Datum registracije: Dec 2003
Postovi: 823
W.M.5.
Univerzalni originalni I PROVJEREN(!) WM5 operativni sustav WWE (nosi oznaku "SHIP")...(sukladno .. pravilniku link sam uklonio) instalacijska procedura je automatizirana i sadrži generičke WM5 drivere za sve uređaje koji mogu pogoniti WM5 (ili starije verzije).Instalacija je tipično Microsoftska i sastoji se od nekoliko "...do you want to...." procedura. ukoliko vam je sistem korumpiran,ovo je dobrodošla pomoć...
Zadnje izmijenjeno od: tin.. 09.05.2007. u 22:15. Razlog: microsoft |
ono ispred konpjuktora
Datum registracije: Apr 2003
Postovi: 3,659
Postovi: 823
i opet sorry...očito mi je caps uključen po defaultu...:-( još jedna novost u zadnji čas...upravo sam istestirao jedan od najbržih i najboljih WM6 ROM-ova dosada...fantastičan je i superbrz, a tehničke detalje pogledajte ovdje : Windiws Mobile 6 OS 5.2.318 (Build 15341.0.0.0) AKU 0.0 Storage Memory: 43.72 Program Memory: 49.58 Page file: 5.8MB DODACI I FIKSEVI : Added support pages for HTC applications (help files). Added extra ring tones (including "OldPhone"). Added extra themes. Added backlight button assignment. Added support for "Flight" mode (via Comm Manager). Corrected password lockout issue. Corrected button assignment for record button (press & hold). Corrected Microsoft Voice Command startup issue. Corrected "Remote SIM Access" service startup issue. Corrected GPRS resume from standby issue. Corrected lock-up on soft-reset issue. Corrected default notification sounds. Corrected storage card encryption feature. Corrected phone call waiting issue. Enabled ClearType as default font. Improved Comm Manager application. Improved power management. Improved phone application response times. Improved system response time and stability. Replaced ClearVue PDF viewer with Adobe Reader LE. Updated Java MIDlet Manager with new icons. Updated HTC Zip application with new icons. Updated Microsoft Office applications with new icons. APLIKACIJE I TEHNIČKA IMPLEMENTACIJA : CE Rom: (2.02.02 WWE) - Adobe Reader LE 2.0 - CompactFramework 3.0 SP1 - Device Page Pool set to 6.0 MB - GPS receiver Control applet - Revamped outlook, refined icons - Totally re-mastered sound theme and system icons - Increased interface speed - Bundled IP-telephony (VoIP, SIP standard) - Smart Dial 2.0, fast search through contacts, call history - Any tune can now be assigned to any event - Support for shortcuts in Outlook Mobile - Full-fledged meetings arrangement system - Support for HTML in messages (Exchange Server 2007 required) - Smart Filter – handy and fast search through messages - Numerous MS Exchange 2007-tailored changes - Integration with Windows Live online-services - Marketplace – purchase, download, and install directly from the device - Encryption – bundled memory card encryption - Improved Remote Desktop, supports true full screen and sound - New Bluetooth stack including A2DP - Better integration of SIM / USIM contacts - Alphabetic sorting of SIM / USIM contacts in contacts list view - Auxiliary display support native in OS - Improved 'Internet Sharing' - Much improved quick start wizard with 'skip' for tutorial, settings setup at boot time - Pre-provisioned email accounts - vCards over SMS - SMS Multiple Recipient improvements - Save SMS to SIM - One handed PPC folder navigation improvements - WMP full screen video on all devices - Smart-type search - Larger number of preconfigured email providers (including GMail!) - USB Hard-drive emulation updated (for sharing storage card contents via USB connection) - Bluetooth Mouse support (Stowaway Driver set) - Bluetooth car-kit SIM access - Added Battery Icon at bottom - IA Zip update - SIM Manager 5.30 - WM 6 Comm Manager with "Flight" mode Extended Rom: (2.03.07 WWE) - ALTERNATIVA - Mobile Operator settings for all major carriers (including the U.S.)-ALTERNATIVA - Skype 2.1 (with Today Plug-in) - Google Maps Mobile Radio Rom: (1.15.00) - Radio paket radi perfektno ( kao i 1.09.00 and 1.13.00) VAŽNA NAPOMENA ! ROM SA DRIVERIMA JE NAMIJENJEN HTC UREĐAJIMA ! (Qtek 9000,MobilePro,JasJar,Dopod,iMate,Universal,Wizzard...itd...) ![]() ![]()
Zadnje izmijenjeno od: tin.. 06.05.2007. u 03:06. |
Postovi: 18,874
Znači da će taj WM 6 raditi na MDA Variu, jupiii... ![]() EDIT: Zašto se ne može skinuti? ![]() |
#5 | |
Postovi: 823
ako ti je uređaj zaključan providerom moraš ga prvo otključati(jednostavan postupak).. još jednom napominjem..sve što radite,radite na vlastitu odgovornost !
