Staro 05.05.2007., 15:55   #1
leon12
Lokacija: Vž
Postovi: 61
dajte i meni neki savjet ;)
dakle, trebam savjet za konfiguraciju,za igre, do 5k kuna. ovo sam nesto napamet slozio..
pa recite dal je to ok, sto da mjenjam, dal mozda proc stavim amd pa cu jeftinije proci i moci
bolju graf. karticu uzet ili sto. isto tako ne znam koju graf bi uzeo (ovo sam samo tako stavio), pa molim one koji
su upuceni malo bolje da savjetuju..
u obzir dolazi i da mi sastavite sasvim nest drugo..
MB Gigabyte GA-965P-S3, Intel P965, S775, Intel Quad Core ready, FSB1066MHz, 4xDDR2 800MHz dual ch... 764kn
Intel Core 2 Duo E6320 BOX, 2×1.86GHz, 1066MHz, 775-pin, 4MB 1335 kn
*HDD Seagate ST3160815AS, 160 GB 8MB, S-ATA300, 7200 416 kn
DDR2 1GB PC6400 (800MHz), Kingmax 347 kn
DVD+RW/-RW/RAM LG GSA-H22N, Dual Layer, 18x, bulk 215 kn
Power Supply FORTRON 400W, HQ, PFC, 2 x 12V, 12cm fan 313,00
Chieftec midi tower DG-01B-D-U, bez PS, crno, USB, Fire wire 320,00
3600kn
Leadtek GF 7600 GT AGP, 256MB, TV-out, DVI 1.146,25 kn
leon12 je offline   Reply With Quote
Staro 05.05.2007., 16:23   #2
Facelessone
Facelessone's Avatar
Postovi: 4,204
sve ok....
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 05.05.2007., 16:38   #3
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
ploča OK
procesor E4300
disk seagate 10 320Gb
2 Gb ram (667 ili 800) kingmax
fortron 350W PNF
grafička PCI-E X1950GT
Staro 05.05.2007., 16:39   #4
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Na tu ploču ne ide AGP.
Uzmi X1950PRO.
Ako se misliš igrati idi na opciju AMD, pa uzmi 8800GTS 320MB.
2X1GB rama.
250GB Hitachi/Samsung.
Ima 100 tema na forumu već!
Staro 05.05.2007., 16:41   #5
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Bolje uzmi E4300 a za razliku što ostane love uzmi još 1GB memorije.
stuc je offline   Reply With Quote
Staro 05.05.2007., 19:04   #6
Buger
Postovi: 4,388
bolje x2 3600+ i onda uguraš 8800GTS
Staro 05.05.2007., 19:13   #7
leon12
Lokacija: Vž
Postovi: 61
onda ovako
Intel Core 2 Duo E4300 BOX, 2×1.80GHz, 800MHz, 775-pin, 2MB 936,01
2x DDR2 1GB PC6400 (800MHz), Kingmax 347 kn
Gigabyte Radeon X1950Pro 256MB DDR, PCIE, TVout, Dual DVI 1.320,10
4978kn
je to ok?
dajte mi onda neki amd proc i maticnu sa uguranom 8800GTS pa da vidim kako bi to izgledalo.. nadam se da bi onda bilo puno bolje nego ovo gore. naravno, limit je 5k
Staro 05.05.2007., 19:22   #8
Bravo
Bravo's Avatar
Postovi: 1,450
*INTEL Core 2 Duo E4300 BOX =940kn
*MB Gigabyte 965P-DS3 =810kn
*Gigabyte Radeon X1950Pro 256MB =1320
*2x1GB (800MHz) Kingmax =346kn
* HITACHI 160GB =394kn
*FORTRON 400W =313kn
*DVD+RW/-RW/RAM LG GSA-H22N =215 kn
*Chieftec midi tower =320kn
=5004kn
*Athlon64 X2 3600+ =535kn
*Gigabyte M55S-S3 =555kn
*1GB PC6400 (800MHz), Kingmax =346kn
*Gigabyte 8800GTS 320MB =2316kn
*Chieftec midi tower 320kn
=4994kn
ja bih uzeo prvo,više je memorije i jači procesor
Zadnje izmijenjeno od: Bravo. 05.05.2007. u 19:49.
