..dno
Lokacija: Crikvenica
Postovi: 1,973
OS-X na PC-u?
Jel tko probao pokrenuti OS-X na PC-u? Naime citam neki info, pa me cisto onako zanima..kako radi..koliko jak stroj treba i sl? Maknuo sam sve linkove da se mozda ne bi klalo s pravilima foruma pa ono.. ..eto cisto me interesira vase iskustvo. Hi y'all, This is Mac OS X 10.4.9 Intel SSE3 [JaS 10.4.8 AMD-Intel-SSE2-SSE3 with PPF1 & PPF2.iso + JaS.10.4.9.Combo.Update.Intel.SSE3.zip] Burn included .iso with anything you like, boot on DVD, follow instructions to install. If you have a RECENT nVidia or Ati card, you can give a try to the included drivers, otherwise it's a bit of a no no for n00bs Reboot after install and copy JaS.10.4.9.Combo.Update.Intel.SSE3.zip on your nice new Os X Desktop. Doubleclick, follow instructions. Don't forget to install the second patch Reboot Voilà, it's Mac Os x 10.4.9 indeed BTW, I'd like to express my admirative gratitude to all the Hackint0sh scene at large and to JaS in particular: I really hope you'll change your mind about your "retirement" Thank you all, exepsylon P.S. Hi yall, This is just to make sure that this torrent I seeded 2 weeks ago isn't corrupted, as different people got different hashes from what should, I hope, be the same files. Maybe, just maybe, my md5s where wrong because I made them while seeding, but it seems quite far fetched to me As always, I don't take any credit whatsoever for this splendid project 99% made possible by the big headed guys, you know mostly JaS, and Semtex, Diabolik, etc. Chapeau bas les gars Here's the link to the SFVs: *** The sfv files in this torrent where made with QuickSFV v2.33a in WIN-SFV32 v1.1a Compatibility Mode. Should you need it you can find it here : *** Voilà, I hope we'll get this sorted out Regards, exepsylon
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” |
Postovi: 34,005
Što se tiče jakosti, Macovi su hardverski slabiji od klasičnih PC-a tako da ne bi imao problema sa svojim kompom.
Postovi: 208
Joj ja sam ih jednom instalirao, ali samo da vidim kako izgledaju. Nikad se nisam previse potrudio raditi sa njima. Sto se tice instalacije full je jednostavno - ko da instaliras vistu. Znam da bivsi clan nicko jos radi sa os x -om na pc-u pa ako zelis posalji mi pm pa ti dam njegov mail. ![]()
C2D e6320, AC freezer Pro Asus P5B Deluxe wifi Sapphire 2900Pro HDD Hitachi 80Gb 4x1Gb DDR2 800 Corsair 450 |
..dno
Postovi: 1,973
E, hvala, bas cu probat, pa se javim ako zapnem..
Lokacija: /
Postovi: 2,053
ja sam htel to instalirat al nemogu zbog grafulje lol ![]() tebi bi trebalo radit bez problema...imaš PM ![]() |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
inace ima na pcexodusu kompletan guide za mac os-x koji sam i sam mislio proci al nisam imao vremena. Tako da evo link http://www.pcexodus.com/phorum/index...pic,153.0.html nadam se da se nekosi sa pravilima foruma nije da reklamiram nesto vec pomazem Ako se pak kosi sa pravilima onda slobodno delete.
#8 | |
ono ispred konpjuktora
Datum registracije: Apr 2003
Postovi: 3,659
ovo je okej, al ako škvadra počne pretjerivat, kresat ćemo ih.
..dno
Postovi: 1,973
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” Zadnje izmijenjeno od: Brown Acid. 07.05.2007. u 00:43. |
bycod
Postovi: 6,699
@ horza a znas bolje je pripremtiti se odma nego acid vidim imas kernel 8.8.1 evo sta rece nicko ""Preporučujem da kupite/nabavite 10.4.7 verziju (8.4.1 kernel). Ja s njom nisam morao ništa posebno prepravljati (osim kextova za grafičku), sve je radilo out of the box "" vjerujem da je u tome problem ![]()
Prečupavi mod
Postovi: 9,118
Koliki je bed sloziti dual-boot sa XP-om i MacOS-om? Planiram uskoro staviti OS X, pa cisto da znam. I da li mora ici na posebni disk ili moze i na postojeci na kojem je XP? Ili barem na drugu particiju istog diska?
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
Postovi: 164
ja sam uspio instalirati samo sam ga brzo maknio, po meni je grije koristiti os x ako nemam maca ![]() evo screnshoot: http://www.if-load.com/store/images/70703mac.jpg |
Postovi: 164
inace ako nekoga zanima sve pojedinosti o instalaciji os x na pc ima na ovome forumu: http://forum.insanelymac.com/ |
..dno
Postovi: 1,973
Ma skužio sam koji je problem..verzija koju imam treba proc s podrškom za ss2..ja sam to gulio na starom (staaarom) celeru..
