Zaključane teme
Staro 04.05.2007., 19:55   #1
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
OS-X na PC-u?
Jel tko probao pokrenuti OS-X na PC-u? Naime citam neki info, pa me cisto onako zanima..kako radi..koliko jak stroj treba i sl? Maknuo sam sve linkove da se mozda ne bi klalo s pravilima foruma pa ono..
..eto cisto me interesira vase iskustvo.
Hi y'all,
This is Mac OS X 10.4.9 Intel SSE3
[JaS 10.4.8 AMD-Intel-SSE2-SSE3 with PPF1 & PPF2.iso + JaS.10.4.9.Combo.Update.Intel.SSE3.zip]
Burn included .iso with anything you like, boot on DVD, follow instructions to install.
If you have a RECENT nVidia or Ati card, you can give a try to the included drivers, otherwise it's a bit of a no no for n00bs
Reboot after install and copy JaS.10.4.9.Combo.Update.Intel.SSE3.zip on your nice new Os X Desktop.
Doubleclick, follow instructions. Don't forget to install the second patch Reboot
Voilà, it's Mac Os x 10.4.9 indeed
BTW, I'd like to express my admirative gratitude to all the Hackint0sh scene at large and to JaS in particular: I really hope you'll change your mind about your "retirement"
Thank you all,
exepsylon
P.S. Hi yall,
This is just to make sure that this torrent I seeded 2 weeks ago isn't corrupted, as different people got different hashes from what should, I hope, be the same files.
Maybe, just maybe, my md5s where wrong because I made them while seeding, but it seems quite far fetched to me
As always, I don't take any credit whatsoever for this splendid project 99% made possible by the big headed guys, you know mostly JaS, and Semtex, Diabolik, etc. Chapeau bas les gars
Here's the link to the SFVs: ***
The sfv files in this torrent where made with QuickSFV v2.33a in WIN-SFV32 v1.1a Compatibility Mode. Should you need it you can find it here :
Voilà, I hope we'll get this sorted out
Regards,
exepsylon
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline
Staro 04.05.2007., 20:05   #2
Postovi: 34,003
Što se tiče jakosti, Macovi su hardverski slabiji od klasičnih PC-a tako da ne bi imao problema sa svojim kompom.
coconut je offline
Staro 04.05.2007., 20:14   #3
Boopsy
Boopsy's Avatar
Postovi: 208
Joj ja sam ih jednom instalirao, ali samo da vidim kako izgledaju. Nikad se nisam previse potrudio raditi sa njima. Sto se tice instalacije full je jednostavno - ko da instaliras vistu. Znam da bivsi clan nicko jos radi sa os x -om na pc-u pa ako zelis posalji mi pm pa ti dam njegov mail.
C2D e6320, AC freezer Pro
Asus P5B Deluxe wifi
Sapphire 2900Pro
HDD Hitachi 80Gb
4x1Gb DDR2 800
Corsair 450
Boopsy je offline
Staro 04.05.2007., 20:18   #4
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
E, hvala, bas cu probat, pa se javim ako zapnem..
Staro 05.05.2007., 15:35   #5
svebee
Lokacija: /
Postovi: 2,053
ja sam htel to instalirat al nemogu zbog grafulje lol
tebi bi trebalo radit bez problema...imaš PM
svebee je offline
Staro 06.05.2007., 22:43   #6
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Koliko to cudo zauzima mjesta na disku?
Matesonik je offline
Staro 06.05.2007., 23:09   #7
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
inace ima na pcexodusu kompletan guide za mac os-x koji sam i sam mislio proci al nisam imao vremena. Tako da evo link http://www.pcexodus.com/phorum/index...pic,153.0.html
nadam se da se nekosi sa pravilima foruma nije da reklamiram nesto vec pomazem Ako se pak kosi sa pravilima onda slobodno delete.
.i.
Razer Blade 15
Codiac je offline
Staro 06.05.2007., 23:24   #8
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
Autor Codiac- Pregled postova
ma ajde, nemoj brijat na paranoju ovo je okej, al ako škvadra počne pretjerivat, kresat ćemo ih.
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
horza je offline
Staro 07.05.2007., 00:33   #9
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Meni odmah brejka u 2-3 sekundi instalacije..
Ima tko kakvu ideju?
Zadnje izmijenjeno od: Brown Acid. 07.05.2007. u 00:43.
Staro 07.05.2007., 14:12   #10
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
@ horza a znas bolje je pripremtiti se odma
nego acid vidim imas kernel 8.8.1
evo sta rece nicko ""Preporučujem da kupite/nabavite 10.4.7 verziju (8.4.1 kernel). Ja s njom nisam morao ništa posebno prepravljati (osim kextova za grafičku), sve je radilo out of the box ""
vjerujem da je u tome problem
.i.
