Lokacija: Kastela
Postovi: 295
Opet zbunjoza :( sa LCDom
NEC LCD1970NX(2650kn) vs HP 1965(2500kn) skoro sam otiso kupit HPa kad sam skuzio da ovaj NEC ima S-IPS matricu koja bi kao trebala bit naj bolja pa me sad grize sta da uzmem ![]() vise sam i sam sebi dosadio sa odabirom monitora al hebiga to je stvar koja se kupuje jednom u 5godina MINIMUM pa se nebi htio zahebat |
Postovi: 23,634
Kako se ono kaže, sve je to lipo al nije li ovaj NEC malo spor (18mS) ?? Details Panel Technology: S-IPS TFT Screen Size [inch/cm]: 19 / 48.2 Pixel Pitch [mm]: 0.294 Viewing Angle: 176° horizontal / 176° vertical (typ. at contrast ratio 10:1); 176° horizontal / 176° vertical (typ. at contrast ratio 5:1) Contrast Ratio (typ.): 800:1 Brightness (typ.) [cd/m²]: 250 LCD Module at 25 °C Response Time (typ.) [ms]: 18 (11 white / black; 7 black / white) Colours [Mio.]: 16.77 Horizontal Frequency [kHz]: 31.5 - 81.1 Vertical Frequency [Hz]: 56 - 75 Optimum Resolution: 1280 x 1024 at 60 Hz Other Resolutions: 1280 x 960; 1152 x 870; 1152 x 864; 1024 x 768; 832 x 624; 800 x 600; 720 x 400; 640 x 480 Connectors: Digital: 1 x DVI-D; Analog: 1 x mini D-sub 15 pin Plug & Play: VESA DDC/CI; DDC2B/2Bi; EDID Standard Adjust Functions Auto Adjust; Brightness; Colour Temperature Control; Contrast; Fine Adjust (analogue); Intelligent Power Management; Language Select; Monitor Information; NTAA (Non-Touch-Auto-Adjustment); On-Screen-Manager (OSM) lock-out; sRGB Safety and Ergonomics: CE; TCO'03; TÜV ergonomics approved; TÜV GS; GEEA/Energy Label; Energy Star; FCC Class B; PCT/Gost; UL/C-UL or CSA; ISO 13406-2 (pixel failure class II); MPR II/ MPR III; RoHS Power Requirements on Mode [W]: 38 (typ.) Power Requirements Power-saving Mode [W]: < 2 Power Supply: 100-120 V/220-240 V; 1.2 A/0.6 A; integrated power supply Ambient Temperature (operating) [°C]: +5 to +35 Ambient Humidity (operating) [%]: 30 to 80 VESA Mounting [mm]: 100 x 100 ErgoDesign®: Height Adjustable Stand [mm]: 110 Dimensions (W x H x D) [mm]: 412.5 x 386.5 x 220 Screen Tilt [°]: -5 to +30 Swivel [°]: -170 to +170 Bezel Width [mm]: 17.1 Cable Management: yes Kensington Lock: yes Weight [kg]: 7.5 Specials: Analog/Digital Interface; Dynamic Visual Mode (DVM); NaviKey; NaViSet® and NaViSet® Administrator compatible; Power-Off timer; Rapid Response Technology; sRGB Support Audio Functions: Option: MultiSync® Soundbar 70 Colour Versions: Silver Front Bezel, Black Back Cabinet; Silver Front Bezel, Light Grey Back Cabinet Shipping Content: Monitor; Power Cable; Signal Cable VGA - VGA; CD-ROM; Sales Office List; Manual Warranty: 3 years warranty including backlight |
Lokacija: Kastela
Postovi: 295
HF 1965 Bildaufbauzeit (rise + fall): 20 ms Bildaufbauzeit grey-to-grey: 6 ms tako da je taj HP i sporiji od NECa neka mu pise 6ms ...samo sta HP i bolji vidljiv kut za 2 stupnja i kontrast bolji za 200 ![]() Zadnje izmijenjeno od: focal. 16.05.2007. u 11:45. |
Lokacija: Kastela
Postovi: 295
LCD1970NXp = 2600 ali LCD1970NX = 3100kn kvaka je u tom slovu p taj sa slovom p NEMA S-ips matricu nego MVA... E sad ti budi pametan jel mene ja samoh zbunilo jel neke stranice pisu da ima taj sa "p" S-ips marticu bice se i oni koji su to pisali zbunili ka i ja ![]() |
Lokacija: Vz - Zg
Postovi: 2,930
nisam ni znao da se rade ips matrice 19", dobar pronalazak pogledaj reviewe po netu malo ako ih ima, ako je dobar kupi onog koji ti se vise svida jer nijedan nebi spadao u klasu "losih" monitora po tehnickim karakteristikama, a hp je po reviewima jako dobar. Mislim da ne mozes fulat niti s jednim zapravo
FC Bayern supporter
Datum registracije: Mar 2002
Lokacija: Kutina
Postovi: 454
Vjerojatno M-computers!I mene je zainteresirao.....
Pozdrav! Vedran |
Lokacija: Kastela
Postovi: 295
FC Bayern supporter
Lokacija: Kutina
Postovi: 454
Ma vjerujem da bi zadovoljio,a još mi se k tome sviđa što je NEC.
Pozdrav! Vedran |
Lokacija: Kastela
Postovi: 295
