Staro 24.03.2007., 19:28   #1
Blaž
Postovi: 97
FireFox v2.0.0.3
Molio bi vas da mi preporučite neke "esencijalne" plugin-ove za FireFox v2.0.0.3! Koji su plugin-ovi po vašem mišljenu "must have"?
Do sad sam bio na IE7, a prešao bi na FireFox pa vas molim za pomoć!
Hvala!
Blaž je offline   Reply With Quote
Staro 24.03.2007., 19:40   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ovo je meni pod mus:
Undo Closed tabs
Foxmarks bookmark synchronizer
adblock plus
adblock filterset.G updater
PDF download
A onda ako oćeš
od Coste PCEkspert.com forum meni
Otvoreni on the air (ako slušaš Otvoreni, da vidiš koja je pjesma)
Sigurno će biti još prijedloga, ali ja nemam previše tih ekstenzija, samo osnovne...
Staro 24.03.2007., 20:04   #3
mat
Postovi: 2,105
Generated: Sat Mar 24 2007 20:02:58 GMT+0100 (Central European Standard Time)
User Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.11) Gecko/20070312 Firefox/1.5.0.11
Build ID: 2007031202
Enabled Extensions: [15]
- All-in-One Sidebar 0.7.1: http://firefox.exxile.net/aios/
- CustomizeGoogle 0.55: http://www.customizegoogle.com/
- Google Toolbar for Firefox 2.1.20060807W: http://www.google.com/
- IE Tab 1.3.1.20070126: http://ietab.mozdev.org/
- keyconfig 20060828: http://mozilla.dorando.at/
- Live IP Address 1.6: http://www.google.com/search?q=Firef...20IP%20Address
- MR Tech Local Install 5.3.2.3: http://www.mrtech.com/extensions/local_install/
- PCEkspert.com Forum Meni 1.4: http://www.google.com/search?q=Firef...20Forum%20Meni
- Sage 1.3.10: http://sage.mozdev.org
- StumbleUpon 3.04: http://www.stumbleupon.com/
- Tab Mix Plus 0.3.5.2: http://tmp.garyr.net
- VideoDownloader 1.1.1: http://videodownloader.net/
- Web Developer 1.1.3: http://chrispederick.com/work/webdeveloper/
- WebmailCompose 0.6.6: http://www.jedbrown.net/extensions/
- Yahoo! Mail Notifier 0.9.9.2: http://ymnotifier.mozdev.org
Disabled Extensions: [1]
- Littlefox 1.7.05 : http://www.google.com/search?q=Firef...lefox%201.7.05
Total Extensions: 16
Installed Themes: [2]
- Firefox (default): http://www.mozilla.org/
- Littlefox 1.7.05: http://www.geocities.com/alfredkayse...tlemozilla.htm
Installed Plugins: (9)
- Java(TM) 2 Platform Standard Edition 5.0 Update 10
- LogMeIn Inc. Remote Access Components 1.0.0.250
- Microsoft® DRM
- Mozilla Default Plug-in
- PCMan's IE Tab Plug-in for Mozilla/Firefox
- QuickTime Plug-in 7.1
- Shockwave Flash
- Windows Media Player Plug-in Dynamic Link Library
- Yahoo! activeX Plug-in Bridge
mat je offline   Reply With Quote
Staro 24.03.2007., 20:13   #4
Blaž
Postovi: 97
Ideš, ima toga puno!
Hvala vam dečki na pomoći, budem ih sve proučio koje ste naveli i napravio si prema njima svoju kolekciju.
Molio bi da se ne obriše ovaj topic tako da se mogu ravnati prema njemu!
Puno hvala!
Staro 24.03.2007., 21:47   #5
fairy
daysleeper
fairy's Avatar
Datum registracije: Apr 2004
Lokacija: zaprešić
Postovi: 405
ako slušaš mjuzu dok surfaš, koristan je foxy tunes
za skidanje s megauploada https://addons.mozilla.org/firefox/3843/
...a od google toolbara meni je bolji ovaj
pdf download je isto zgodna extenzija... i gmail notifier ak koristiš gmail...
fairy je offline   Reply With Quote
Staro 24.03.2007., 22:52   #6
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Ej ljudi, ja sam neki dan (prije par tjedana ) isprobavao taj firefox i kad god bi ušao u bilo koju stranicu slika (ne ekran već slika) bi mi počela titrati odnosno skakati gore/dolje po 1cm! Npr. u google-u sam i počne mi bježati google gore/dolje.
Jel imao itko takav problem? Kak da to riješim?
Bartuc je offline   Reply With Quote
Staro 24.03.2007., 23:09   #7
fear1666
fear1666's Avatar
Postovi: 86
stavi nesto u bookmarkse
fear1666 je offline   Reply With Quote
Staro 24.03.2007., 23:50   #8
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Autor fear1666 Pregled postova
To je riješilo problem, ali...
Zašto ne mogu imati mirnu sliku bez bookmarksa? Kad su mi oni uključeni to mi smanjuje vidljivu plohu browsera i samo me smetaju!? Ima li još koje rješenje za to?
PS:
1) Ovak izgleda bez bookmarksa ali slika skače: - primjeti kako ima slovo B iznad Banner i kako je u dva sloja firefox simbol (toliko mi slika skače gore dolje)
2) Ovak izgleda sa bookmarkom ali mi se ne sviđa jer je ikona debela i velik dio ekrana mi pojede:
Hvala unaprijed
Staro 24.03.2007., 23:55   #9
morph
morph's Avatar
Postovi: 1,530
Pa iskljuci bookmarks toolbar (view>toolbars)
morph je offline   Reply With Quote
Staro 25.03.2007., 00:00   #10
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Autor morph Pregled postova
E, to je skroz na skroz riješilo problem!