Staro 05.05.2007., 19:32   #9
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Sve je sad ok, jedino ušparaj na grafičkoj...umjesto PRO uzmi GT ---230kn razlike, i kupiš veći 320Gb disk...8800 se po meni ne isplati stavljat na AMD
Staro 05.05.2007., 19:37   #10
joga bonito
joga bonito's Avatar
Lokacija: Vukovar
Postovi: 436
Intel Core 2 Duo E4300 BOX, 2×1.80GHz, 800MHz, 775-pin, 2MB 936 kn
MB Gigabyte 965P-DS3, s775, i965P, DDR II, SATA II, GLAN 810 kn
DDR2 1GB PC6400 (800MHz), Kingmax 346 kn
Gainward BLISS 8800GTS Golden Sample, 320MB, PCI-E, TV-out, DVI 2.359 kn
Codegen midi tower 6102-CA, 400W PSU w/12cm fan, P4, USB, audio, ručka za nošenje 205 kn
UKUPNO: 5.287 kn
Kuciste sam stavio neko najjeftinije i dobijes napajanje 400W pa ako izdrzi super ali preporuka da cim ustedis stavis neko kvalitetnije napajanje
joga bonito je offline   Reply With Quote
Staro 05.05.2007., 19:43   #11
hash
Postovi: 1,431
Autor leon12 Pregled postova
onda ovako
4978kn
je to ok?
maknes ovo boldano -3076kn
znaci ostaje 3098kn
VGA PCI-E XFX, GeForce PCX 8800GTS 500M, 320MB, DDR3, 2xDVI, TV, links 2206kn
AMD ATHLON 64 X2 3600+ AM2 BOX 536kn links (ili 498kn adm)
2x DDR2 1GB PC5300 (667MHz) Kingmax 2x319kn=638kn , ve-mil
ostaje 356kn (394kn) za maticnu
MB:
a) MB Biostar Tforce 570U, 661kn, kvark
b) MB Gigabyte GA-M55S-S3, 549kn, kvark
c) nesto trece
znaci prekoracio si budzet ili 305kn (267kn) s biostarkom ili 193kn (155kn) sa gigabyteicom
ako hoces sve iz ve-mila, onda na finalne cijene dodaj ovo:
gpu = +111kn
cpu = ista cijena
mbo = +6kn (gigabyte)
edit:
neznam da li je ovo dovoljno jako napajanje, provjeri jos
Zadnje izmijenjeno od: hash. 05.05.2007. u 20:04.
Staro 05.05.2007., 19:51   #12
leon12
Lokacija: Vž
Postovi: 61
zanimljivi prijedlozi.. a sto mi je bolje uzet, taj amd ili intel? i dal mi se stvarno isplati 8800 uzimat, je puuno bolje od x1950? ili je bolje uzet radeon pa pricekat dok 8800 ne pojeftini..
joga bonito, daj alterativno napajanje koje ce sve to drzat
Staro 05.05.2007., 20:01   #13
hash
Postovi: 1,431
najisplativije ti je ici na amd konfu i x1950Pro i 700kn spremis u dzep
Staro 05.05.2007., 20:07   #14
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Gigabyte 965P-DS3 – 774 kn ADM
E4300 1.80 Ghz 2MB 800MHz BOX – 831 kn BORG
HDD HITACHI 160GB SATA300 8MB - 382 KN VE-MIL
KINGMAX 1GB 667 – 317 KN VE-MIL
Pržilica po izboru – cca 220KN
Power Supply FORTRON 350W PNF – 212 KN VE-MIL
VGA PCI-E XFX, PCX 8800GTS – 2206 KN LINKS
---------------4942kn-----------------
Kučište po izboru
Sve je složeno po cijenama s nabava.net…za gotovinu
Staro 05.05.2007., 20:15   #15
leon12
Lokacija: Vž
Postovi: 61
za koliko ce mi podici performanse igranja ta 8800 u odnosu na x1950pro?
i nekak se bojim da cijena od 8800 prebrzo ne padne, pa da mi nebude zao sto sam dao tolku lovu..
Staro 05.05.2007., 20:20   #16
Bravo
Bravo's Avatar
Postovi: 1,450
gledaj
e4300+x1950pro+2gb ddr je bolja kombinacija od x3600+8800gts+1gb ddr i to ti je to, nečeš pogriješiti.
Staro 05.05.2007., 20:23   #17
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Gts je PUNO brža...ne bi cijena tak skoro trebala past ispod 2 soma, bez obzira na HD 2900XT
Staro 05.05.2007., 21:17   #18
P.A.L.A.C
P.A.L.A.C's Avatar
Lokacija: Vukovar
Postovi: 59
Autor joga bonito Pregled postova
UKUPNO: 5.287 kn
potpis
..::MiDrAcE NrG PoWeR BlAcK EdItIoN::..