Razer Blade 15
Codiac je offline
Staro 07.05.2007., 14:29   #11
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,118
Koliki je bed sloziti dual-boot sa XP-om i MacOS-om? Planiram uskoro staviti OS X, pa cisto da znam. I da li mora ici na posebni disk ili moze i na postojeci na kojem je XP? Ili barem na drugu particiju istog diska?
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
^SuperUnknown^ je offline
Staro 07.05.2007., 14:33   #12
Tichma
Tichma's Avatar
Postovi: 164
ja sam uspio instalirati samo sam ga brzo maknio, po meni je grije koristiti os x ako nemam maca
evo screnshoot:
http://www.if-load.com/store/images/70703mac.jpg
Tichma je offline
Staro 07.05.2007., 14:35   #13
Tichma
Tichma's Avatar
Postovi: 164
inace ako nekoga zanima sve pojedinosti o instalaciji os x na pc ima na ovome forumu:
http://forum.insanelymac.com/
Tichma je offline
Staro 07.05.2007., 21:04   #14
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Ma skužio sam koji je problem..verzija koju imam treba proc s podrškom za ss2..ja sam to gulio na starom (staaarom) celeru..
Staro 13.05.2007., 21:08   #15
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja sam na svoju kantu instalirao mac X radi bez frke jedino što nema PS/2 podršku pa je usb i/o oprema must have...
Inače po ostalome je sličan visti cca 14-15gb je dobro ostavit za njega (iirc minimalno je 10gb), giga rama i sse2 procesor, nebitno jel AMD ili Intel maker kažu da je inel bolji i da je Ati grafa bolja opcija...
dual boot nisam isprobavao jer sam ga na odvojeni hard (disablao sam onaj s windowsima - yic...) stavljao ali mislim da bi sa acronis selektorom ili nekim grub loaderom išlo bez frke...
Have a nice day...
yedwy je offline
Staro 13.09.2007., 23:22   #16
sale01
sale01's Avatar
Lokacija: Velika Gorica
Postovi: 336
Ako može mala pomoć?
Stavio sam poseba HDD u komp(Seagate 160gb 7200.10) i formatirao ga u HFS+, međutim kod instalacije ga se nigdje ne vidi i tu stane jer ga nemam gdje instalirati.
e5200/2x2Gb Mushkin 1000MHz/BFG 8800GT/500Gb
Antec Overture II
22"Lenovo 220x
Logitech z3e
sale01 je offline
Staro 15.09.2007., 01:15   #17
Spirit
Spirit's Avatar
Postovi: 723
kliknes na utilities i tamo nadjes particiju i obrises je, odnosno formatiras u mac os jur.... nesto
no imam i ja problem, digo sam os x i kad se boota sve prodje ok i kad se treba pojaviti main screen bude plavi i nis nema ni ikona ni nicega?
di je problem?
Spirit je offline
Staro 15.09.2007., 07:29   #18
yedwy
yedwy's Avatar
Postovi: 6,956
Možda ti je prestara verzija? Pitanje je dal ti podržava grafu...
Have a nice day...
yedwy je offline
Staro 15.09.2007., 15:23   #19
sale01
sale01's Avatar
Postovi: 336
Autor Spirit Pregled postova
di je problem?
Ma ne, uopće ne vidim hard, niti particiju, bez obzira formatirao ga kao FAT32 ili HFS+.
Antec Overture II
22"Lenovo 220x
Logitech z3e
sale01 je offline
Staro 15.09.2007., 17:18   #20
Tichma
Tichma's Avatar
Postovi: 164
ima problema sa sata diskovima, ja sam instalirao verziju 10.4.8 i radilo mi je sve okej osim zvuka i mreze, iako sam nasa drivere nikako skontati kako instalirati, ne snalazim se bas u terminalu
Tichma je offline
Staro 21.09.2007., 00:02   #21
Baja 001
Baja 001's Avatar
Postovi: 7,504
Koja je zadnja hack verzija i bi li ima problema na konfi iz siga???
Baja 001 je offline
Staro 21.09.2007., 01:00   #22
jonyb
jonyb's Avatar
Datum registracije: Apr 2004
Postovi: 887
jedan od zadnjih je uphuck 10.4.9 Intel x86 install dvd v1.4i r3, ima i od Kalyway-a 10.4.10 ali je vrlo rijetka... Jas 1.4.10 još nema.
uvaj uphuck je kao lite verzija osx-a, umjesto standardnih 4.7giga ima nekih 1gb i nekaj sitnog.
iz instalacije je maknuto isync, mail, dictionary i desktop pictures
od tvoje konfe radit če ti vjerojatno sve osim možda grafe ili lana.