Zadnje izmijenjeno od: tin.. 09.05.2007. u 22:13. |
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
a jel imas neki link sa WM6 ali za PPC uredjaje, znaci one 'klasicne', ne samo HTPC... ili to spada u isti koš pa mogu puknut na PPC Mio550? ![]()
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() ![]() |
Postovi: 18,874
Kakav HTPC te spopao? ![]() ![]() |
#8 | |
Postovi: 823
zato je važno koji uređaj imaš jer Microsoft samo dobavlja platformu,a proizvođač sam stavlja određene drivere..Problem je i u tome ako još imaš na pretplatu pa ti i provider još stavi svoje drivere (to voli raditi T-Com,dok u Engleskoj O2 uopće ne zaključava telefone,na primjer).Bilo bi idealno da je to kao standardni Windows za računala,no...nažalost... Ali ima i izlaz..na stranici proizvođača možeš za svoj MIO naći fikseve i firmware update...klikni ovdje i skini što ti treba.....vidim da im i podrška nije baš bog zna što...nažalost. a ha..evo..mislim da bi jedino mogao staviti (sukladno .. pravilniku link sam uklonio),ukoliko imaš stari WM i ovo je bolje...no prvo svakako posjeti (sukladno ..( pravilniku link sam uklonio) gdje možeš naučiti kako instalirati platformu,a i naći puno toga.
Zadnje izmijenjeno od: tin.. 09.05.2007. u 22:14. |
Postovi: 823
#12 | |
Postovi: 823
e ovako...raditi će... Citiraj:
...tvoj 2003 ne iskorištava potpuno resurse uređaja,pa očekujem da će ti 5.0 raditi daleko brže..tvoj 6515 koristi istu matičnu i proc Intel XScale,o kojem možeš više doznati ovdje i drivere ko i HTC-ovi modeli..Ustvari,ovaj model i radi HTC kao i model hw6510 za AT&T-jev Cingular (Amerika)o kojem možeš više naći ovdje...Treba napomenuti da ako nemaš naprijed kameru onda je uređaj namijenjen Američkom tržištu (nije prošao njihovu kontrolu) a kompletan review možeš pročitati OVDJE,a o XScale tehnologiji izvrstan pdf ovdje,a ako ga želiš još i overclockati i staviti u turbo mod onda post ovdje, no preporučam ti da za svaki slučaj napraviš deployment i backup platforme na SD...opisano je ovdje... ukoliko zapneš u bootloaderu detalje možeš korak po korak isto naći ovdje i isključi sve firewalle,antiviruse,anti...bilo što...moraš imati i active sync 4.5 koji možeš skinuti ovdje. naravno,neznam jel trebam opet napomenuti da sve što radiš radiš na svoju odgovornost,ali pošto je to i star uređaj mislim da mu je i vrijeme za "platformsko krštenje"...
Postovi: 823
editor in chief
Postovi: 151
evo ja sam pokusao kao sto si mi poslao u pm ![]() ![]() |
#15 | |
Postovi: 823
detaljnije ću poslije...sad mi se žuri trenutno....
#16 |
Postovi: 823
zamolio bi moderatore da maknu naslov ovog threada i ostave samo W.M.5 - ako je moguće... hvala
#17 | |
editor in chief
Postovi: 151
Ok, skinut cu taj alat, btw iPAQ je otvoren za sve sim kartice, tj. nije kupljen kod providera! vjerujem da to znaci WWE ![]() Budem bio malo uporniji! hvala jos jednom! |
#18 | |
Postovi: 823
![]() Ukoliko i neće pokrenuti..već imam "zlatnu rezervu",tak da nema straha.. ..naprednu komunikaciju i ostalu podršku ti i dalje šaljem u p.p.(nemoj zaboraviti raditi screen shotove! trebat će za tutorijal o iPaq-u... ![]() savjet: dolje u mom sigu klikni na "member" i učlani se..trebat će ti..i tamo me potraži..
#20 |
Postovi: 823
#22 |
Postovi: 823
ovdje skini wm6, raspakiraj ga i u folder "no error ID" iskopiraj fajl "nk.bf" (to je Radio ROM)...otvori folder i pokreni odatle upgrade...obavezno stavi uređaj u bootloader mode!.. obavezno čitati ovdje ..rutinsku operaciju smo razvukli ko meksičku sapunicu..
#25 |
Postovi: 823
jesmo..ali već kad radiš odi odmah na wm6..vidim da auto-instalacija baš i nejde.vjerojatno treba ručno...e da..potkrao mi se gore tipfeler...nije "nk.bf" nego "nk.nbf"...upravo sam dobio poruku da jedan kolega nije uspio napraviti upgrade...hm...kvragu...treba fakat specifičan ROM...
#27 |
Postovi: 823
#30 | |
Postovi: 823
bootloader mode = camera+power+reset ili drži oba "action" gumba L+R pa reset..drži gumbe toliko dok se ne pojavi potpuno crni ekran...ili....POWER+ RECORD+RESET=BOOTLOADER svaki uređaj koji se goni na bilokoju WM platformu ima bootloader mode...prouči i svoju dokumentaciju koju si dobio uz uređaj..mora biti unutra. ![]() bootloader u iPaq izgleda upravo ovako: ![]() izvor : XDA-Developers forum
