Staro 23.04.2007., 19:44   #1
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,913
8600GTvs7600GT - 8600GT is a joke !
Matta je offline   Reply With Quote
Staro 23.04.2007., 19:52   #2
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Zanimljivo...
A isto tako je zanimljiv i ovaj komentar na taj review
Firstly, let me start off by saying what was more of a joke was the review itself!
The TRUE successor to the 7600GT is the 8600GTS, a much more powerful card clocked at 675MHz core, 2000MHz memory. The 7600GT was at top end of the old Nvidia midrange, and you should have only compared it to its new equivalent, the 8600GTS, instead of its namesake the GT.
Compared with the 7600GT, the 8600GTS holds its own. Probably not enough to warrant an upgrade, but a fair bit faster nonetheless. I don't mean to be rash, but take a look at some of the other 8600GTS reviews for a comparison and you'll find your answer.
And FIY the 8600GT's memory clock is 1.4GHz, the same as the 7600GT, which is why it has the same memory bandwidth.
A more apples to apples comparison is more appropriate next time maybe?
Matth€w je offline   Reply With Quote
Staro 23.04.2007., 20:25   #3
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Ja samo kazem da cekam da ATi (AMD) izda svoju novu mid-range gamu. Onda cu odluciti koja grafa ce zamijeniti moju X1650Pro.
Sad si sve gledam, i isplativije je kupiti neku naclockanu verziju 7900GS ili X1950Pro/GT nego ove nove grafe iz 8600 serije. Ova 8600 serija nikad ne znas kako ce se ponasati. U nekim igrama je super i brza od prethodnika, a u drugima je pak totalna pusiona..i jos popusi od moje ATi-jevke!
Staro 23.04.2007., 20:46   #4
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Koja bruka za nvidiju....
Staro 23.04.2007., 20:59   #5
focal
focal's Avatar
Lokacija: Kastela
Postovi: 295
cuo sam za te informacije vec prije....nego sta je 8600 trbala izac ..necu sad lagat nisam 100% povjervao u to....al sad sam definitivno siguran da nisam falio sa kupnjom 1950pro
hebiga r600 ce bit bolja al otom potom...kad ce to izac i koliko ce kostat
focal je offline   Reply With Quote
Staro 23.04.2007., 21:00   #6
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ja sam pricekao da vidim kako ce ispast. I sad znam sta mi je cinit. Uzet X1950GT.
Staro 23.04.2007., 21:01   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
A što ste i očekivali od direct x10 hardvera za mid range?
Staro 23.04.2007., 21:10   #8
JC Denton
JC Denton's Avatar
Postovi: 3,164
Autor tor Pregled postova
Očekivao sam da 8600GT bude u svemu bolja od 7600GT, a 8600GTS da bude u svemu bolja bar od 7900GS i/ili X1950Pro. I to sve po sličnim cijenama kao kartuše s kojima sam ih upravo usporedio.
A što smo dobili? 8600GT koja još zadovoljava kako-tako po nekim testovima (brzina tu negdje sa 7600GT po istoj cijeni), i 8600GTS koja možda i je brža od 7900GS u 60% slučajeva, ali košta 400-600kn više... što je way too much, pogotovo kad uzmemo u obzir da se serijski naclockana 7900GS nabavi za manju cijenu od 8600GTS, a takva 7900GS je pojede "za dorucak" po vecini testova.
Iako me "vuku" te nove DX10 grafe, imam snazan dojam da kupnjom jedne od njih ne dobivam ono što sam platio
Staro 23.04.2007., 21:39   #9
Grofaz
Postovi: 285
Nije sve u FPS. Najveći adut tih grafa je to što se piše po netu da je kvaliteta slike ipak bolja sa dx10 pri istim postavkama. Pa ako ljudima nije bitno 6-7 FPS gore dolje, onda ipak ima argumenata. To što su ljudi zagriženi za te brojke koje su svima postale isus krist i majka božja to je druga stvar. Ima i reviewa koji se ne fokusiraju strikno na FPS. E sad, jel to stvarno istina da je kvaliteta slike bolja il ne...
Grofaz je offline   Reply With Quote
Staro 23.04.2007., 22:37   #10
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Ovo nVidia nije smjela dozvoliti nikako...
Evo prilike za Ati da konačno nakon 3 godine odnese pobjedu u mainstreamu
Lud76 je offline   Reply With Quote
Staro 23.04.2007., 23:33   #11
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Hmm, vec sam mislio da sam se zaletio s kupnjom grafe (posto uporno necu s AGP-a ), da ce izac 8600GT i 8600GTS za AGP, koja ce za manje pare rasturat moju x1950.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
