorija 2 GB DDR2 (2 x 1024) 667 MHz Nadogradivo do 4 GB Grafika ATI Radeon X1250 Do 512-MB dijeljene memorije Fax modem 56K modem Mrežna kartica LAN (10/100/1000) Broadcom 802.11a/b/g Multimedia Intel High Definition Audio Ugrađeni stereo zvučnici I/O 4 USB 2.0 porta, VGA, stereo microphone in, stereo headphone/line out, Firewire (1394a), RJ-11, RJ-45, S-video TV out, 1 Type I/II PC Card Dimenzije 3.5 x 35.7 x 26.5 cm Masa 2.7 kg OS Windows Vista Business Ostalo Bluetooth, Čitač otiska prsta 3. *HP nx9420 RU478EA Core 2 Duo T5600 2GB 120GB DVDRW DL 17'' WSXGA+ WVA BV Vista Home Basic Model nx9420 RU478EA Zaslon 17" WSXGA+ TFT + WVA Bright View 1680x1050 rezolucija Procesor Intel Core 2 Duo T5600 1,83GHz, 2 MB L2 Cache, 667MHz FSB HDD 120 GB, 5400 rpm Optički pogon DVD+/-RW Dual Layer Memorija 2 x 1024MB DDRII 667MHz Nadogradivo do 4 GB Grafika Odvojena, ATI Mobility Radeon X1600 256 MB memorije Fax modem 56K Modem Mrežna kartica Broadcom Gigabit 10/100/1000 Intel® Wireless LAN 802.11a/b/g MOW2 Multimedia Sound High Definition, Audio 24 Bit Audio DAC Integrirani stereo zvučnici I/O RJ 11, RJ 45, 4 x USB 2.0, VGA, S-Video-TV, IEEE 1394a, priključak za docking, audio ulazi/izlazi, PCMCIA Type I/II PC Card Dimenzije 393 x 275 x 33 mm Masa 3.35 kg OS Windows Vista Home Basic Ostalo Integriran Bluetooth modul! Ugrađen čitač kartica 7u1 Ambient light sensor Po vasem izboru koji bi uzeli laptop znaci za autoCAD??? |
Postovi: 12,613
Cuj koliko znam, za CAD je vazan sto veci monitor, tako da od ovih 3. ulazi kao najbolji izbor, a ima i grafu odvojenu...
Lokacija: //
Postovi: 136
Mozete preporuciti neki laptop iz ve-mila ili hgspota da moze CAD pokrecat bez problema do 10 000kn jer neznam sta to znaci odvojena graficka ako nekom nije problem moze li mi odabrati neki |
Postovi: 33,993
Integrirana grafika znači da ona za svoj rad koristi RAM laptopa. A dotični je UVIJEK sporiji od GDDR memorije koja se koristi na odvojenim graf. karticama. Za AutoCAD najbolje su ti nVidia Quadro graf. kartice, dok su ATI Fire GL zericu slabije. Njih ćeš naći u HP seriji nw8xxx i nw9xxx. Moj iskreni savjet je da pročitaš 'Vodič za kupnju..' koji imaš zalijepljen na vrhu ovog podforuma. Ako imaš keš, najbolje ti se obratiti gospodinu koji je taj tekst napisao jer ti može ponuditi odlične laptope po najpovoljnim cijenama.
Lokacija: Ploče
Postovi: 264
Pročitaj ovo http://forum.pcekspert.com/showthread.php?t=52798 dosta će ti pomoći - kasnije češ moći i sam odabrati. edit:coconut je bio brži ![]() |
