Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Tray Tools 1.3.6.1042
1.3.6.1042[*] Updated existing translation files [+] Added Polish translation[*] Updated Advances Tweaks databases [F] Fixed procedure to collect monitoring sources from ATT in "Motherboard Sources" FlashOSD Plugin. [F] Fixed current 3D profile detection in non CCC compatible mode[*] Updated Monitoring Graphs module to support external plugins. This excellent idea was first implemented in RivaTuner by Unwinder. ATT and RT plugins are incompatible. [+] Added example Monitoring Graphs plugin "Memory Monitor". Which can monitor global memory statuses like Memory Load %, Physical memory Available, Page File usage, Virtual memory usage. Source code included. [+] Added monitoring plugin "HDD Temperature". Allows monitoring temperature of HDD disks via S.M.A.R.T.[*] Updated plugins SDK to support new monitoring graphs plugins[*] Minor GUI updates[*] Updated Driver level Overclocking support for RV560/RV570 boards. [+] Added test support for voltage regulation on X1950XTX boards[*] Added monitoring plugin "X1xxx Voltages" to provide monitoring sources for GPU/Mem voltages.[*] Updated installation GUI interface [+] Added new configuration option. "Disable using OverDrive in "Driver Level" overclocking mode". This option can be useful if your video board has support for OverDrive, but ATT unable to overclock using "Driver Level" mode. Can be changed in atitray.ini or at installation process.[*] Updated Overdrive 3 support detection procedure.[*] Updated Core Names database. Added infotmation about RV610/M74/M72/M76/RV630 chips.[*] Updated registry handling function under CCC compatibly mode[*] Added support for Vista 32bit. Not all of functions will work under Vista at this time. [-] Audio recorder and Volume control functionality disabled because of incompatible issues under Vista.[*] Updated Advanced Tweaks registry editor to support Windows Vista [+] Added new tweaks database "Avivo Tweaks" for Windows Vista only! [F] Fixed memory calculation procedure for some of RV5xx video boards [+] Added new option to automatically restore desktop icon positions after resolution changes.[*] Updated RefreshLock subsystem. Now you should set only Width, Height and Refresh rate for refresh override. No need to set color quality. Old saved profiles are incompatible with this version so please recreate them again. [+] Added new Game Profile option. "Force VSync=ON". This option can force using VSync in D3D8/9 games under Vista[*] Now only "Driver level" mode overclocking are allowed for X1xxx video boards. If you want to use Low Level overclocking you should change options in atitray.ini.[*] Added support for Radeon X1050[*] Updated HW Monitor logging system. Added option to select log file folder location http://www.guru3d.com/article/atitraytools/189/
Lokacija: n/a
Postovi: 6,128
Uf, ovo odmah skidam! Tnx.EDIT: Radi! Sad mogu i sa ATT clockat X1950GT, prije nije moglo pa sam morao rabit Rivu ili Atitool. ![]() Zadnje izmijenjeno od: SRV. 22.05.2007. u 19:50. |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,164
Hm... ATI Tray Tools. A sto bi ti radio s tim na nVidia grafi? ![]()
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
Postovi: 2,937
pa Riva Tuner radi sa ATi karticama :P |
Postovi: 3,164
Super Moderators
Postovi: 17,485
Pa, sa ATITool-om se i dalje normalno clocka Nvidia...samo kaj mi tu pričamo o ATI Tray Tools-u ![]()
Postovi: 9,067
Hm, imam jedan specifican problem, i vec nakon 2 formata i ponovne instalacije windoza problem se javlja bas negdje paralelno sa instalacijom ATT-a. Naime, dok igram CoD2, prvi puta se ALT+TAB-am u Win normalno, ali nakon drugog puta me doceka crni ekran kod povratka u igru, a podizanjem Task Managera i DirectX error. Googlao sam vec dosta, jer problem imam od 8mj prosle godine kada sam presao sa NV -> ATI x850pro pa i sad na x1950pro. Digao sam win, stavio samo osnovne stvari, 7.4 drivere i CoD2 i zacudo mogao sam ici u WIN do mile volje. I onda sam pomislio da je bilo do drivera, odnosno da je sa 7.4 to rijeseno. No naknadno dignuh i ATT i krenulo je sa DX errorima. Dali je nekome poznat problem?
___________ Just atha x |
Strichek Moderator
Postovi: 9,344
Dal ti je tad uključen Xfire? Driveri su sa CCCom ili ?
žmnpp |
#11 | |
Lokacija: Vrulja
Postovi: 484
Kod mene nikako ne leze 7.4 driver. Ja sam sa njima imao svakojakih problema od rusenja igara do crnog ekrana. I dizao novi instalaciju win-a i instaliranje drivera po neznam koliko puta. Sa 7.3 nemama ama bas nikakvih problema tako da ti je to moja preporuka. Poz. |
Postovi: 9,067
ma probao sam sve drivere jos tamo od ljeta prosle godine, do 7.4 - tako da nije do drivera. @Buljo - cisti driver + WDM + ATT, xFire je uvijek ukljucen. No nekako sumnjam da je do njega? O_o
Lokacija: Sinj
Postovi: 1,080
#16 |
Super Moderators
Postovi: 17,485
Njubaro ![]()
#18 |
Strichek Moderator
Postovi: 9,344
Shebao je to jedan update, prije njega je sve radilo kak spada, ja sam bio lud zbog toga i sad mi ne pada na pamet više da upalim xfire, osim ako to ne poprave a vidim da je prošlo već dosta vremena i još uvijek problemi.. :/
žmnpp |
#20 |
Lokacija: Velika Gorica
Postovi: 11
Može mi tko reći na koji način mogu snimiti profil kada karticu overclockam. Kada ju clockam i idem na save pojavi se poruka: Nothing to save in profile. U padajućem izborniku ne mogu ništa odabrati niti upisat ime profila. Molim za pomoć |
#21 |
Super Moderators
Postovi: 17,485
Narihtaš frekve, Apply, Save as.
#23 |
Postovi: 18,906
ATI Tray Tools 1.3.6 Build 1047 Beta donosi dosta zanimljivih stvari... ![]() What's New in This Release: · Added new overclocking method for X1xxx boards with Overdrive support. "Driver Level overclocking". Near the same method first was introduced in RivaTuner and then in ATITool. What will do this method? · Overclocking will be done by Catalyst itself like Overdrive · Voltage will be applied by driver for GPU and by ATT for memory. Only for hardware with voltage regulator · ATT will emulate Overdrive job, but will allow to set clocks when you want it instead of when you run full screen 3D application. · This should work even if you didn't disable ATI HotKey poller! And clocks will not reset by that service in 3D games · With this method clocks shouldn't not resets when you play any video files (tested on my 1800XT) · More stable overclocking. · You can create full featured overclocking profiles in ATT and use them in game profiles. · For Video board without OverDrive support ATT will use alternative method for overclocking like used in ATI WinClk and also in last release of RivaTuner.... http://www.radeon.ru/downloads/att/b/attsetup.exe |