EDIT ima i koolkal 10.4.10 update za intel i amd
Zadnje izmijenjeno od: jonyb. 21.09.2007. u 01:28.
jonyb je offline
Staro 21.09.2007., 01:22   #23
jonyb
jonyb's Avatar
Postovi: 887
Autor sale01 Pregled postova
sa ovom pločom kaj imaš sve radi eventualno uz nešto malo editiranja ( lan, sound, sata, usb)
IDE kontroler ne radi bez IDE FIXA !!
Sve kaj priključiš na žuti SATA bit če užasno sporo, zato kaj moraš namjestiti IDE mod za te SATA priključke.
Znači ide ovako:
SATA ljubičasti => Hard
SATA žuti => DVD/rw
ideš u bios i ovak podesiš:
Integrated Peripherals
zatim Sata Port0-3 Native Mode Disabled
Ova postavka se odnosi samo na žute sata, i može se javiti neka greškica tjekom instalacije koja je zanemariva.
Zatim podesiš Onboard SATA/IDE Device Enabled
Onboard SATA/IDE Ctrl Mode staviš na AHCI
kad instaliraš osx napraviš ovaj fix za AUDIO, RESTART, IDE
znači otovoriš terminal, zatim napišeš
SUDO -S
pa pasword koji si stavio za account,nakon toga upišeš
nano audio-restart-fix
i napraviš copy paste ovog koda dolje, onda
ctrl+o
chmod a+rwx audio-restart-fix pa upišeš
./audio-restart-fix
ugasiš komp, upališ i sve če raditi, i restart...
sudo rm -rf /System/Library/Extensions/AppleHDA.kext
sudo rm -rf /System/Library/Extensions.mkext
sudo rm -rf /System/Library/Extensions.kextcache
sudo perl -pi -e 's/0x31491106/0x2363197B 0x31491106/g' /System/Library/Extensions/AppleVIAATA.kext/Contents/Info.plist
sudo perl -pi -e 's/0x01060100/0x2363197B/g' /System/Library/Extensions/AppleAHCIPort.kext/Contents/Info.plist
sudo perl -pi -e 's/0x10ec0880/0x10ec0883/g' /System/Library/Extensions/AppleAzaliaAudio.kext/Contents/Info.plist
sudo perl -pi -e 's/0x26688086/0x284b8086/g' /System/Library/Extensions/AppleAzaliaAudio.kext/Contents/PlugIns/AppleAzaliaController.kext/Contents/Info.plist
printf '\260\376\346\144' | sudo dd if=/dev/stdin of=/mach_kernel bs=1 count=4 oseek=578235 conv=notrunc
sudo diskutil repairpermissions /
sudo kextload /System/Library/Extensions/AppleAzaliaAudio.kext
kextcache -k /System/Library/Extensions/
Ovo gore se odnosi na istalaciju JAS 10.4.7 eventualno JAS 10.4.8, neke novije več imaju integrirane fikseve za audio i ide...
jonyb je offline
Staro 22.09.2007., 18:33   #24
sale01
sale01's Avatar
Postovi: 336
Hvala JONYB, uspio instalirati ali mi ne diže sustav, već kaže sljedeće
http://tinypic.com/view.php?pic=52oj9f4&s=1
A ova stavka /Onboard SATA/IDE Ctrl Mode staviš na AHCI/ nije upalila, već samo kao IDE
Antec Overture II
22"Lenovo 220x
Logitech z3e
sale01 je offline
Staro 22.09.2007., 22:11   #25
jonyb
jonyb's Avatar
Postovi: 887
koju točno instalaciju osx-a imaš?
jonyb je offline
Staro 23.09.2007., 01:58   #26
sale01
sale01's Avatar
Postovi: 336
10.4.8 Jas with PPF1 & PPF2,
dok 10.4.9 ne želi niti pokrenuti, kaže " com.apple.Boot.plist is not found"
Antec Overture II
22"Lenovo 220x
Logitech z3e
sale01 je offline
Staro 29.09.2007., 21:24   #27
sale01
sale01's Avatar
Postovi: 336
Evo problem riješen, kupio iMac 20" .
Antec Overture II
22"Lenovo 220x
Logitech z3e
sale01 je offline
Staro 30.09.2007., 10:24   #28
yedwy
yedwy's Avatar
Postovi: 6,956
OMG...
Have a nice day...
yedwy je offline
Staro 30.09.2007., 14:16   #29
jonyb
jonyb's Avatar
Postovi: 887
jonyb je offline
Staro 30.09.2007., 16:25   #30
pablito
Lokacija: virovitica
Postovi: 16
Wink
Pozdrav prijatelji,
evo ovih dana mi stiže novi komp pa me zanima da li ću na njega moći instalirati OS X, i ako da , koju verziju i gdje ju mogu " KUPITI ".
Komponente su sljedeće:
Gigabyte P35 DS4
Intel 6550
KINGMAX 2 GB 6400
SATA seagate 320 GB
PowerColor HD2600 XT 512 MB
pablito je offline
Zaključane teme
