Staro 31.05.2007., 02:02   #1
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Kako ovo overclockat? Gigabyte MBO + nVidia
Kako da ovo overclockam?
MBO Gigabyte 965P-DS4 rev3.3
VGA nVidia 7800gtx 256mb
CPU Core2Duo E6300
MEM 2 x 1gb DDR2 800mhz PC6400 Supertalent
Prije sam imao maticnu plocu (MSI Neo4) sa nVidijinim chipsetom i overclockanje se obavljalo jednostavno - preko nTune programa koji bi sve sam podesio i testirao.
Medjutim ova ploca ima Intelov chipset i nTune odbija funkcionirati (logicno).
Dakle, sad moram manualno to napraviti, ali ne znam kako, s kojim programima, ...
Savjeti ?
Staro 31.05.2007., 07:41   #2
Buger
Postovi: 4,391
Autor Neo-ST Pregled postova
CPU Core2Duo E6300
Savjeti ?
klokaš iz BIOSa...
use the search...
Staro 31.05.2007., 11:13   #3
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Podigni FSB i to je to. Ali u biosu sa ctrl+f1 otključavaš dodatne opcije još.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 31.05.2007., 12:31   #4
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
zasto to oc-at kad imas jaku masinu koja ce tjerat igre na high detaljima bez problema.
Tekla je offline   Reply With Quote
Staro 01.06.2007., 13:21   #5
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Autor Tekla Pregled postova
Vjeruj mi, ne tjera ih. Snage nikad dosta
Staro 01.06.2007., 13:35   #6
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Hvala.... ali ima jedan problem... nikad u zivotu nisam nista overclockao niti znam kako se to radi
Jedino preko nTune programa, za newbie poput mene
Sta to znaci da podignem FSB, koliko, sta time dobivam...?
Sta je sa memorijom, procesorom, grafickom, ...?
Staro 01.06.2007., 13:43   #7
Buger
Postovi: 4,391
gle imaš ovih tema mali milijun al ajd:
PCIE frequency postaviš na 100
FSB postaviš na (ovisi sad isporbavaš dokle ide) 400 što daje 2.8GHz
latencije RAMa postaviš na manual i ostaviš ih na 5-5-5-15(možeš ih smanjivati al nema neke prevelike koristi)
po potrebi povećavaš napon
po ovom mom "receptu" proc ti radi na 2.8GHz a RAM na deklariranih 800MHz
i sad dalje dižeš FSB, testiraš i vidiš kolko mogu ploča, proc, RAMi
*do 2.8GHz nemoraš dirat napon na procesoru
-djelitelj memorije postaviš na 2.00 tj. da ti omjer fsb:ram=1:1
Staro 01.06.2007., 22:13   #8
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Autor Bugger Pregled postova
Nisam uspio.
1. PCIE je vec po defaultu na 100
2. kontrolu FSB-a ne mogu nac u BIOS-u
3. u biosu sam pritisnuo ctrl+f1, ekran je zablinkao, ali ne znam koje su se to opcije otvorile
4. latencije rama su vec na 555-15
5. djelitelj memorije nisam dirao jer upozorenje kaze da se sistem moze ponasat cudno i ne radit...
Uglavnom, nisam znao kako da ti to drugacije predocim pa sam slikao
1. slika - glavni ekran BIOS-a
http://img162.imageshack.us/img162/7530/dsc00695ce3.jpg
2. slika - MIB intelligent tweaker (jedini dio biosa gdje mozes overclockat)
http://img73.imageshack.us/img73/811/dsc00696sa7.jpg
3. nastavak ekrana od MIB
http://img73.imageshack.us/img73/4990/dsc00697nl9.jpg
Sta cu sada?
EDIT by Buljo: Ubuduće čitaj pravila i pazi kakve slike stavljaš..
Zadnje izmijenjeno od: buljo. 02.06.2007. u 01:31.
Staro 01.06.2007., 23:35   #9
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
grafu preko riva tunera.
Staro 02.06.2007., 00:27   #10
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Mislim da nisi ti dobro stisnuo taj ctrl+F1 - odmah cim udes u bios, a ne kad vec odaberes neku stavku. Koliko vidim da bi jos trebalo bit Advanced chipset features - neka javi tko ima tu ploču (domyos?)
Staro 02.06.2007., 00:38   #11
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Autor flajpan Pregled postova
Pa i jesam stisnuo odmah kad udjem u BIOS, u glavnom ekranu...
