Zaključane teme
Staro 06.05.2007., 14:42   #1
Dechec
Dechec's Avatar
Datum registracije: Feb 2003
Lokacija: umag
Postovi: 220
Pomoc; ima li ovdje sto a da mu nije mjesto..?
Evo popisa ekipa, pa ako netko vidi sto "ubaceno", molim pomoc...
hvala
Logfile of HijackThis v1.99.1
Scan saved at 14:39:16, on 6.5.2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\T-Com Antidialer\T-Com Antidialer.exe
C:\Program Files\Eset\nod32kui.exe
C:\WINDOWS\system32\sysvx.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\SpeedswitchXP\SpeedswitchXP.exe
C:\Program Files\HDD Thermometer\HDD Thermometer.exe
C:\Program Files\Lenovo\Bluetooth Software\BTTray.exe
C:\PROGRA~1\Lenovo\BLUETO~1\BTSTAC~1.EXE
C:\Program Files\Lenovo\Bluetooth Software\bin\btwdins.exe
C:\Program Files\Eset\nod32krn.exe
C:\WINDOWS\system32\PMSveH.exe
C:\Documents and Settings\All Users\Documents\My Music\HijackThis.exe
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Image Helper - {646782DF-07D9-5816-C17D-32459D631863} - C:\WINDOWS\system\bpmdm32.dll
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [tcomantidialerrun] C:\Program Files\T-Com Antidialer\T-Com Antidialer.exe
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [sysvx.exe] C:\WINDOWS\system32\sysvx.exe
O4 - HKLM\..\Run: [vgmepaaa] C:\WINDOWS\system32\vgmepaaa.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [SpeedswitchXP] C:\Program Files\SpeedswitchXP\SpeedswitchXP.exe
O4 - HKCU\..\Run: [RSD_HDDThermo] C:\Program Files\HDD Thermometer\HDD Thermometer.exe
O4 - Global Startup: Bluetooth.lnk = ?
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\Lenovo\Bluetooth Software\btsendto_ie_ctx.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_05\bin\npjpi142_05.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_05\bin\npjpi142_05.dll
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\Lenovo\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\Lenovo\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxdev.dll
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\Lenovo\Bluetooth Software\bin\btwdins.exe
O23 - Service: NOD32 Kernel Service (NOD32krn) - Unknown owner - C:\Program Files\Eset\nod32krn.exe
O23 - Service: PMSveH - Lenovo - C:\WINDOWS\system32\PMSveH.exe
Silverston Temjin TJ05 silver+Corsair vx550w
ASRock Z77 Extreme4+i5 3570K
Lg M227WD,Corsair Vengeance 2*4gb / HDD:OCZ Vertex3 128gb, Samsung 1.5TB, Samsung 750gb, WDC 2TB
Member Of PC Ekspert 100+kg Demolition Squad[/SIZE]
Dechec je offline
Staro 06.05.2007., 21:50   #2
tutix
tutix's Avatar
Postovi: 4,069
Imaš sticky okačen gore za logove ali nema veze, ovo je za van:
tutix je offline
Staro 07.05.2007., 11:45   #3
domy_os
domy_os's Avatar
Postovi: 18,851
Ako te zanima samo log, gore imaš temu o HijackThisu, a ako te muči nešto žešće, detaljno opiši problem, a log možeš priložiti ili tu kao prilog ili opet gore u sticky.
domy_os je offline
Zaključane teme
