Staro 27.05.2007., 20:10   #1
prasak
You'll never walk alone
prasak's Avatar
Postovi: 324
Konfa oko 8000, jel to to?
Matična Gigabyte P35-DS4, s775, intel P35+ICH9R, FSB 1333/1066/800MHz 1.225,50Kn ADM
Procesor Intel Core 2 Duo E6420 , 2.13GHz, socket 775, 4Mb cache 1.272,46Kn ADM
Hladnjak ARCTIC-COOLING Freezer 7 Pro, socket 775 178,61 Kn LINKS
RAM DDR2 1024Mb (1Gb) PC6400 Kingmax MARS , CL5, KLDD48F-A8KB5 x2 530,86Kn ADM
Grafička XFX 8800 GTS GeForce 8800 GTS, 320 MB, DDR3 1.938,67Kn ADM
HDD 320.0 GB SAMSUNG, Serial ATA II, 16MB cache, 7200 okr/min 613,11 Kn LINKS
Floppy drive 3.5'', 1,44MB, crni 39,99 Kn LINKS
Napajanje CHIEFTEC 550W, 12cm fan, ATX2 ver 2.0 493,88 Kn LINKS
Kućište COOLERMASTER Centurion 534 lite, crno 489,91 Kn LINKS
Miš Genius ERGO 525 Laser Gaming mouse, 2000 dpi 149,45Kn ADM
Zvučnici Logitech X-230, 2.1, 2 satelita (6W) + Subwoofer (20W) 304,88Kn ADM
Tipkovnica SAITEK Eclipse Keyboard, crvena, USB 339,80 Kn LINKS
Trebam li što mijenjati? Mislio sam uzeti Seasonic s430 ali ga u linksu nemaju. DVDRW već imam.
i5 2500k i Ryzen 5 1600
prasak je offline   Reply With Quote
Staro 27.05.2007., 20:46   #2
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
sve super, eventualno zvucnike da uzmes altec lansing vs2221 po mojem
ostalo super!
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 27.05.2007., 20:49   #3
mehekek
mehekek's Avatar
Lokacija: At yo' mamaz!
Postovi: 194
moje misljenje je da si ubodes jos 2 gige rama izbacis ''skupe zvucnike'' a ubacis 8800GTS 640MB
mehekek je offline   Reply With Quote
Staro 28.05.2007., 20:17   #4
Salko01
Salko01's Avatar
Lokacija: PcEkspert forum
Postovi: 554
Samo jos gigu rama i miran si dosta vremena!!!
Salko01 je offline   Reply With Quote
Staro 28.05.2007., 20:39   #5
mehekek
mehekek's Avatar
Postovi: 194
rami su danas PREJEFTINI pa bi bilo bolje da uzmes 2 keksa, a i 640MB verzija ce ti bolje sluziti na vecim rezama od 1280x1024
Staro 28.05.2007., 22:40   #6
prasak
prasak's Avatar
Postovi: 324
Ostaje mi monitor iz siga pa mi je 1000kn više za grafu neisplativo. A o ramima ću razmisliti. Znam da će mi trebati, ali ih je uvijek lako dodati. Samo da sve komponente budu raspoložive... Šteta što je admov on-line shop totalno u neredu, a nema ni podatke o raspolozivosti i garanciji komponenata, pa ću se morati raspitati.
Staro 28.05.2007., 23:07   #7
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Kak kaze ekipa, ubodi jos 1GB jer su rami jeftini. I za zvucnike AL VS2221, jeftiniji su i bolji od X-230. VS2221 je malo teze nac, ima ih u Nitel-u ak se ne varam.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 28.05.2007., 23:20   #8
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
pa vec je napisao x2 za ram, dakle 2 GB
onaj 1 Gb je samo stavka,ime i podaci komponente.. na kraju je kolicina i cijena
glede chiefteca 550W, ako si osjetljiv, cut ces ga kako 'cvrči'....
imao pa znam.
(seasonica ti mogu preporuciti ali on je skuplji,
ali mislim da se isplati, bolje nego kasnije mijenjati)
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 29.05.2007., 08:09   #9
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Vaj d hell 550W?! 450W ti je dosta i previse...
Staro 29.05.2007., 08:44   #10
Shinichi
Taiketsu Master
Shinichi's Avatar
Lokacija: Suzuka, Japan
Postovi: 150
@prasak
Sve mi se čini dobro izbalansirano ali mi je nekako tastatura za 339 kuna Overkill. :|
Shinichi je offline   Reply With Quote
Staro 29.05.2007., 11:18   #11
mehekek
mehekek's Avatar
Postovi: 194
Autor TomRi Pregled postova
imao pa znam.
seasonica trenutno nema u linksu
Staro 29.05.2007., 12:16   #12
Postovi: 33,930
Autor Shinichi Pregled postova
@prasak
Slažem se s kolegom
Staro 29.05.2007., 14:27   #13
Salko01
Salko01's Avatar
Postovi: 554
Autor mehekek Pregled postova
Nista nije prejeftino samo neka cijene padaju!!!!
Netreba mu za 19 lcd 640 mb verzija!!
Staro 12.06.2007., 23:54   #14
prasak
prasak's Avatar
Postovi: 324
Evo, kao što je vidljivo iz siga, uzeo sam što sam i planirao (mala izmjena grafičke i seagate jer nije bilo samsunga), a poslušao sam savjet i uzeo jeftiniju tipkovnicu. Ionako mi se crveni Eclipse ne bi slagao sa plavim ledicama svuda uokolo Taman sam završio svoje prvo slaganje PC-a i mogu reći da sve radi, samo sad treba riješiti softversku stranu priče.
Staro 13.06.2007., 02:32   #15
Joker
Joker's Avatar
Lokacija: Mostar
Postovi: 68
Dodaj gigu rama i ako oces smanji HDD na 250gb nemas potrebe za 320GB.
Joker je offline   Reply With Quote
Staro 13.06.2007., 13:23   #16
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
Autor Joker Pregled postova
ako pogledas post iznad, covjek je kupio vec komp
i kak mislis nema potrebe za 320?! moj je pun i sve mi vise sline cure za onim wd-om 500gb za 800kn u diskontu, a i to pitanje kolko ce potrajat...
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