Kazem ti, ekran zablinka ali nikakve posebne nove opcije nisam vidio...
idem proguglat da vidim, mozda nije ctrl+f1
Staro 02.06.2007., 01:00   #12
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Ipak je ctrl+f1... ali boga mi ja ne vidim nikakve napredne opcije...
Na ovoj stranici http://www.ciao.co.uk/Gigabyte_GA_96...Review_5611534
čovjek kaže da se funkcije za overclockiranje otvaraju tek nakon pritiskanja ctrl+f1: "Pressing Ctrl + F1 on the bios page displays the overclocking features allowing you to raise the fsb, change multipliers, memory timings, chipset, cpu and ram voltages as well as the PCU bus frequency. Every option that you want for overclocking can be access here."
Ali stvarno ne znam koji je onda vrag s ovom pločom, jer meni se nakon ctrl+f1 ništa ne događa...
Probao sam stavit Robust Graphic Booster na "Turbo", Memory Performance Enhance isto na "Turbo" i CIA2 na "Full thrust" ali onda nakon boota nije više htio dignit Windowse...
pa sam vratio sve na optimized defaults.
any clues?
Staro 02.06.2007., 08:53   #13
Buger
Postovi: 4,391
gle jedna opcija iznad odabrane na enabled, pa mrdaš
inače odmah pri ulasku u BIOS stisneš CTRL+F1
Staro 03.06.2007., 09:28   #14
nexus-6
Pero_Snajper
nexus-6's Avatar
Postovi: 649
Ako si dobio ovaj ekran kao sto si naveo, onda ti ctrl-f1 radi (inace ne bi imao pol opcija na slici).
I sad ovak:
cpu host clock control - ENABLED
cpu host frequency - 400
pci-e express frequency - 100
system memory multiplier - 2
I to ti je cist dovoljno za pocetak.
nexus-6 je offline   Reply With Quote
Staro 05.06.2007., 11:43   #15
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Autor nexus-6 Pregled postova
I sad ovak:
Evo napravio sam ovo i takt je skocio sa 1.8 na 2.8 !
Ali je bogami i temperatura, sa 37 na 50
No, pokrenuo sam 3dmark06 i nema nekih boljih rezultata. CPU result je 2.5 puta bolji, ali ono drugo je sve losije pa dodje na isto, tako da sam vratio default postavke
Staro 05.06.2007., 16:16   #16
Moree
Postovi: 328
Hmmm?
Moree je offline   Reply With Quote
Staro 05.06.2007., 17:32   #17
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Autor Moree Pregled postova
Hmmm?
Da...
Kad uhvatim vremena stavit cu 3Dmark06 score usporedbu, da puno ne pricam...
Staro 05.06.2007., 18:23   #18
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Moree se čudi kako ti "sve drugo" može bit lošije... A bogami i ja?
može bit isto, ali kako može bit LOŠIJE ako nisi dirao grafu????
Have a nice day...
Staro 05.06.2007., 19:04   #19
Neo-ST
Neo-ST's Avatar
Postovi: 8,445
Autor yedwy Pregled postova
Ma ukljucio sam neke postavke u biosu za graficku (robust graphic booster ili tako nesto) pa ne znam sta je od toga svega ispalo...
Staro 05.06.2007., 21:33   #20
nexus-6
Pero_Snajper
nexus-6's Avatar
Postovi: 649
Ma taj graphics booster nemoj dirat jer ti onda usporedba ne drzi vodu (ak se ne varam on dize takt gpu-a). Ak ces grafu dizat, to fino iz windoza specijaliziranim alatima (atitool, riva tuner itd...) Sta se temperature tice, bilo je dosta govora o tome, ispod 60 na jezgrama u loadu nemas frke...
Staro 28.06.2007., 22:35   #21
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Mozda je malo glupo pitanje...
Dal je moguce povecat multiplier na nekom procu?
E6300?
Staro 28.06.2007., 22:41   #22
yedwy
yedwy's Avatar
Postovi: 6,956
Moguće je ne nekim procesorima ali AFIAK ne na E6300, Athloni FX, mobile Bartoni, neki Tbredi uglavnom starije stvari i rijtki testni primjerci ili specijalne serije se mogu otključati inače su danas svi lockani...
Have a nice day...
Staro 13.09.2007., 20:18   #23
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Znam da dizem temu iz prasine, ali bolje to nego otvorit novu...
Meni po defaultu pise cpu host frequency 100 sto mi je malo cudno. I kojim tocno redosljedom treba postavit ove latencije da bi dobio 5-5-5-15? Vidim da ima dosta jos dodatnih.
Imam slican komp ko ovaj.