Puno hvala kolega. Sad mogu napokon vidjeti firefox u pravome svijetlu!
Jel po vašem mišljenju puno bolji od IE7? Po čemu je bolji osim po ovim pluginovima?
Staro 25.03.2007., 00:03   #11
tutix
tutix's Avatar
Postovi: 4,069
Možeš to skroz maknut. Idi na View - Toolbars - Customize i samo područje tih Bookmarksa odvuci lijevom tipkom miša u onaj prozor ovako:
Mislim ako ti smeta ta velika tipka, ali to ti je od skina koji koristiš. WindowBlinds, jesam li u pravu?
EDIT: Ma pišem post ko baba sporo, zanemari .
Staro 25.03.2007., 00:12   #12
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Ma u redu je Tutix, hvala na pomoći! Koristim Alienware temu, nego reci zašto je kod tebe toliko lijepši firefox? Koju verziju koristiš? Jel to neki mod za firefox ili meni ovaj alienware totalno shebe izgled firefoxa (kod mene izgleda kao da je pobjegao iz Win98 )!?
Staro 25.03.2007., 00:26   #13
tutix
tutix's Avatar
Postovi: 4,069
To je Firefox povukao moju Royale Vista temu. Inače možeš instalirat teme za Firefox da ti izgleda bolje:
link 1
link 2
Staro 25.05.2007., 15:04   #14
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Od zadnjeg updejta, Gmail Notifier addon neće se ucompatibilati (na 2.0.0.3.). Neće pa neće. Točnije, ili ne otvara Gmail uopće, ili kad otvori, ne radi (nema replyjanja, nema click unread, lijevo di je onaj google chat piše "We're experiencing difficulties atm blabla..."). Za sve naredbe izbaci prozor "Please try again" "Failed"... Nakon disejblanja/uninstalla gmail addona sve radi. Piskaraju dečki po forumima da je nekompatibilan često, al da ga se treba instalirat baš s proizvođačeva sajta, i da onda radi, al nula bodova. Fuj, prešla sam privremeno na neki eksterni Gmail Notifier, al mi se ne sviđa. Oću svoj Ffox gnotifier!
Please ako netko ima radeći Gnotifier, nek rekne di ga je skinuo jer sma isprobala već ne znam koliko bezuspješnih raznih lokacija.
Ladybug je offline   Reply With Quote
Staro 25.05.2007., 15:24   #15
Mikeyy
Postovi: 2,078
http://www.longfocus.com/firefox/gmanager/
Probaj ovo, meni je to najkorisniji addon.
Staro 25.05.2007., 15:45   #16
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Savršeno radi - čak ima i više opcija od starog, a i ljepše su. Hvala!
Staro 25.05.2007., 19:07   #17
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
Autor Ladybug Pregled postova
probaj se igrat s malo disable,enable tog addona i gasenjem paljenjem ffa.. meni je proradio nakon sto sam doslovno nekim redoslijedom to prckao a neznam kojim
msvrtan je offline   Reply With Quote
Staro 25.05.2007., 20:50   #18
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Thx svrtan, al sam se sad prebacila na ovaj gorenavedeni notifier, i čak mi je bolji i lakši za koristiti! Imam na kompu i previše stvari koje određenim redoslijedom trebam pipkati da bi proradile, ova barem radi sama od sebe
Staro 28.05.2007., 12:53   #19
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
sliknuo sam svoje extenzije, jer mi se nije dalo tipkati, sve ih preporučam
@ tutix, može link na tu temu? ili gdje da potražim? HVALA
jollyb je offline   Reply With Quote
Staro 28.05.2007., 20:11   #20
tutix
tutix's Avatar
Postovi: 4,069
Autor jollyb Pregled postova
Može uvijek: Royale Vista link. Autor stavio u jedan paket sve verzije koje je napravio, ova moja je 1.5 .
Staro 28.05.2007., 22:19   #21
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Autor mat Pregled postova
Izgleda mi korisno, ali meni ne radi. To je ovaj, zar ne? Instalirao sam ga i stalno piše Retieving your IP address... dole desno gdje bi trebala pisati IP adresa. Izgleda da ne funkcionira kada se ide preko routera na net? Ja idem preko routera.
EDIT: sad je najedamput proradio nakon 10 minuta. nemam pojma kako ni zašto - sam od sebe. Bitno da radi.
1: Intel Badaxe2 () C2Q Q6600 () 2x2GB Kingmax 800MHz () Gigabyte GF 7300GT () 2 x Seagate 7200.10 320GB SATA II () Corsair VX 550W () DVD±RW LG H22 () Rebel 12 Economy
2: Gigabyte GA-965GM-S2 () C2D E6400 () 2x1GB Kingmax 667MHz () Seasonic S12 380W
beroland je offline   Reply With Quote
Staro 29.05.2007., 16:51   #22
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Autor beroland Pregled postova
nakon cca 24 sata korištenja ovog plugina za vidjeti vlastitu IP adresu, čini mi se da ima neki bug u kombinaciji sa firefoxom v2.0.0.3 jer moram doublclick na mjesto gdje se prikazuju IP adresa i tek onda mi se IP pokaže. Dok ne napravim double click stalno piše "Retrieving your IP address..."