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja sam na svoju kantu instalirao mac X radi bez frke jedino što nema PS/2 podršku pa je usb i/o oprema must have... Inače po ostalome je sličan visti cca 14-15gb je dobro ostavit za njega (iirc minimalno je 10gb), giga rama i sse2 procesor, nebitno jel AMD ili Intel maker kažu da je inel bolji i da je Ati grafa bolja opcija... dual boot nisam isprobavao jer sam ga na odvojeni hard (disablao sam onaj s windowsima - yic...) stavljao ali mislim da bi sa acronis selektorom ili nekim grub loaderom išlo bez frke...
-- Have a nice day... |
#16 |
Lokacija: Velika Gorica
Postovi: 336
Ako može mala pomoć? Stavio sam poseba HDD u komp(Seagate 160gb 7200.10) i formatirao ga u HFS+, međutim kod instalacije ga se nigdje ne vidi i tu stane jer ga nemam gdje instalirati.
e5200/2x2Gb Mushkin 1000MHz/BFG 8800GT/500Gb Antec Overture II 22"Lenovo 220x Logitech z3e |
#17 |
Postovi: 723
kliknes na utilities i tamo nadjes particiju i obrises je, odnosno formatiras u mac os jur.... nesto no imam i ja problem, digo sam os x i kad se boota sve prodje ok i kad se treba pojaviti main screen bude plavi i nis nema ni ikona ni nicega? di je problem? |
#19 | |
Postovi: 336
Ma ne, uopće ne vidim hard, niti particiju, bez obzira formatirao ga kao FAT32 ili HFS+. ![]()
#20 |
Postovi: 164
ima problema sa sata diskovima, ja sam instalirao verziju 10.4.8 i radilo mi je sve okej osim zvuka i mreze, iako sam nasa drivere nikako skontati kako instalirati, ne snalazim se bas u terminalu ![]() |
#22 |
Datum registracije: Apr 2004
Postovi: 887
jedan od zadnjih je uphuck 10.4.9 Intel x86 install dvd v1.4i r3, ima i od Kalyway-a 10.4.10 ali je vrlo rijetka... Jas 1.4.10 još nema. uvaj uphuck je kao lite verzija osx-a, umjesto standardnih 4.7giga ima nekih 1gb i nekaj sitnog. iz instalacije je maknuto isync, mail, dictionary i desktop pictures od tvoje konfe radit če ti vjerojatno sve osim možda grafe ili lana. EDIT ima i koolkal 10.4.10 update za intel i amd Zadnje izmijenjeno od: jonyb. 21.09.2007. u 01:28. |
#23 | ||
Postovi: 887
IDE kontroler ne radi bez IDE FIXA !! Sve kaj priključiš na žuti SATA bit če užasno sporo, zato kaj moraš namjestiti IDE mod za te SATA priključke. Znači ide ovako: SATA ljubičasti => Hard SATA žuti => DVD/rw ideš u bios i ovak podesiš: Integrated Peripherals zatim Sata Port0-3 Native Mode Disabled Ova postavka se odnosi samo na žute sata, i može se javiti neka greškica tjekom instalacije koja je zanemariva. Zatim podesiš Onboard SATA/IDE Device Enabled Onboard SATA/IDE Ctrl Mode staviš na AHCI kad instaliraš osx napraviš ovaj fix za AUDIO, RESTART, IDE znači otovoriš terminal, zatim napišeš SUDO -S pa pasword koji si stavio za account,nakon toga upišeš nano audio-restart-fix i napraviš copy paste ovog koda dolje, onda ctrl+o chmod a+rwx audio-restart-fix pa upišeš ./audio-restart-fix ugasiš komp, upališ i sve če raditi, i restart... Citiraj:
#24 |
Postovi: 336
Hvala JONYB, uspio instalirati ali mi ne diže sustav, već kaže sljedeće http://tinypic.com/view.php?pic=52oj9f4&s=1 A ova stavka /Onboard SATA/IDE Ctrl Mode staviš na AHCI/ nije upalila, već samo kao IDE
#25 | |
Postovi: 887
#26 |
Postovi: 336
10.4.8 Jas with PPF1 & PPF2, dok 10.4.9 ne želi niti pokrenuti, kaže " com.apple.Boot.plist is not found"
#30 |
Lokacija: virovitica
Postovi: 16
Pozdrav prijatelji, evo ovih dana mi stiže novi komp pa me zanima da li ću na njega moći instalirati OS X, i ako da , koju verziju i gdje ju mogu " KUPITI ". Komponente su sljedeće: Gigabyte P35 DS4 Intel 6550 KINGMAX 2 GB 6400 SATA seagate 320 GB PowerColor HD2600 XT 512 MB |
