#421 | |
Lokacija: Sinj
Postovi: 1,080
znači to je ova kuća prema kojoj gledam?Ili preko puta ceste? edit.nađoh, tnx ,dobio stalker suit ![]()
... Zadnje izmijenjeno od: bozzomfeeder. 01.05.2007. u 17:10. |
#422 |
Datum registracije: Jun 2004
Lokacija: split i zagreb
Postovi: 490
jedno glupo pitanje. Kako ja otvorin vrata u hotelu od sobe 26 di je onaj dekoder i di da nađen doktora na Pripyat mapi je nidi nisan dobija taj zadatak ili sta vec
CPU: E6400 & termaltake ST RAM: 2x1Gb DDR2 super talent 800-CL4 MB: D975XBX2 GRAF: ASUS 8800GT; Dell 2407 wfp-hc HDD:WD raptor 74Gb (10000rpm) & HITACHI Sata II 250Gb(7200 rpm) CASE: chieftec dragon big black;Corsair HX 520W AUDIO: X-Fi Xstreme Music; Logitech 5.1 Z-5500 THX |
#427 |
Lokacija: livno
Postovi: 1,065
#429 |
Postovi: 490
#431 |
Postovi: 490
iskljuceno je sve negdi san procita da se triba vratit tamo di se stvorin na pocetaku igre ali nemogu nac lika tog a i neznan kako se zove
#433 |
Postovi: 490
ma znan to nego je taj lik na toj mapi
#435 |
Gamer 2 the Bone
Lokacija: Zagreb, oko centra...
Postovi: 1,640
Ja bio kod doktora i našao ono u hotelu u Pripyatu...sad veli "nađi tajna vrata", ali nema markera na mapi. Đe su?
- Nothing in this world is certain. That's the only certain thing I know. - |
#438 |
Postovi: 490
NE CITAJ AKO NEZELIS ZNAT STA CE SE DESIT U IGRI On the trail of Strelok -- Meet the stalker called Guide The stalker you want to talk to for Strelok is in Cordon. In fact, he is in the same spot where you found Fox before. Head back to Cordon and talk with the guy. He will give you new clues about Strelok. On the trail of Strelok -- Meet the "Doctor", who is not a real doctor, like drkay The clue from Guide leads you to Agroprom's sewers -- back to where you found Strelok's secret base. Head back there and get a cut-scene with an NPC. You will get new information and a new marker for Pripyat. This clue is vital for you to get the true endings of the game. di je bija taj FOX dude nemogu ga nac nikako edit: evo san ga nas adi je bija samo je n mrtav a tu i oko nema nikoga
CPU: E6400 & termaltake ST RAM: 2x1Gb DDR2 super talent 800-CL4 MB: D975XBX2 GRAF: ASUS 8800GT; Dell 2407 wfp-hc HDD:WD raptor 74Gb (10000rpm) & HITACHI Sata II 250Gb(7200 rpm) CASE: chieftec dragon big black;Corsair HX 520W AUDIO: X-Fi Xstreme Music; Logitech 5.1 Z-5500 THX Zadnje izmijenjeno od: brzi181. 02.05.2007. u 17:44. |
#439 |
...---... ...---... Stalker zapeo u labosu x-18. Zatvorile me beštije izvana,a drugi prolaz ne vidim/nalazim,osim nazad na ta vrata.Duhovi me cipelare(bačvare?),prže na plamenicima,i prisiljen sam gledati stare 486-ice... Eto, molim kakvog dobrog stalkera da mi skrati muke,i uputi me kako da im umaknem...one dokumente imam,trebam ih vratiti,al' nejde...neće me pustiti. EDIT:Eh,odgovor je čekao na mene na str.11 tako da-riješeno(valjda).Zadnje izmijenjeno od: windfucker. 03.05.2007. u 08:09. |
#440 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,691
Pa ako se ne varam neki su bacili granate u stare "486-ice" pa su rekli da su im se vrata otvorila, a neki (ukljucujuci mene) u gađati u te vatrene duhove (treba potrošiti malo više municije). EDIT: nisam videl da si (valjda) našel rješenje Jel zna tko čemu koriste oni dokumenti iz outposta na početku igre (uz selo desno niz ulicu), tj. za koji quest ili šta več se mogu iskoristiti? |
#441 |
Postovi: 489
Onaj trejder koji te spasi, on ti da taj quest da mu pribavis dokumente... vidim da si ti bil nestrpljiv pa si ih isel prije vrmena nabavljat :P
Poslije BSG-a sve je glupo |
#442 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Da li je izašla kakva verzija patcha koja ti ne dira stari save?
#443 |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Ako može pomoć
Evo u čemu je problem:skinuo sam neki mod S.T.A.L.K.E.R -Faiakes v1.8 ali neznam šta i kako treba napraviti da proradi, i da li je možda problem što sam stavio novi patch 1.0001 i realism mod.Pa ako netko zna molio bi da pomogne ali malo detaljnije(s opisom ili još bolje slikom) ako može naravno. Unaprijed zahvaljujem.Pozdrav. |
#444 |
Super Moderators
Postovi: 17,485
Koliko sam ja vidio jučer-postoji i Faiakes Mod v1.8 Patch, valjda te to zeza... http://stalker.filefront.com/file/Fa...18_Patch;78640
#445 |
Zule
Postovi: 1,993
Instalirao sam igru neki dan. postavke na high, lightning na onoj srednjoj postavci (nije static, a nije ni dynamic), bloom, 2xAA i 8xAF i igra je išla jako glatko, u sobama oko 100fps-a a vani oko 70-80. Jučer upalim igru drugi put, počela kiša padat, onaj dio na samom početku (kamp) i igra se vuče ko zadnja crkotina ...sad meni ne ide u glavu, kako, zašto.. |
#446 | |
Lokacija: Sinj
Postovi: 1,080
#449 |
Lokacija: /
Postovi: 2,053
igra mi uopće nije ništa specijalno, dapače grozno - prešel prvi level i zagasil...ništa novog i inovativnog žalosno nakon takvih odgoda...ali ipak tu tugu ublažuje Crysis ![]() |
#450 |
fanATIčni AMDovac
Lokacija: KC-ZG
Postovi: 1,312
pitanjce kratko...da li netko zna neki link na popis oruzja i koje je najbolje...ljudi tu pricaju o onom gauss rifle a oruzje mi je tesko smece...prespori firerate...dok ja ponovno ispalim metak vojak kod NPP-a ispali u mene cjeli spremnik...i btw. presao sam prvo na najlakse i sad prelazim na stalker i nekako mi je cudno ali dobivam vise "upgradeanih" oruzja tj onih za strelicom prema gore...
