#31 |
Lokacija: VT
Postovi: 333
2050kn je previse za karticu sa 32 Shader procesora i 128bit sirinom sabirnice, osim toga cijena je i nelogicna jer za 250kn vise dobijes 8800 sa 96 shader procesora, ne ovdje nema nikakve logike. Ko zna mozda je ovo marketinski trik da sto vise ljudi kupi 8800gts, makar je i ovo malo vjerojatno. Jednostavno po treci puta ponavljam, nema tu logike. ![]() |
#32 | |
Lokacija: Varaždin-Zagreb
Postovi: 76
#33 |
Postovi: 184
To sto jos nema konkurencije u dx10 klasi objasnjava dijelom manjak logike, a onda jos treba prodati vec proizvedeni high i mid dx9 kartice dok se jos moze. To je (vjerojatno) logican potez da se izvuce maksimum iz trzista. |
#34 | |
Postovi: 7,568
ECS, Chaintech, BFG i XFX 8600GTS Review
We found both GeForce 8600 GTS GPU based video cards to provide noticeably higher performance and image quality in every game compared to the ATI Radeon X1950 Pro. Our gameplay evaluation has proved that the architecture of the GeForce 8 series is much different, and better, compared to the previous pipelined architecture in GPUs. This goes to show that you cannot use conventional thinking anymore. With 32 scalar streamlining processors the GPU can balance the load of pixel and vertex data so that nothing is idle. We get much better efficiency out of this system. We expect that over time prices will fall on the GeForce 8600 GTS as well and you may find them cheaper as the weeks and months pass. Compared to ATi’s current generation the GeForce 8600 GTS kicks its butt. Compared to NVIDIA’s own last generation, GeForce 7 series, the GeForce 8600 GTS kicks its butt. Citiraj:
Izvor: [H]ard|OCP i OCWorkbench |
#35 | ||
Uptime 99.99%
Postovi: 2,547
Evo testovi po meni razocaravajuci previse para za premalo muzike: Citiraj:
Anandtech Citiraj:
Evo i zasto je kod cijena Gainwarda nesto vise od drugih modela. |
#36 |
Je suis Schumi
Postovi: 1,524
Razočaranje za puno love ![]() ![]() A još su tu 7900GS i X1950 GT/Pro/XT i ako se malo OC-aju... ![]() Po mom totalno ne isplativa investicija ![]()
Di sam stao? -Stalji smo onda kad je *ebem Šćepanović ![]() |
#37 |
Postovi: 1,130
Point of View modeli: Point of View GF8600GTS, cijena 1600 kn + PDV Specifikacija: GF 8600GTS 256MB DDR3 128-bit Engine clock 675MHz, memory clock 2GHz, memory speed 1.0ns GDDR3 2xDVI-I, HDTV-out, TV-out Podržava Directx10.0 i Shader model 4.0 Prvih 40 kupaca dobiva na poklon Point of View gamer laser mouse i mousepad! Point of View GF8600GT, cijena 1090 kn + PDV Specifikacija: GF 8600GT 256MB DDR3 128-bit Engine clock 600MHz, memory clock 1,4GHz, , memory speed 1.4ns GDDR3 2xDVI-I, HDTV-out, TV-out Podržava Directx10.0 i Shader model 4.0 Point of View GF8500GT, cijena 740 kn + PDV Specifikacija: GF 8500GT 256MB DDR2 128-bit Engine clock 450MHz, memory clock 800MHz, , memory speed 2,5ns GDDR2 DVI-I, HDTV-out, TV-out podržava Directx10.0 i Shader model 4.0
..smartphone... |
#38 |
Premium moderator
Postovi: 4,600
__________________ |
#39 |
Je suis Schumi
Postovi: 1,524
#40 | |
Postovi: 1,130
pa biti će valjda u manje/više svim većim; Links i Ve-mil? No mislim da nema smisla automatski pljuvati po 128bit sabirnici, naročito nakon dragulja kao 7600GT. U usporedbi sa nekim "starijim" modelima koji su sad zanimljivi zbog jako dobre cijene kao 7900GS, 7950GT, X1900 serija ima smisla sračunati koje je bolje rješenje, no sama 128bit sabirnica nužno ne znači da kartica nije dobra ![]() A cijena ko cijena, sve je skupo kad izađe, pokupuju je likovi kao Drago, firme malo zarade i onda se krenu klati sa cijenama kad je svi dobiju i proizvođači snize svoje cijene. Stara priča...
..smartphone... |
#42 |
Lokacija: Dalmatia
Postovi: 116
Polako, polako, smanjiti euforiju za ljude pliceg dzepa, kada dodje ATI R600 cijene ce jos kalati.....A onda kupiti 8800 GTS bez puno razmisljanja ! |
#44 |
Prečupavi mod
Postovi: 9,107
Hmm, vidim li ja to AGP karticu na: http://www.pcekspert.com/news/20070417.html#57284
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#45 |
Datum registracije: May 2005
Postovi: 53
Vidis ![]() Po zeleznom frame-u oko gpu bi reko ta je to neki radencek a i cini mi se da vidim ati logo na chipu... |
#48 |
Prečupavi mod
Postovi: 9,107
Layout me podsjeca na EVGA 7800GS AGP, izgleda da je to ta... EDIT: yep ![]() http://www.pcmasters.de/hardware/rev...lagschiff.html
#51 |
Postovi: 582
#53 |
Leteći medvjedić
Postovi: 1,204
#54 |
Lokacija: rijeka
Postovi: 3,849
yap pročito guru recenziju,odškicao testove,vlasnici 7900 gs te radeka x1950 pro nemaju razloga prelaziti na isto s dx 10 podrškom,1700 je puno, bolje dodati 600 kunića i zeti 8800 gts 320 mb,možda nvidia nakon njurganj kupaca ili loše prodaje izbaci 256 bitnu verziju. |
#57 |
Postovi: 939
...i sa samo godinu dana garancije. Uzeti nesto drugo... a istina je to, kad bih gledo po garanciji uzeo bih BFG gdje je garancija 3 god tak tak ja sebi namjeravam u 9 mj kupiti VGA PCI-E GIGABYTE, GeForce PCX 8800GTX koji kosta 3864.22kn a do 9 mj se past jos cijena ![]() |
#58 |
Lokacija: Sinj
Postovi: 1,080
do devetog mj će sigurno izać nešto bolje i povoljnije aka 8900GS , ova 8800GTX će biti sada ko 7800GTX
#59 | |
Lokacija: VT
Postovi: 333
#60 |
Lokacija: Sinj
Postovi: 1,080