P.A.L.A.C je offline   Reply With Quote
Staro 05.05.2007., 21:21   #19
joga bonito
Lokacija: Vukovar
Postovi: 436
UKUPNO: 5.287 kn
Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 515kn
stavis ovo napajanje i miran si!moja preporuka da uzmes ovu konfu sto sam ti ja slozio jer si onda miran jako dugo vremena i grafa ti je najnovija i podrzava dx10 sto ce ti trebat za novije igrice!
Svakako idi na intela e4300 i ds3 maticnu i sad ako ti je previse i mislis da ti se ne isplati 8800gts uzet onda si bolje stavis 2 gige rama i x1950pro ili si stavi
Leadtek GF 8600GTS, 256MB, PCI-E, TV-out, 2 x DVI 1.549kn isto je dx10 i dosta jaka i brza i jos ti ostane za veci hdd
Staro 05.05.2007., 21:23   #20
P.A.L.A.C
P.A.L.A.C's Avatar
Lokacija: Vukovar
Postovi: 59
fino joga fino, iznenadjujes me iz dana u dan. heh
Staro 05.05.2007., 21:25   #21
joga bonito
Lokacija: Vukovar
Postovi: 436
Autor P.A.L.A.C Pregled postova
heh palčiću
koliko sam slozio konfa po tvom zahjevu cijeloj obitelji sam ti slozio komp
zivio
Staro 05.05.2007., 21:28   #22
P.A.L.A.C
P.A.L.A.C's Avatar
Lokacija: Vukovar
Postovi: 59
heh palčiću
zivio
jos da i rade kako spada
Staro 05.05.2007., 21:30   #23
joga bonito
Lokacija: Vukovar
Postovi: 436
heh u pravu si!!!
Ja sam ti slozio konfu ali ne komponente to su ti oni mulci u HGšrotu napravili znas i sam sta su sa sestrinim kompom napravili mulci nabrzaka ubacili i na kraju 3 puta na servisu hdd u banani,napajanje s***ano...
i uvijek kupujes u tom hgšrotu umjesto da promjenis trgovinu ili bar odi u drugi hgšrot ako bas hoces kod njih a ne stalno u istu trgovinu onu u vk
Staro 06.05.2007., 09:33   #24
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Gadno si zabrijo...Fortron mu je dosta - 212 kn, a da 8600gts ne pričam...128 bitnu grafičku...pa čovjek kaže da mu je stroj za igranje...neznam dali ima netko ovdje na forumu da će kupit tu karticu
Staro 06.05.2007., 09:50   #25
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Autor Bravo Pregled postova
gledaj
Potpisujem kakva 8800GTS u kombinaciji sa 1GB meme, to je u današnje vrijeme malo
Di sam stao?
Staro 06.05.2007., 10:47   #26
Bravo
Bravo's Avatar
Postovi: 1,450
takva (šrot)napajanja nisu dovoljna (za intel+8800gts)jer imaju 12,13A na 12V,a o kvaliteti da nepričam..
Staro 06.05.2007., 10:57   #27
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Točno, neka proba ako hoće, samo da nam ne plače poslje kak si je skurio komp
Staro 06.05.2007., 12:30   #28
joga bonito
Lokacija: Vukovar
Postovi: 436
Autor gilbert5 Pregled postova
Taj fortron je 350W sumnjam da bi izguralo takvu konu mozda na knap a ako bi se islo u OC onda pogotvu nebi!
Pa dobro ja sam mu sastavio C2D i 8800GTS prelazi onaj cifru ali nek skupi koju kunu jos i nek kupi to sto mu je ponudjeno
a za napajanje preporucujem Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors 515kn provjereno da radi na 3800+ x2, 2gige na 800mhz 8800GTS itd i radi kako treba mislav_os ima takvo napajanje a i bolje da mu je malo jace da mu ostane za OC ako planira a sigurno planira cim razmislja o C2D
Staro 06.05.2007., 12:39   #29
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Opa, najbolje nek uzme 1000W...za svaki slučaj
Taj fortron gura i 8800GTX, kako nebi GTS koja troši duplo manje??
Staro 06.05.2007., 12:50   #30
joga bonito
Lokacija: Vukovar
Postovi: 436
Pa dobro nek uzme onda fortrona 350 PNF 212 kn a ako bude OC pa kad neobude radilo ko mu kriv onda!
